Error 3. How do I resolve the issue? Buy a new tube and cup?
firerep1 5727 1
  • #1 20947517
    firerep1
    My micro life gentle will not fully inflate and gives an error code of 3. How do I resolve the problem, buy a new cup and hose?
  • Troubleshoot hose, cuff, and battery issues
    #2 21026383
    farhanshahid2k5
    Check the Hose and Cuff:
    Ensure that the cuff is properly connected to the hose and that there are no kinks or twists in the hose that could impede airflow.
    Inspect the Cuff:
    Check the cuff for any signs of damage, such as tears or leaks. If the cuff is damaged, it may not inflate properly and will need to be replaced.
    Verify Proper Placement:
    Make sure the cuff is placed correctly on your arm according to the manufacturer's instructions. It should be snug but not too tight or too loose.
    Reset the Monitor:
    Try resetting the blood pressure monitor according to the instructions in the user manual. Sometimes a reset can resolve temporary issues.
    Replace Batteries:
    If the monitor is powered by batteries, try replacing them with fresh ones to ensure that power is not the issue.
    Contact Customer Support:
    If the problem persists after trying these steps, contact the manufacturer's customer support for further assistance. They may be able to provide additional troubleshooting steps or advise on whether new parts are necessary.
    If, after troubleshooting, you determine that the cup and hose need to be replaced
