[Solved] Iris BC2HP Brush Cutter: Carburetor Adjustment After Unintentional RPM Screw Alteration
Camille93 117375 12
How should I readjust the carburetor on a brush cutter after accidentally changing the RPM screw, if it now smokes and the cutting head turns at idle?
Set the mixture screw with the spring while the engine is running: start from fully screwed in and back it out about 3/4 turn, then fine-tune in small steps of about 1/8 turn until it accelerates smoothly under load without excessive smoke [#13559089] [#13559330] [#13563008] Adjust the idle screw separately so the engine idles evenly and the cutting head does not rotate [#13559089] [#13563008] Do not leave it in a position where it chokes or runs “like crazy”; the goal is smooth pickup, even running through the rev range, and no smoking [#13563008] If the machine still stalls after some minutes, also check the tightness of the carburetor/cylinder/muffler connections and the fuel-cap vent hole, because a blocked vent can create a vacuum in the tank and stop fuel flow [#13559089] [#13632176]
  • #1 13557652
    Camille93
    Rate: 45
    Hello, I have a brushcutter like in the subject (Chinese scythe). I have a problem with it, namely when I mowed with the scythe, it walked normally only after about 20-30 minutes of mowing ordinary grass, so it was not too hard, the scythe went out by itself and it was impossible to fire it again. Only after waiting a day, the two scythe fired without any problem.
    Trying to remedy it, having no experience, I started to play with the carburetor and RPM screw (my mistake). Now the scythe does not walk as it should, it smokes and previously it hardly smoked at all. The fuel mixture is the same before I toyed with the regulation. In addition, the circular head slowly rotates, without adding gas.
    I would ask for the help of experienced people on how to adjust it, below are photos of the scythe. Unfortunately, I do not have the manual, it is lost somewhere.
    In advance, let me just mention that I took it apart and cleaned it, and so did I.
    Iris BC2HP Brush Cutter: Carburetor Adjustment After Unintentional RPM Screw Alteration Iris BC2HP Brush Cutter: Carburetor Adjustment After Unintentional RPM Screw Alteration Iris BC2HP Brush Cutter: Carburetor Adjustment After Unintentional RPM Screw Alteration
  • #2 13559089
    azxxc
    Help: 20
    Rate: 236
    If you smoke and choke at the same time when you go into speed - too rich mixture, too much fuel, a screw with a spring is used for adjustment.
    I have set it many times - no philosophy, I take a screwdriver and go to mow, fire up, try to mow, then using the trial method: if I wind the smoke, let's say 1/8 of a turn, and an attempt to mow, if it seems weak and does not turn well, unscrew it minimally. I know that the method is not professional, but whenever I adjusted it according to the instructions that are all OK somewhere on the forum, it fired well, but when trying to mow (under load) it turned out that it gets weaker, it gets too little fuel and it was necessary to slightly unscrew the adjusting screw.
    To adjust the second (top) screw - unscrew it so much that the engine at idle runs evenly and at the same time the head with the line does not spin.
    It is of course unnecessary to add that the entire adjustment makes sense if the scythe is operational: compression, spark plug (break, spark), proper (tight) connection of the carburetor with the cylinder.
  • #3 13559219
    Camille93
    Rate: 45
    Thanks for the answer and tell me whether you can adjust both screws, the one with the carburetor spring and the idle speed on the scythe, or before the adjustment, it should be turned off. And is there a risk of incorrect or not fully adjusted carburetor adjustment?
    As for the smoking, as I wrote in the subject, she did not smoke almost at all before playing with regulation, but only started after playing. A was working and running on the same fuel mixture (25: 1) as before, so I guess it's not the mixture's fault.
  • #4 13559330
    azxxc
    Help: 20
    Rate: 236
    The 25: 1 mixture is ok, all Chinese work on it.
    The adjustment is made with the engine running, you start it, press the gas to full throttle several times and you can see if it goes into revolutions well, it would be practically impossible to do it when it was turned off.
    In the long run, of course, it is harmful to overheating, seizing the rings with carbon deposits, with too rich a mixture it will eat fuel like a dragon, with sales, it will be weak, it will choke, fade out - just not a job.
    I have an identical scythe 6th season and contrary to popular opinion: it is not so bad, despite the fact that it works quite well, I only replaced the clutch (the spring broke) and from time to time carburetor adjustment I do not know if they all have it.
  • #5 13561807
    Camille93
    Rate: 45
    I took up adjusting the carburetor for now. I noticed that in one position the scythe walks like crazy after adding gas, in another it suffocates it. I do not know if I should leave this position as crazy, because I will wear out faster? Should I maybe just leave the prop in a place like this between running like crazy and choking it?
    Another thing is that it continues to kick, no matter what position I put the screw in.
    Edit
    I screwed it in completely and twisted it 1.5 turns. When I was mowing it seemed to work well, but after about 8 minutes of mowing my fishing line got blocked, I had to turn it off and unlock it. When I turned it off, I saw that from the muffler side it was running down the scythe and there was such a black goo on the tank, I don't know what that means. Then, after cleaning this fluid and unblocking the line, the scythe refuses to fire: /
    Could you check if it's not a problem for you, how many revolutions do you have this screw with a spring removed?
  • #6 13563008
    azxxc
    Help: 20
    Rate: 236
    ... how many turns do you have this screw with a spring removed?
    In mine - fully screwed in and unscrewed 3/4 of a turn.
    It is not allowed to choke, just smoothly enter the revolutions and work evenly throughout the range of revolutions and at the same time not to smoke.
    Check the tightness of the connection between the carburetor and muffler to the cylinder.
  • #7 13573615
    Camille93
    Rate: 45
    In the 3/4 position, unscrewed, it does not want to start at all, I set it to 1.5 turns, turned it on, I mowed for 15 minutes, it went out by itself and did not want to fire again, in addition, such black goo was flowing again as I mentioned in the previous post.
  • #8 13573673
  • #9 13574410
    Camille93
    Rate: 45
    Could you tell me which one and how to regulate it?
  • #10 13587092
  • #11 13632176
    kamil.ck13
    Rate: 12
    I also had a problem with the fact that after some time it choked and finally went out, solving the problem turned out to be trivial. There is a tiny hole in the traffic jam that lets air into the tank, but it somehow clogged. There was then a vacuum in the fuel tank and the scythe could not pull fuel. It is enough to unscrew and close the tank every now and then and everything will be ok. I also opened this hole with the needle, but I think the needle was too big and now, when the tank is full, sometimes something will leak out of fuel.
  • #12 13769185
    wsz_rk
    Help: 258
    Rate: 11
    Let me disagree with the honorable speaker. I would not touch the cork. The cork consists of three parts A, B, C. In the external elements A, C there are indeed 1.5 mm holes, but B is the proper part, where the working function is performed by a 2mm incision in the rubber material. Once I followed my friend Kamil's footsteps, but I had to replace the cap with a new one, because the fuel was leaking through the cap.
    I find the comments of my colleague azxxc (# 2) valuable and helpful, but with a working carburetor. I tried this method (regulation of the mixture composition), but the effects were temporary and inconclusive. My observations about the carburetor as in the topic are as follows: the new carburetor does not require any adjustment after installation and works properly for a while until something hurts it, then no magic helps except buying a new one. I suppose the carburetor is hurt by storing fuel in the scythe's tank. Certainly, fresh fuel (not older than 3 months) is also important, as it loses more easily flammable fractions when it ages. At the moment I am already using the third carburetor. The cost of purchase is PLN 24. Falontech
  • #13 18762209
    Autorol
    Rate: 50
    The carb in this scythe is surprisingly complicated, the fuel diaphragm pump, channels and Micro Filterek, I warn you against mixing fuel in water containers, one drop will immobilize your engine. As for the aging of fuel, it is said that something happens with red oil after mixing with fuel after time, does not know it crystallizes? although the class of the oil is supposed to be the highest, probably even a synthetic oil. That is why many users use ordinary oil, even a mixer, this also applies to petrol chainsaws, and this information comes from a professional saw.
The discussion revolves around issues faced with the Iris BC2HP brush cutter, particularly after the user unintentionally adjusted the carburetor's RPM screw. The user reported that the brush cutter would stop running after 20-30 minutes of use and would not restart until a significant wait. After adjusting the carburetor, the machine began to smoke excessively and the circular head rotated slowly without throttle response. Various users provided insights on carburetor adjustment techniques, emphasizing the importance of tuning while the engine is running and the potential consequences of a rich fuel mixture. Recommendations included adjusting the mixture screw and ensuring the carburetor is functioning properly. Users also noted the significance of maintaining the fuel system and avoiding stale fuel. Some shared experiences with similar models, highlighting common issues and solutions.
