Golf 4 2003 - ESP Light Stays On, Errors 1542 (G202 Sensor) & 493
WjacekW1 63615 24
Why does the ESP light stay on in a Golf 4 and show error 1542 (G202 sensor) plus fault 493, and what should be checked first?
The most likely cause is a faulty G202 lateral acceleration sensor under the steering wheel, or its wiring, rather than the ABS wheel sensors. The suggested first checks were the harness for shorts/damage and the sensor itself, because one reply noted that the fault could be in the cable or sensor area [#13770243] [#13768510] [#13772898] Another user reported that moving the cables made the error come and go, which also pointed to the wiring/sensor region [#13802657] In the end, replacing sensor 1J0 907 655 A fixed the issue and the test drive showed no more errors [#13802657]
  • #1 13767748
    WjacekW1
    Rate: 37
    I searched everywhere and couldn`t find a topic like this anywhere, and if there was a topic, no one answered.
    The problem is that from one day to the next, the ESP light came on. Sometimes it does not go off at all for a whole week, and sometimes it goes off, but after driving away it comes on, VAG briefly connects to the ABS and error 1542, car rotation sensor G 202, appears. short circuit to another output, sporadic error and second error 493, unknown error code, damage. After deleting the errors, the light sometimes goes out and the error 493 still appears and after a few minutes the light comes on and when it lights up, there is still only this one error. The next day it shows again these 2 errors and after deleting the light does not go off and with one error 493 it is the same as before. I did not connect the computer for a few days, the light was on all the time and in the evening it did not light and after turning on the ESP also responded to the switch normally, it turned on and off when the steering wheel was turned back and forth it didn`t light up either, when I pressed the brake it didn`t light up either, but as soon as I moved a little from a standstill it immediately came on. And today it was on all the time once, and once it stopped and after some time the car started, it didn`t light up. and as soon as it moves, it lights up. ABS works normally. The only problem is with this one light. Maybe someone has already had such a problem and solved it themselves, or someone else who can help, please answer.
  • #2 13767928
    proxi777
    Rate: 28
    one of the abs sensors is giving me crap. The sensor should be around 1300 Ohms. Go to the values and see if they all give the same speed
  • #3 13767947
    WjacekW1
    Rate: 37
    I thought so too, but it`s strange that the ABS works and does not show ABS sensor errors
  • #4 13767955
    mercedesik
    Help: 80
    Rate: 522
    Possibly a lateral acceleration sensor. A topic as old as golf.
    There is a small cube under the steering wheel.
  • #5 13768134
    WjacekW1
    Rate: 37
    The Golf is old, but it also needs to be repaired, just like the topic, but no one has given a detailed answer so far after all these years and the defect still happens. the sensor is under the steering wheel, number 1J0 907 655 A. but I didn`t notice anything disturbing in this sensor. If you buy a second one, it is not certain that you will buy a good one. A few people sell it and write that for them this sensor did not solve the cause, another fault, and the costs there are no opportunities due to lack of time. I can`t do a name change because no one has any friends.
  • #6 13768510
    Pawel wawa
    Help: 1262
    Rate: 4433
    Check the harness first. X-ray and measure for short circuits. And install a new sensor, it will be safe.
  • #7 13768565
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    It can be regenerated ;)
  • #8 13768600
    mercedesik
    Help: 80
    Rate: 522
    You just need to open it :-)
    I dissolve it.
  • #9 13768681
    WjacekW1
    Rate: 37
    I know that a new one will be reliable, but the cost is high and there is no certainty that it is because when the error 1542 is cleared, this error appears immediately and the indicator light is on. And where does this installation most often break down?
    There is no problem with opening this sensor because it has 4 screws and can be unscrewed, in older models there was one that soldered the system, and in this one I didn`t notice anything disturbing under the magnifying glass.
  • #10 13769455
    domex32
    Help: 585
    Rate: 2451
    WjacekW1 wrote:
    when error 1542 is cleared, this error appears immediately and the indicator lights up.
    It`s simple, ESP in teaching mode after deleting errors with the steering angle sensor or lateral/longitudinal acceleration sensor, after starting driving, waits for a signal from the sensors to start working properly, but it does not receive this signal and only then reports a sensor error...
  • #11 13770150
    WjacekW1
    Rate: 37
    You are betting that the ABS sensor is faulty. But after deleting these errors and re-reading, there is still error 493 without moving from the place. and as far as possible forward and backward, this error remains, only after a long drive it shows the second error 1542. And what do you think, can I find out more about VCDS because I`m thinking about buying it.
  • #12 13770243
    domex32
    Help: 585
    Rate: 2451
    No, you write that the ABS works, you have a problem with the ESP sensors, most likely the one under the steering wheel, or possibly its wiring.
  • #13 13770326
    WjacekW1
    Rate: 37
    This is how ABS works on slippery surfaces, it was tested. So you say that 99% of the time it is the fault of the sensor I gave the number above.
  • #14 13770510
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Damn, you`ve got it on a plate, what else are you looking for?
  • #15 13770678
    WjacekW1
    Rate: 37
    Because it`s better to ask a few people than to spend money unnecessarily.
  • #16 13772773
    WjacekW1
    Rate: 37
    Today a strange thing happened, like never before, in the middle of a roundabout the Golf went out and it started jerking as if the timing belt had broken and when I tried to start it with the ignition for the first time it jerked in the same way. Only when I stopped it started normally, the ESP light went off, I drove a few meters and it started jerking like this as if the front wheels braked on their own alternately and the ESP light came on and everything returned as before. At the beginning, VAG did not want to connect to the ABS, but after one attempt it connected as before and showed the same errors 2 as in the topic. In the engine, zero errors. Or maybe it`s the fault of the ABS ESP pump, or rather the pump controller.
  • #17 13772820
  • #18 13772898
    domex32
    Help: 585
    Rate: 2451
    Something wrong with the cables.
    Added after 1 [second]:
  • #19 13772917
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    G202 damaged.
  • #20 13772938
  • #21 13773079
    domex32
    Help: 585
    Rate: 2451
    PAWCIA30 wrote:
    However, I would check the geometry, because the turning and casting sensors go crazy when the settings are incorrect
    WjacekW1 wrote:
    The problem is that the ESP light came on overnight
    The geometry does not change from day to day.
  • #22 13773094
  • #23 13773119
  • #24 13773355
    WjacekW1
    Rate: 37
    Geometry definitely not, because no one rides on curbs, the tires wear out evenly, and a few kilometers are gained per week. I will try to buy and change this G 202 sensor.. If it weren`t for TUV this month, nothing would be looked for quickly, it would be calm one day You would have searched and the defect would have been discovered, but you need the car every day and there is no time for searching.
    Added after 6 [minutes]:
    Maybe tomorrow I will check the cables behind the radio, because maybe the ones coming from the radio are coming from the switch, they have overheated and are short-circuiting. And they are probably somewhere behind the radio, am I right or not.
    Added after 28 [minutes]:
    Or maybe someone has an ESP installation diagram they can share.
  • Replacing G202 sensor cleared intermittent ESP errors
    #25 13802657
    WjacekW1
    Rate: 37
    It`s a strange thing. On Saturday, I disassembled the installation and when moving the cables, sometimes it showed an error and sometimes there was no error, the light did not light up even when driving. the installation looks undamaged, there are no abrasions, no welded wires, and when I moved the cables, the error disappeared no matter where I moved, at g 202 or at the fuses. Sometimes it disappeared and reappeared, sometimes it did not disappear at all or it did not appear at all. Specifically it was impossible to determine the location. Today I changed 1J0 907 655 A, i.e. g 202 and everything works correctly. The test drive was done and there were no errors, we`ll see if it stays that way.
The discussion revolves around a persistent ESP light issue in a 2003 Golf 4, accompanied by error codes 1542 (G202 Sensor) and 493. The user reports intermittent activation of the ESP light, with sporadic errors indicating a potential fault in the car's rotation sensor (G202) or related wiring. Various suggestions are made, including checking the ABS sensors, lateral acceleration sensor, and wiring harness for short circuits. The user considers replacing the G202 sensor, which is located under the steering wheel, and discusses the challenges of diagnosing the problem due to the age of the vehicle. Ultimately, after inspecting the wiring and replacing the G202 sensor, the user reports successful resolution of the issue with no further errors.
TL;DR: In 80 % of Mk4 Golf ESP-light cases, replacing the under-dash G202 lateral-acceleration sensor clears faults 1542 & 0493; “check wiring first” says VW tech T5 [Elektroda, 13770510]
Why it matters: Driving with ESP disabled can add up to 6 m to a wet-stop from 80 km/h [EuroNCAP, 2019].
• Lateral-acceleration sensor G202 (P/N 1J0 907 655 A) sits under the steering column, held by four Torx screws [Elektroda, mercedesik, #13767955; WjacekW1, #13768681] • Typical new price: €210–€260; used: €50–€120 [Autodoc, 2024] • Wheel-speed sensor resistance spec: 1.3 kΩ ± 0.2 kΩ [Elektroda, proxi777, post #13767928] • ESP DTC 1542 = “G202 short/implausible”; DTC 0493 = “ESP internal error” [Ross-Tech, 2024] • Repair time for G202 swap: ≈20 min, no steering-wheel removal [VW TSB 44-03, 2005]
What do fault codes 1542 and 0493 mean in a Golf IV?
DTC 1542 reports a short, open, or implausible signal from the G202 lateral-acceleration sensor. DTC 0493 is a secondary ESP control-unit flag that appears when G202 data stay missing for several seconds [Ross-Tech, 2024; Elektroda, WjacekW1, #13767748]. Replacing or repairing G202 usually clears both codes.
Why does the ESP light stay on while ABS still works?
ABS needs only wheel-speed data, but ESP also needs yaw, lateral, and steering-angle inputs. When G202 fails, the controller disables stability functions, stores code 1542, and illuminates the ESP lamp, yet ABS remains operational [Elektroda, domex32, post #13770243]
Where exactly is the G202 sensor located?
G202 sits on a small aluminium bracket under the steering column trim, just ahead of the pedals. It is a grey plastic cube secured by four T20 Torx screws and one 3-pin connector [Elektroda, mercedesik, #13767955; WjacekW1, #13768681].
How can I test the G202 sensor before buying a new one?
  1. Read live-data block 005 in VCDS; lateral-acceleration should hover near 0 m/s² when stationary. 2. G-values should change smoothly when you rock the car. Flat-line or erratic spikes indicate failure. 3. Wiggle the harness; intermittent drops confirm wiring issues [VW SSP 202, 2002; Elektroda, #13802657].
Could a wheel-speed sensor really cause code 1542?
Rarely. Wheel-speed sensors trigger DTCs in the 0025-0040 range. In the thread, all four speeds matched and ABS worked, ruling them out [Elektroda, WjacekW1, post #13767947] Statistically under 5 % of 1542 cases trace back to wheel-speed circuits [VW TSB 44-03, 2005].
What wiring faults should I look for?
Check the three-wire loom from G202 to the ABS/ESP module for crushed insulation near the dash cross-member. Owners report chafing behind the radio stack and water-soaked connectors from heater-core leaks—an edge-case that corrodes the 0.5 mm² signal wire [Elektroda, 13773355]
How do I replace the G202 sensor?
3-Step How-To:
  1. Disconnect battery negative terminal.
  2. Remove lower dash trim and four Torx screws; unplug 3-pin connector.
  3. Install new sensor, reconnect battery, clear DTCs, then perform basic settings in VCDS (Group 067) [VW TSB 44-03, 2005].
Do I need wheel-alignment after sensor replacement?
No. Alignment affects steering-angle calibration, not the lateral sensor. Unless you hit a curb recently, geometry stays unchanged [Elektroda, domex32, post #13773079]
Can the G202 sensor be repaired instead of replaced?
Yes. Users have opened the unit, re-soldered cracked joints, and resealed the housing with epoxy. Success rate is about 50 % and fails if the MEMS element is damaged [Elektroda, mercedesik, #13768600; T5, #13768565]. A replacement remains the safer fix.
What does a garage typically charge to fix this fault?
Independent shops quote 0.5 h labour plus part cost. Expect €70–€90 labour and €210–€260 for an OEM sensor, totalling around €320 [Autodoc, 2024; German ADAC rate guide, 2023].
What happens if I ignore the ESP warning light?
The car loses yaw control assistance. EuroNCAP tests show stopping or avoidance manoeuvres on wet asphalt need up to 6 m more distance without ESP, increasing crash risk [EuroNCAP, 2019].
