Nac x510hvy Mower: Issues Starting Post-Winter, Oil Change, Knife Sharpening & Pipe Replacement
tomasz9920 23277 17
Why does my NAC x510hvy mower start, run for a few seconds with black smoke, then stall and refuse to restart after an oil change and blade sharpening?
Check for oil/fuel flooding first: if the mower was tilted during maintenance, there may be too much oil in the OHV engine, so remove the valve cover, verify the oil level, and blow out the cylinder after removing the spark plug [#16445095] Use the proper original air filter setup, because running without it or with the wrong filter can make the engine fire back through the filter cover; for this NAC engine that means a paper filter plus the sponge pre-filter, with the paper element replaced and the pre-filter washed and lightly oiled [#16449982][#16453870] If the mower only runs with pumping, re-clean the carburetor more thoroughly, including the main nozzle, and check the intake/carburetor seals and gaskets for air leaks [#16466769][#16467349][#16467363] In the end, the thread author reported that the mower was working again and the actual fault was the speed controller [#16467930]
  • #1 16444414
    tomasz9920
    Rate: 33
    Hello, I have a problem with the Nac x510hvy mower, namely after winter I changed the oil, sharpened the knife, changed the pipe from the candle because the old one was cut off. After the first attempt of firing, the mower fired and walked normally but kicked it black, after a while I extinguished it and since then I do not want to fire. I cleaned the air filter, the entire carburette, but it did not do anything. The spark is there, the fuel comes in because the candle burns after many attempts to fire and the mower does not work any further. Please help. I could not find the right department because I chose this one
  • #2 16445095
    Czyżycki
    Help: 75
    Rate: 197
    You did not specify your engine, so I assume that there is a top-notch engine, signed as NAC, e.g. T675. If so, I would suggest:
    1 / unscrew the valve cover (such as OHV) and check if there is too much oil, which when changing the oil and operations with the knife certainly got there by dimming.
    2 / unscrewing the spark plug and blowing oil and fuel residues out of the cylinder.
    When starting a cold engine carefully with pumping fuel, because this engine is easy to pour.
  • #3 16445273
    tomasz9920
    Rate: 33
    Thanks for your help, I'll check and write what and how ? tomorrow
    Added after 10 [hours] 26 [minutes]:
    Now the mower walks for about 10 seconds and goes out, but when instead of the air filter, I put a cloth all the time but the problem is that it shoots fire from the filter cover ?
  • Use the correct air filter and pre-filter servicing
    #4 16449982
    Czyżycki
    Help: 75
    Rate: 197
    I still do not know your engine.
    After cleaning the carburetor, it may turn out that the engine will only work properly on the original fresh air filter. If it is a NAC engine, there is a paper filter and so-called. pre-filter (piece of sponge). The pre-filter must be washed in detergent and lightly soaked with motor oil.
    The paper air filter must be replaced with a new one.
    I hope you did not start the engine without the knife mounted.
  • #5 16450253
    tomasz9920
    Rate: 33
    No, the knife was put on
  • #6 16450566
    Czyżycki
    Help: 75
    Rate: 197
  • #7 16452559
    tomasz9920
    Rate: 33
    NAC POWER OHV, top-valve, four-stroke, cast iron sleeve. Engine data
  • Replace oil-flooded air filter to fix mower backfire
    #8 16453841
    timon125
    Help: 58
    Rate: 31
    Hello. I know the case when during the disassembly operation, the mower was tilted too much which caused a kick at the initial firing and consequently the machine was not started. Green World mower, Brigs & Straton 625 engine, paper air filter. Cleaning did not help. The machine was almost new, it worked 2 months. Only replacing the filter with a new one helped. Maybe in this case it will help? It all depends on whether it was flooded with oil or not?
    He shoots fire because the composition of the mixture is not suitable - too much air because there is no filter. It is very difficult to replace the original filter with something else with adequate air throughput.
  • Pump fuel through rough running to clear residual oil
    #9 16453870
    Czyżycki
    Help: 75
    Rate: 197
    This is a NAC engine. All my previous comments are current. I will just add that if you start the engine, you can help him in the self-cleaning of residual oil by pumping fuel when the engine starts to lose speed. Try not to extinguish the engine, if it smokes or unevenly worked, so be it - I think it will finally settle itself.
    I assume, of course, that you have done the cleaning of the carburetor exactly, the throttle regulator rods are not bent, and the air filter will be new.
    Colleague @ timon125 he wrote the right note.
  • #10 16454277
    tomasz9920
    Rate: 33
    Thank you for your help, I will order a new filter and let me know what and how.
  • #11 16465686
    tomasz9920
    Rate: 33
    A new filter has arrived today. At the beginning after firing the mower went out after a few seconds, but when the fuel pumped it went all the time, after some time she started to work without the help of a pump, but the speed of flew, after turning on the drive and entering the grass the engine loses power and goes out. When the fuel pumped up, the mower could handle the grass and the revolutions did not wave. I tried to adjust through the screw on the amount of air, but it did not help
  • Repeat carburetor cleaning and seal the intake system
    #12 16466769
    Czyżycki
    Help: 75
    Rate: 197
    In my opinion, you should repeat the carburetor cleaning, but this time with the main nozzle removed and the plastic carburetor removed from the top. After that I would look at the seals of the carburetor connection with the cylinder and the air filter housing. It may be necessary to make gaskets - from the side of the filter housing it is originally a combination of plastic and plastic.
    Let me remind you that in the first post you wrote about the problems after sharpening the knife and changing the oil. I therefore decided that the carburetor was flooded with oil, which is a fairly common case. Since I do not know the quality of the activities you have done, and you do not describe them accurately, I suggest repeating them and additionally trying to seal the entire intake system. I understand that the carburetor for cleaning is removable, which may additionally affect the tightness of the intake.
    I am asking you to carry out your activities accurately and describe them, because we must be sure of something. Otherwise, we will pursue the heel.
  • #13 16467156
    tomasz9920
    Rate: 33
    Cleans the carburetor exactly once more today. I still wanted to ask how seals should be put in order, I want to be sure everything is ok
  • #14 16467180
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    You did not run anything else? Leakage sign in the fuel system (left air).
  • #15 16467267
    tomasz9920
    Rate: 33
    I did not expand anything more
  • Carburetor removal risks gaskets and governor linkage damage
    #16 16467349
    Czyżycki
    Help: 75
    Rate: 197
    The gaskets that we are interested in that may be damaged when removing the carburetor are:
    1 / air filter base gasket (thick plastic.) On its surface, there are risers that can be opened link
    2 / gasket under the carburettor (large plastic, can be torn when separating it from the carburetor) link
    The gasket 1 is between the carburettor and the air filter housing, the gasket number 2 is between the carburettor and the engine block.
    When removing the carburettor, it is important not to damage the spring and pull rod of the speed controller hooked to the throttle lever of the carburetor.
  • #17 16467363
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    Pay attention to the tightness when screwing, thoroughly clean the element before applying the gasket, to be sure to use new gaskets.
  • #18 16467930
    tomasz9920
    Rate: 33
    The mower is already working, the problem was in the speed controller, but everything has already been done. Thank you all for your help. I close the topic
    Moderated By Pawel wawa:
    The report came: Let the author describe exactly what was the cause of the damage or give the opportunity to ask questions because at the moment I am curious for the future what caused the damage. A colleague has similar concerns in a similar mower. Why set up a new topic if you can find out something meaningful, the only author described the removal of the fault. Maybe a colleague would like to share the solution? I open the topic again.
The discussion revolves around issues faced with the NAC X510HVY mower after winter storage. The user reported problems starting the mower despite changing the oil, sharpening the blade, and replacing the spark plug pipe. Initial attempts to start the mower resulted in black smoke and eventual failure to start. Various troubleshooting steps were suggested, including checking for excess oil in the valve cover, cleaning the carburetor, and ensuring the air filter was in good condition. The user later confirmed that the mower started briefly but struggled under load, leading to further adjustments and cleaning of the carburetor. Ultimately, the issue was resolved by addressing the speed controller, allowing the mower to function properly.
