[Solved] OMRON RX2 – error “E” after deflation, can it be repaired?
alkoholik1983 48960 4
  • #1 13790818
    alkoholik1983
    Rate: 179
    I have an Omron RX2 blood pressure monitor as mentioned in the topic. something bad started happening to him. When measuring the pressure, when the air is released, error "E" appears. After turning on the device, it pumps air correctly, then the counter gradually drops down and when it is about to show the result, the error is displayed. Batteries changed several times, contacts under the batteries are like new.
    Can it be repaired or should the blood pressure monitor be thrown away?
    It looks like damage to the heart rate sensor or an error in writing to memory.
  • #2 13790842
    music
    Help: 94
    Rate: 264
    It pumps all the way and when releasing it shows E? Does it stop, release and show E while pumping?
  • #3 13792544
    zbig205
    Rate: 56
    Hello. I opened the topic " Searching for a "Metrodyne MPS-2000" pressure sensor "The point is that I have 3 Medisan blood pressure monitors and one has the same error as the colleague who started the topic wrote and the other two have the error described by the colleague above. When the blood pressure monitor fills air but the pressure on the indicator does not increase, the pressure sensor is probably damaged. I join in to the question, what can be damaged if the sensor pressurizes the pressure normally and shows the values and the error appears only when the result should be shown?
  • #4 13797410
    alkoholik1983
    Rate: 179
    It pumps all the way and when releasing it shows "E" (at a low value of about 40)
  • #5 17329498
    alkoholik1983
    Rate: 179
    I`m closing the topic
