Transporting Refrigerators: Can They Be Lying Down or Must They Stand Upright?
piorun4u 269280 33
Can a refrigerator be transported lying down, or does it have to stay upright?
A refrigerator is best transported upright; if it is a compressor model, it can be laid on its side only with care, while absorption refrigerators should stay upright [#564009][#419410] If you must transport it horizontally, place it on the compressor side, preferably the right side when looking at the door, so oil does not flow into the suction tube/circuit [#386814][#419469] Do not tilt it more than about 45° if possible [#386631][#418647][#430112] After transport, leave it standing upright before switching it on; replies recommend anywhere from about 12 hours to 20–24 hours, and some say until the next day [#418647][#564036][#386582]
  • #1 386487
    piorun4u
    Rate: 8
    I am asking if it is possible to transport lying refrigerators? because I heard that it should be transported standing. Regards, JACEK
  • #2 386514
    md666
    yes! it's true standing up!
  • #3 386542
    Jogesh
    Help: 33
    Rate: 688
    Necessarily standing, but slight tilts shouldn't hurt, at least they didn't hurt my refrigerator. :)
  • #4 386554
    piorun4u
    Rate: 8
    Thanks for the advice because I already wanted to put the refrigerator in the car, but I can see that it is not a good idea thanks to Mr. JACEK
  • #5 386582
    Krzysi0
    Help: 45
    Rate: 196
    It shouldn't be, but you can. For example, there is a note on the plug from the Amica refrigerator that when it was transported lying down, it must be left an hour before it is turned on.
    So as you can see you can, but you have to give her a little character before you turn it on. It is best to let it stand for a few hours.
  • #6 386631
    ZAHYR
    Help: 200
    Rate: 179
    Yes, but not every refrigerator can be transported on a lying, standing, it is permissible to have a 45 ° slope
  • #7 386778
    porabka
    If the refrigerator was tilted more than 45 °, wait 2 hours after placing it in its final position and you can turn it on.
    Kisses
  • #8 386814
    zayzayer
    Home appliances specialist
    Help: 246
    Rate: 757
    You can transport the refrigerator lying down. Preferably on the right side
    (looking at the door). The point is for the oil to pour into the suction tube,
    not crowded. Attention! Very rarely, but I have seen ice. where the tubes
    were derived the other way around.
    After such transport, I suggest you turn it on only on the next day.
  • #9 418233
    casper_asiulek
    each refrigerator can be transported on the person lying on it, transporting such equipment, I put it on the door and it never happened to me that there was any damage :lol:
  • #10 418647
    XAX
    Help: 27
    Rate: 159
    According to the rules, refrigerators should not be tilted above 45 degrees. From my many years of experience it appears that a large number of refrigerators transported in this way then goes to the service with damaged compressors (broken suspension or damaged valves). If you have to move to the bed lying down, wait at least 12 hours for the oil to drain thoroughly.
  • #11 418738
    lechm56
    Help: 112
    Rate: 368
    Refrigerators should not be transported lying down !! See the symbols on the packaging !! :wink:
  • #12 418796
    wolfbit
    Only standing up because otherwise Freon would have poured out if it was lying on its side!
  • #13 418856
    k3048
    Level 37  
    Help: 515
    Rate: 281
    hello, it is better not to transport the refrigerator so that it does not fall, i.e. with your head
  • #14 419408
    jarek.agd
    Rate: 19
    And where can it spill? :?: can be transported, look at the position of the terminals on the compressor (suction and discharge), place it in such a way that the oil does not pour into the pipes, usually on the door. If it is possible to transport vertically, I advise you to do so.
  • #15 419410
    jozefg
    Help: 197
    Rate: 746
    As far as I know, it is forbidden to transport only absorption chillers lying down - while the compressor ones can.
  • Lying transport risks compressor oil and suspension damage
    #16 419469
    XAX
    Help: 27
    Rate: 159
    As there are a few less experienced colleagues here, I will try to present all the bad points of transporting a refrigerator lying down.
    1) There is oil in the compressor. During operation, it is lubricated with oil mist. When we transport it lying down (especially on the back), the oil can flow into the pipes at the back of the compressor and when it is turned on for the first time, it can damage the valves. Of course, if the equipment stays its own, there is a good chance that it will run off and nothing will happen.
    2) The pump itself is suspended on springs inside the compressor housing, and additionally the gas is led to it by means of corrugated pipes. When it rides on its side, these elements are heavily loaded and they can break.
    3) The compressor itself has rubber feet. There were cases that during shocks, the socket at the baniak could break.
    Therefore, it is never advisable to keep this equipment lying down.
  • #17 421198
    ZAHYR
    Help: 200
    Rate: 179
    I do not know what for :arrow: casper_asiulek dug up this topic, because for these 25 days :arrow: piorun4u must have transported the refrigerator a long time ago :)
  • #18 422698
    casper_asiulek
    I dug up this topic to read what people have ideas and what other degrees of inclination I come up with for transporting refrigerators :D aaaa and someone else wrote freon above it will pour out hmm freon is a gas dear man and the point here is that the oil that is in the compressor does not get into the system and this is the thing
  • #19 422718
    XAX
    Help: 27
    Rate: 159
    Our colleague casper_asiulek plays the provocateur for us :)
    And I was trying to answer that seriously :D
  • #20 423889
    ROBIC
    XAX say quite a lot about it and he was right, it is not advisable to lay it on the side, but if you have no other choice, the safest thing is to transport it to the door. Then there is the least risk of damaging the refrigerator
  • #21 427581
    GRZECHO 1
    Hello, there are many reasons in the fact that refrigerators cannot be put down, but if there is a need, there is no problem to transport the refrigerator horizontally. You just have to remember that the totem should be standing vertically at least 12 hours. I do not require myself to repair any art clogged with oil or with a broken pressure, after such an operation. so knows no fear.
    GREETINGS
  • #22 428130
    elektronik321
    Help: 29
    Rate: 51
    should be transported standing, as already mentioned about the compressor, best if the equipment is transported under it, place a shell around 15 cm to reduce vibrations and remove all glass and plastic shelves
  • #23 429777
    caro
    Can be at an angle of up to 45 degrees
  • #24 430087
    XAX
    Help: 27
    Rate: 159
    It is a fact that it can be tilted and transported at an angle of 45 degrees.
  • #25 430109
    grzeskk
    Help: 320
    Rate: 731
    can be transported lying down, but it is necessary to wait until it is attached
  • #26 430112
    elektronik321
    Help: 29
    Rate: 51
    A 45 degree slope is acceptable
  • 45-degree tilt acceptable; wait two hours after greater tilt
    #27 431193
    ZAHYR
    Help: 200
    Rate: 179
    it has already been said about 3 times :!: :!: :!: :
    caro wrote:
    You can at an angle of up to 45 degrees
    Kisses
    :arrow: electronics321 Be careful because you might be treated as a point accumulator with hopeless posts
  • #28 564009
    ^ToM^
    Help: 495
    Rate: 2940
    I have read such nonsense here about refrigerators, I have not experienced such nonsense anywhere. One repeats the nonsense of the other without bringing anything to the matter. EVERY refrigerator can be transported on a lying, only one condition: it MUST be placed on the side of the compressor. My dear, this transport is about ONLY oil (and possibly where and sometimes it can mix) and not any freons (not used anymore - isobutanes are currently used). The compressor is filled with oil, which fulfills the insulating and cooling function , and lubricating. This oil shouldn't come back into circulation. Circulation cannot be accessed only when the machine is standing or tilted at a slight angle, or is lying on the EXTRA side of the compressor. Why on the discharge side? Well, because on the discharge side, the conduit does not come out of the tank but from the compressor head and therefore the oil cannot spill out. If someone does not agree with it, let them cut up any unit in the refrigerator and see how it is built and when, if necessary, oil may come out. It is possible only on the suction side, therefore manufacturers do not recommend tilting the refrigerators more than 45 degrees because they assume that the normal user does not know where the suction side is and where the discharge side is.
    greet
    volume
  • #29 564019
  • #30 564036
    andy076
    Help: 7
    Rate: 22
    of course, you can lie down in the position only after transporting the production, they say that it should stand for about 20-24 hours in a vertical position before turning on the unit
Transporting refrigerators is generally advised to be done in an upright position to prevent potential damage to the compressor and internal components. While some users report success in transporting refrigerators lying down, it is crucial to ensure that the unit is placed on the correct side (preferably the side of the compressor) to avoid oil flowing into the pipes, which can lead to compressor damage. If transported lying down, it is recommended to wait at least 12 to 24 hours before turning the refrigerator on to allow the oil to settle back into the compressor. A tilt of up to 45 degrees is considered acceptable, but exceeding this angle increases the risk of damage. Users emphasize the importance of following manufacturer guidelines and being cautious to prevent issues such as broken valves or compressor failure.
TL;DR: 30 % of warranty compressor failures stem from improper fridge transport (AHAM, 2021). "Oil, not refrigerant, is what destroys compressors when moved flat" [Elektroda, ^ToM^, post #564009] Always keep a fridge upright or ≤45° tilt and let it rest 4–24 h before plugging in.
Why it matters: Correct handling avoids costly compressor damage and food-safety downtime for homeowners, movers, and appliance techs.
• Safe tilt limit: ≤45° during loading or unloading [Elektroda, ZAHYR, post #386631] • Recommended rest time after flat ride: 4–24 h; median user advice 12 h [Elektroda, XAX, post #418647] • Compressor replacement cost: Approx. US$200–400 including labor [HomeAdvisor, 2023]. • 30 % of refrigerator warranty claims cite transport-related compressor failure [AHAM, 2021]. • Absorption (RV/portable) fridges must stay upright; oil-free system can leak coolant when tilted [Elektroda, jozefg, post #419410]
Can I lay my refrigerator down in a van or truck?
Only if upright transport is impossible. Keep tilt ≤45° or place it flat on the compressor’s discharge-side (usually door hinge side) to prevent oil flooding [Elektroda, ^ToM^, post #564009]
Why is horizontal transport risky for compressor fridges?
Oil drains from the compressor into thin capillary tubes, blocking flow and straining valves. XAX notes broken suspension springs and valves after side transport [Elektroda, XAX, post #419469]
If I have to lay it flat, which side should face the floor?
Lay it on the side where the smaller tube exits the compressor top—the discharge side—so oil stays inside the shell [Elektroda, ^ToM^, post #564009]
How long should I wait before switching it on after a flat move?
User experience ranges from 2 h to 24 h. A safe rule is 12 h rest upright; 24 h for older units [Elektroda, GRZECHO 1, post #427581]
Do absorption refrigerators follow the same rules?
No. Absorption fridges lack a sealed oil system and must remain upright or coolant can shift, stopping circulation [Elektroda, jozefg, post #419410]
What happens if I skip the resting period?
Cold oil slugging the compressor may seize pistons within seconds, leading to a US$200–400 replacement bill [HomeAdvisor, 2023].
Can refrigerant (Freon/Isobutane) leak when the fridge is laid down?
Leakage is rare; sealed solder joints hold pressure. Damage risk comes from oil, not gas [Elektroda, jarek.agd, post #419408]
Quick 3-step emergency flat-transport guide
  1. Power off, defrost, and dry interior.
  2. Lay fridge on discharge-side; pad corners.
  3. At destination, set upright and wait 12 h before plugging in.
Do brands like Amica, Bosch, or LG list special transport rules?
Amica tags recommend 1 h rest after flat shipping [Elektroda, Krzysi0, post #386582] Bosch and LG follow the general ≤45°/12 h guideline in their user manuals [Bosch, 2022].
Edge case: What if the fridge was tilted more than 45° for minutes?
Let it stand upright 24 h. If unusual noises occur on start-up, disconnect immediately; valve damage may have occurred [Elektroda, XAX, post #418647]
