AMICA Refrigerator Transport: Which Side to Lay Down When Moving?
jabadu_ 143901 16
Which side should I lay an old Amica refrigerator on when transporting it horizontally?
Lay the refrigerator on the left side as seen from the back/photo, not on the discharge side [#13802509] [#14060409] The reason given is that the suction tube is on the L side, and laying it the wrong way can let compressor oil get into the refrigerant lines and clog the capillary [#13802804] After transport, keep it upright for about 3 hours before plugging it back in [#13802509] [#16048878]
  • #1 13802367
    jabadu_
    Rate: 9
    I have a refrigerator to transport. Unfortunately, I do not have stand-up transport, so I have to transport it on the side. I read that you can transport her on the side. Unfortunately, I am not able to determine which one.
    Refrigerator data. I know that this is a relatively old AMICA refrigerator. However, I have a photo of its back, where the generator is located.
    In the photo I put the letters L and P denoting the sides of the refrigerator, looking from the back.
  • #2 13802509
    spkb
    Help: 7
    Rate: 71
    Take it on the side marked in the photo L. Wait about 3 hours after placing it in a new place.
  • Lay the refrigerator on its door to protect compressor tubing
    #3 13802520
    Arekdj0
    Rate: 35
    The tubes are directed to the back of the refrigerator unit, it will be safest to put it on the door and then nothing will happen, because no oil should get into any of them, unless you break the engine mounting inside the compressor from "perfectly equal Polish roads ".
    And by the way, it might help ;)
    http://www.przeprzałki-lodz.pl/porady/transport-lodowki-zamrazarki/
    and this:
    https://www.elektroda.pl/rtvforum/topic1077809.html
  • Clarifying safest refrigerator transport orientation
    #4 13802773
    jabadu_
    Rate: 9
    So if I understood correctly, I can pack it on the left side (looking from the back) or put it on the door. Are both options reasonably safe? Maybe one is better after all?
    As for the links, I have already familiarized myself with the topics, but I have no experience in this type of transport (it must always be the first time), so I preferred to ask more experienced people.
    Thank you for your interest in the topic.
  • #5 13802804
    bruns
    Level 30  
    Help: 101
    Rate: 303
    I also think there is a suction tube on the "L" side.
    Do not put on the pressure side so that the oil does not clog the evaporator capillary.
  • #6 14059846
    salkometer
    Rate: 16
    Hello, I did not want to start a new topic.
    On which side should I put the refrigerator when transporting it horizontally?
    Pafnucy
    Help: 9
    Rate: 21
    From the photographer's perspective, it is best to place it on the left side.
  • #8 14061441
    RFTiTONSIL
    Help: 16
    Rate: 35
    Gentlemen, but when I was transporting refrigerators, various freezers, I never thought about putting it on the right side, I put it as it came in and always if they were operational, they would run and cool well.
  • #9 14108284
    Arekdj0
    Rate: 35
    You were lucky.
    From what a friend of mine and producers of refrigerators and freezers explained to me, there is oil in the compressor of refrigerators, which, by placing the refrigerator on the wrong side, can get into the pipes with the refrigerant and plug them. Therefore, you have to look at which side you put the refrigerator. Ps. The warranty on refrigeration appliances also mentions this and if we damage a refrigerator or other refrigeration appliance in this way, they simply will not take it into account and we will have to repair it at our own cost.
  • #10 15316788
    pavianek
    Rate: 10
    Hello. I wanted to know how to transport my crap .... I mean on which page.
    I have read so much with it pressed upwards or downwards. With a wire blinded here and there and I don't know anymore.
    Here she is ... AMICA Refrigerator Transport: Which Side to Lay Down When Moving?
    nares
    Home appliances specialist
    Help: 1522
    Rate: 3395
    On the left side of the photo.
  • #12 16047747
    canseco
    Rate: 9
    I will add my question. Which one to put the refrigerator for forced transport? It's all about Samsung hardware. To my eye on the left side - "L" in the photo. Please give me your opinion.
    Thank you for your help in advance.
  • #13 16047944
    nares
    Help: 1522
    Rate: 3395
    This is.
  • #14 16048878
  • #15 16433525
    matgra
    Good morning everyone!
    Forgive me for digging up the old topic, but I don't see the point in starting a new one.
    Please advise on which side it is better to transport the refrigerator. In my opinion, looking at the photo, it is on the one marked 'L'? AMICA Refrigerator Transport: Which Side to Lay Down When Moving? The capped tube should be at the top?
    I will be grateful for your help!
  • #16 16433556
    Rezystor240
    Help: 689
    Rate: 1655
    Yes, looking at the photo, on the left side.
  • #17 16433918
Transporting a refrigerator horizontally requires careful consideration of which side to place it on to avoid damaging the compressor and refrigerant system. Users recommend placing the refrigerator on the left side (marked 'L' in the provided images) to prevent oil from entering the refrigerant lines. It is advised to wait approximately three hours after transport before plugging it in to allow any displaced oil to settle. Some users noted that placing it on the door is also a viable option. However, caution is emphasized regarding the potential for oil clogging the evaporator if the refrigerator is placed on the wrong side. Overall, the consensus is to prioritize the left side for safe transport.
