Transport Refrigerator Horizontally: Safely Determine Best Side for Laying Down
Keda_R 50544 17
Which side should I lay a refrigerator on when transporting it horizontally?
If your refrigerator has two compressors, the thread says the exact side is much less important, but if you must lay it down, keep the discharge/pressure side on top; in the photo discussed, that was the left side [#15189950][#15190946] If possible, transport it upright instead. After horizontal transport, leave it standing upright before switching it on so the oil can flow back into the compressor [#15188159][#15190222] The minimum wait mentioned was 12 hours, and 24 hours was suggested as the safer choice [#15188159][#15190222]
  • #1 15188140
    Keda_R
    Rate: 12
    I need to transport the refrigerator lying down, I wanted to ask for help in determining which side I should transport it on. Thank you in advance for your answer.
    stanley*
    Help: 5
    Rate: 8
    Hello, the most important thing is that after transport, it should stand upright for 12 hours so that the oil flows into the compressor.
  • #3 15188476
    m fox
    Help: 92
    Rate: 235
    Ideally on the side and so that the door does not open during transport. Hinge up and handle down.
    Then he has to stand out, as his colleague wrote earlier
  • #4 15188485
    karolark
    Help: 701
    Rate: 2486
    The door can be taped with the rest as much as possible :-)
  • #5 15189918
    Keda_R
    Rate: 12
    Thank you for your answer.
    I read on the forum and from the information I was able to find it is quite important on which side the refrigerator is transported. However, according to these guidelines, I cannot determine which side this refrigerator should be on, because all the examples I found referred to refrigerators with one compressor. Surely it doesn't matter which side I put her on?
  • #6 15189950
    m fox
    Help: 92
    Rate: 235
    Physically, the refrigerator, if it has to, should lie on the side on which the compressor is. In your case you have 2, so if it's horizontal, it doesn't matter.
    As Stanley wrote *, he has to come off after such transport.
    Added after 26 [minutes]:
    maybe this article will help you, but with 2 aggregates it is either vertical or no difference which side.
    http://www.przeprzałkikatowice-24h.pl/transport-agd/
  • #7 15190099
    Keda_R
    Rate: 12
    I read this article and it seemed to me that according to this description, the refrigerator should be with the compressor discharge side facing up. I do not know anything about it, but by the method of deduction, looking at the photo, it seems to me that the discharge side of both compressors is on the left, i.e. the refrigerator should be on the right. I wanted to make sure, but since you write that it is all one thing, the problem is gone.
    m fox
    Help: 92
    Rate: 235
    The discharge side if the genset is in the center, otherwise on the side with the genset.
    This is my suggestion and I stick to it always.
    With 2 aggregates, one will always be on top and gravity will do its job. That's why the fridge must stand out afterwards, some say 8h, others 12 or 24.
    It also depends on how long the refrigerator was in a horizontal position, the longer the better, then it should stand upright.
    12h is the minimum in my opinion, after 8h I would not turn it on.
  • #9 15190341
    Keda_R
    Rate: 12
    Thanks for all the info. I even leave it for 24 hours, I am in no hurry, I prefer to wait rather than look for a new one.
  • #10 15190377
  • #11 15190433
    Keda_R
    Rate: 12
    This is already lost. This article shows that the refrigerator should be transported with this cut tube. down. At least that's what the description of the photos shows. agdhandel are you not wrong with the left side?
  • #13 15190531
    Keda_R
    Rate: 12
    He is good :)
  • #14 15190658
    nares
    Home appliances specialist
    Help: 1515
    Rate: 3381
    The basic rule is the pressure part on the top, i.e. we transport it on the left side, relative to the photo. After such transport, the refrigerator can be turned on even after 1 hour.
  • #16 15193543
    Keda_R
    Rate: 12
    I have one more question, if I had to transport a refrigerator someday. How to distinguish the discharge side from the suction side? Because in this article http://www.przeprzałki-lodz.pl/porady/transport-lodowki-zamrazarki/ there are photos from the forum and they show that the refrigerator should lie on the side of this cut and blind tube. My fridge should be on the left side and the blind tubes are on the right, which means that the method in the article does not work.
  • #17 15193560
  • #18 15193592
    Keda_R
    Rate: 12
    Approx. I will do as you advise. Thanks for the help. greetings
✨ Transporting a refrigerator horizontally requires careful consideration of which side to lay it on, particularly regarding the compressor's position. It is generally advised to transport the refrigerator on the side where the compressor is located, ensuring that the discharge side is facing up if applicable. After transport, the refrigerator should remain upright for a minimum of 12 hours to allow the oil to flow back into the compressor. For refrigerators with two compressors, the orientation may be less critical, but it is still recommended to follow guidelines to avoid potential damage. Users also discussed methods to secure the door during transport and the importance of identifying the discharge and suction sides of the compressor.
