EuroTec brushcutter – dies on throttle, fuel in air filter, what to check?
RafiRup 121197 11
Why does my EuroTec brushcutter die when I give it throttle and leak fuel into the air filter, and what should I check?
Check the fuel lines first; the thread ended with the fault being broken fuel lines, which explained the engine dying on throttle and fuel leaking into the air filter [#16797099] Before that, the recommended checks were to clean the fuel system/carburetor, blow out the jets and small passages with compressed air, and also blow out the fuel lines [#13786692][#13786745] Fuel should not leak from the air filter area [#13795262] If cleaning and line checks do not fix it, another suggestion was a dead muffler or worn carburetor diaphragm on a membrane carburetor [#14729444][#14729708]
  • #1 13786683
    RafiRup
    Rate: 47
    Hello!
    I have a EuroTec brushcutter, I have had trouble with it for some time, because after adding more gas it goes out or it goes out as if it was going to go out, the revolutions are very low. Earlier, I noticed where the air filter is that it is full of fuel and sometimes fuel leaked there, especially when the mower was no longer at the suction.
    Do you have any ideas?
    I would like to add that there are no L or H screws for speed regulation.
  • #2 13786692
    Padrettini
    Help: 98
    Rate: 556
    Try to clean the fuel system. Maybe it is contaminated and adding gas cannot give enough fuel and goes out and / or slime.
  • #3 13786713
    RafiRup
    Rate: 47
    So I have to clean the entire carburetor? And by what means or simply from dust, etc.
  • #4 13786745
    Padrettini
    Help: 98
    Rate: 556
    There are special carburetor cleaners. You can easily get them on a popular auction site for a maximum of PLN 20. Then blow out the nozzles and small holes with compressed air. Also, don't forget to blow out any fuel lines.
  • #5 13795201
    RafiRup
    Rate: 47
    So I did what my colleague wrote above and there is indeed no silting and it does not go out, but there is another problem now, when I start the scythe, it starts at the same speed, often the speed is not equal after adding the same amount of fuel (after adding gas). I noticed that when the scythe is choking on the choke, it is so screaming and dark gray smoke is there, and after a while fuel leaks from the air filter, maybe it should be like that or I didn't pay attention to it.
  • #6 13795262
    jasiek1122
    Help: 50
    Rate: 366
    There is no way fuel should leak from the air filter, if it is at the intake the fuel can escape through the muffler, not burnt fuel. :D
  • #7 13795674
    RafiRup
    Rate: 47
    But it's leaking there, what should I do?
  • #8 13806783
    RafiRup
    Rate: 47
    Problem still not solved, please help.
  • #9 14728720
    zeimp
    Moderator on vacation ...
    Help: 548
    Rate: 2345
    At the author's request, I am restoring the thread.
  • #10 14729444
    Pawel wawa
    Help: 1262
    Rate: 4431
    Gentlemen, there must be a muffler already dead. Cleaning and trying again.
  • #11 14729708
    Sławek K
    Help: 44
    Rate: 232
    The fuel sold in Poland is not conducive to membrane carburetors. Unfortunately, after a short time of 1 - 2 years, the damage to the abovementioned You can then yank or "bite" the tool out of anger. No adjustment helps, passed cleaning ... no wonderful carburetor cleaners. This applies to lawn mowers, brushcutters and chainsaws. The "brand" ones withstand a little longer the effects of petrochemical products ...
    Thank God, or rather the Chinese, the carburetor costs PLN 25-30, so cleaning and replacing the diaphragm makes no sense immediately replacing the carburetor and the equipment returns to normal operation, which I wish to a distressed colleague. Of course, repairing in this way is working on a Chinese scythe, because replacing the carburetor in a brand scythe is not an option due to the cost - here, replacing the membrane.
    Slawek
  • #12 16797099
    RafiRup
    Rate: 47
    Solved topic, broken fuel lines.
The discussion revolves around issues with a EuroTec brush cutter that stalls after adding gas and exhibits low RPMs. The user initially suspects a fuel system contamination, leading to suggestions for cleaning the carburetor and fuel lines. After cleaning, the user reports persistent problems, including uneven speeds and fuel leaking from the air filter. Responses indicate that fuel should not leak from the air filter, suggesting potential muffler issues or carburetor damage due to poor-quality fuel. Ultimately, the user resolves the issue by identifying broken fuel lines as the cause of the problems.
