[Solved] Troubleshooting Microlife BP 3AG1 Blood Pressure Monitor - ERR 3 Error and Pressure Valve Issues
tadziu47 68586 3
  • #1 18831335
    tadziu47
    Help: 43
    Rate: 45
    Hello !
    I was forced to use a blood pressure monitor Microlife BP 3AG1.
    Proper pressure cannot be built up in the cuff.
    After a while, the measurement shows the error: ERR 3
    I changed the batteries, then also and connected the power supply.
    And the measurement result still shows error: ERR 3 .
    For subject matter experts.
    Could the pressure valve be damaged? And where can I buy it?
    I am attaching his photos.
    Regards !
  • #2 18832759
    Tumiwisizm
    Help: 125
    Rate: 195
    This error appears when the sleeve from the blood pressure monitor is put on the arm, or does it fly (pump) when empty?
    As empty without a hand, the error will always be on everyone.
    leonard64
    Help: 22
    Rate: 78
    Are you sure that the cuff is ok, i.e. 100% tight? With this message, 99% of damage is due to cuff leakage. The easiest way is to check it by pumping it up to a certain degree, and then clamp (bend) the hose, if it becomes "flak" after a short time - the cuff needs to be replaced. It also happened to me that the cuff socket in the camera broke, the effect was similar.
  • #4 18838445
    tadziu47
    Help: 43
    Rate: 45
    Hello !
    I went with the above blood pressure monitor to the medical store.
    There, on the spot, a very nice lady took a new cuff off the shelf
    and checked the blood pressure monitor.
    diagnosis; cuff unsealing.
    Buying a new cuff PLN 19.
    Regards !
