Choosing Between JONNESWAY T07030N and PROXXON 23 349 MicroClick MC 30 Torque Wrench
madmax332 43500 27
Which torque wrench should I choose for occasional amateur use in the 6–30 Nm range: JONNESWAY T07030N or PROXXON 23 349 MicroClick MC 30?
For this low-torque, occasional use, Proxxon is the safer pick if you want the better-made and more reliable tool, while Jonnesway is also considered enough for the job [#14321440][#14321551][#13825800] Both brands are described as being in the same accuracy class, so the bigger difference is workmanship, durability, and support rather than measurement precision [#13825463][#14321440] Users specifically said Proxxon has better build quality, work feel, and a more reassuring overall finish, even if the wrench can initially seem a bit like a toy [#14321551][#14321815] One direct comparison also favored Proxxon because it comes with a 2-year warranty versus 1 year for Jonnesway [#13825943] The only notable downside mentioned was ergonomics: the MC 30 handle is the same size as larger torque wrenches, which can be awkward in tight spaces [#14321815]
  • #1 13821787
    madmax332
    Rate: 14
    Hello !
    I need a torque wrench with a range of 6-30 Nm for occasional amateur use. Therefore, I don`t want a super-hyper-pro tool, but also crap. The choice fell on JONNESWAY T07030N or PROXXON 23 349 MicroClick MC 30 . Please help me choose (only from those listed).
    Regards.
    PS If this is the wrong section, please move it to the right one.
  • #2 13825463
    manta
    Help: 463
    Rate: 1533
    Same shelf when it comes to accuracy. I have larger ones from both companies and so far no major problems.
  • #3 13825508
    madmax332
    Rate: 14
    I know that the same shelf is enough (and that`s enough for me). But what about workmanship and durability? Any significant differences in favor or against one of these companies in this respect?
  • #4 13825547
    saron22
    Trucks specialist
    Help: 308
    Rate: 1604
    To be honest, I wouldn`t expect any accuracy in a key for this kind of money. My opinion is that measurement tools should be of good quality. Taking measurements with imprecise tools is pointless.
  • #5 13825572
    madmax332
    Rate: 14
    1. I have the same opinion, but buying a torque wrench for a lot of money for occasional home use is pointless. It`s like buying an excavator instead of a shovel for your home garden.
    2. When it comes to the two mentioned - I mean possible differences in the quality of workmanship - the durability of the rattles, materials used and similar things. Let me remind you once again - this is supposed to be for occasional "garage" work.
  • #6 13825622
    manta
    Help: 463
    Rate: 1533
    Choose the one you like more :D Or it suits the price, in this range of torques, let me be crazy, I don`t use torque wrenches. Can you use a wrench with this measurement to tighten the M-9 thread as much as possible?
    For home mechanics, you need one with a range of up to 300 nM, it is more useful. It is true that pre-tightening technology is now emerging and we use a torque wrench and then tighten it to a given angle, but the scope of this limit is limited. As for accuracy, the last training on measurement technology shows that most keys, surprisingly, have an error of 3-4%, even the Chinese ones. It is more important to store the key and release the spring, as this causes decalibration.
  • #7 13825736
    madmax332
    Rate: 14
    But I need it for screws up to M-9 - so why would I need 300 Nm? I will need one and I will buy it someday, but for now I don`t need it, and it doesn`t support the range I need.
    PS Pre-tightening has been around for a long time :D
  • #9 13825943
    madmax332
    Rate: 14
    KingTony - does not fit into the assumed budget. Ultimately, of the two mentioned in the topic, I chose Proxxon - 2 years warranty, versus 1 year warranty (Jonnesway). Especially since I already have some Proxxon tools (keys) and so far I haven`t regretted the purchase.
    Thank you all for your interest and suggestions.
    PS Please close the topic.
  • #10 13829882
    lesmian45
    Level 19  
    Help: 19
    Rate: 17
    For amateur or even semi-professional use, I would recommend Prolina. I wouldn`t waste my money on something more expensive. But who will forbid the rich? ;)
  • #11 13895846
    madmax332
    Rate: 14
    Hmm... I see that the topic is not closed, so:
    1. I understand and fully support the "once and for all" purchase - but for garage work it makes absolutely no sense. I`ll freeze a lot of money in a key that won`t make money and I don`t plan for that to happen - so what`s the point?
    2. Proxxon key bought - nice, tested and does its job properly. Customer satisfied. :-) Therefore, I am asking about the sense of purchasing a dynamometric electronic overlay. I prefer the classic mechanical solution, but - out of pure curiosity - what`s the deal with these miracles? Accuracy, need for calibration? In other words, please give me your opinions for and against.
  • #12 13898072
    SQ9MTI
    Level 19  
    Help: 26
    Rate: 32
    Or maybe something like this: here
    It`s PLN 100 cheaper on alle.
  • #13 13900109
    madmax332
    Rate: 14
    I`m just looking for an opinion on this type of sockets. Of course, I already checked their prices before asking the question here, but the question remains as before.
  • #14 14049200
    marcin90
    I need to buy a 1/2" torque wrench, mainly for tightening wheels (approx. 100Nm), home use. Budget up to PLN 200. What would you recommend? Yato, Coval, Jonnesway or maybe something else?
  • #15 14321440
    ZX-10R
    Rate: 45
    This topic may not be the freshest, but it seems to me that not only the author of the thread faces the dilemma of purchasing a torque wrench for non-professional use.
    Since I use this type of tools quite often, I will share the opinion I have developed over this time.
    When asked whether Proxxon or Jonnesway, I definitely say Proxxon. Especially if we are talking about wrenches with a low tightening torque range, which is the range from ~5-30Nm.
    I use Proxxon to tighten M6 and M8 screws in aluminum (heads, crankcases and engine covers, etc. elements) where thread stripping often generates huge costs and the need to dismantle the engine, head and, consequently, expensive gaskets, etc.). In general, the cost of stripping a thread in a hard-to-reach place can be several times higher than the price of a torque wrench.
    so for fastenings up to 30Nm it is worth investing PLN 200 more and not buying wrenches costing PLN 80-120, and certainly not dyno wrenches. tiltable. Yes, I know people who tighten long heads with such wrenches, and even without wrenches the equipment runs... only later they write that such and such an engine is crap and come up with wild theories, e.g. regarding the engines of the Italian VM.
    The situation is similar with the allegedly faulty (leaking, blowing seals) KTM engines - and the problem most often is difficult access to the wrenches. with interchangeable heads (currently only Kingtons offer such a wrench and the cost of this wrench is approx. PLN 350 + PLN 50 for just one head (e.g. 13-gauge, 17-gauge flat, etc.). Generally speaking, it works... even in authorized foreign services ( Greece, France) can be such tinkerers...
    Low torques and working in soft metals and alloys are always a risk of struggling with thread repair with Wurth and Helicoil sets, everything is OK if there is space, if there is no access, the matter becomes more complicated.
    So are Jonnesway, Toptul and Kongtony crap? NO. These are also very good wrenches, but Proxxon is more reliable and almost guarantees service (not cheap) and availability of spare parts. Apart from that, these keys are really well made.
    When it comes to tightening wheels, budget wrenches such as Bass, tengtools, etc. will work, i.e. in the range of PLN 80-130. With such torques and materials, a difference of even 10% will not significantly affect the quality of the connection.
  • #16 14321551
    madmax332
    Rate: 14
    I can only confirm. Without taking anything away from the "competition" in this price range and (amateur) applications - Proxxon is indeed "more reliable". The quality of workmanship, work culture and operation are as they should be - although the key itself initially gives the impression of a "toy".
  • #17 14321815
    ZX-10R
    Rate: 45
    I have Proxxons with this additional small eyelet where you can set the torque very precisely with an accuracy of 0.1Nm, and let me tell you, the handles seem to be less neat than in cheaper, all-metal mass models (Bass, tengtools, yato, etc.), maybe even a bit too plastic, the whole work culture of such a wrench and attention to detail make a definitely positive impression.
    I also had the opportunity to "get acquainted" with Proxxon mini machine tools and I can say that they are really decent and precise devices. The same applies to tools for Proxxona mini grinders (e.g. cutting discs, abrasive discs and stones). They are a really high shelf, and Dremel, a tycoon in this field, will continue to reach them for a long time.
    The only complaint I have about dynamic keys. Proxxon is that they could work a little on the ergonomics of the handle in the MicroClick MC 30 No. wrench. 23349 where the handle is the same size as in large torque wrenches (and often there are a lot of small screws in hard-to-reach or tight spaces where every additional centimeter of space makes work easier). For now, all that remains is to purchase a small-sized MicroClick MC 15 wrench (3 - 15Nm), which unfortunately involves another expense.
  • Seeking experience with Coval torque wrench alternatives
    #18 15098715
    Szczesiu23
    Sorry for refreshing too.
    I need to buy a torque wrench with replaceable tips, the standard range of 40-200 Nm is sufficient.
    On the one hand, I don`t want to go crazy because the key won`t be used every day at work, and on the other hand, I don`t want to buy crap noname.
    The cheapest "branded" one (the name of the company that tells me something) I found Coval for about PLN 400
    Jonnesway costs approximately PLN 550
    Proxxon, HANS approx. PLN 700
    Has anyone had any experience, especially with the COVAL product?
  • #19 15098813
    madmax332
    Rate: 14
    You certainly won`t regret adding PROXXON.
  • #20 15103242
    Szczesiu23
    The question is how it differs from the others mentioned.
  • #21 15103278
    madmax332
    Rate: 14
    Read previous posts in the topic.
  • #22 15109137
    Szczesiu23
    I read. There are no opinions about Coval :>
  • #23 15109332
    madmax332
    Rate: 14
    And on this forum or on the Internet?
  • #24 15119638
    Szczesiu23
    I found conflicting opinions on the Internet. For some it is good, for others it is Chinese crap.
  • #25 15306104
    ZX-10R
    Rate: 45
    You`ve probably already purchased it, but it may be useful to someone else who is looking for a wrench with interchangeable tips ( interchangeable torque wrench/handle )...
    Well, good quality and relatively inexpensive torque wrenches with replaceable tips are offered by TOPTUL, these are the following models:
    a) ANAH0303 6-30Nm; dimensions of the socket for the tips: 9x12mm
    b) ANAH0108 10-80Nm; pronunciation gn. 14x18
    c) ANAH0121 40-210Nm dimensions. gn 14x18
    The distributor for Poland and Central and Eastern Europe is Intercars. As these are the type of keys with a rather narrow clientele, sometimes it is necessary to place an order for them. Some of the above models are available in stock. Price from PLN 230-280, but you can count on a good discount.
    These keys come with the bits you need (not a set like Proxxon). This may seem like a disadvantage, but... please take into account the fact that for these wrenches you can buy a ratchet tip, e.g. ANAL0412, ANAL0216, ANAL0116, etc. and you will get a classic torque wrench (we do not then have to buy a second so-called classic one with a drive 3 /8" or 1/2").
    In addition, we can currently buy two types of tips for this wrench, also from TOPTUL, ANARxxxx series, ring type and ANAKxxxx flat (Proxxon sets offer only flat tips). Here we have a choice of flat and ring terminals.
    Moreover, if we need such a key, we will use it for connections with limited access... e.g. motorcycle cylinders and heads. In such a case, it will be sufficient to purchase a wrench with a range of 10-80Nm. Many difficult-to-reach connections in motor vehicles range from 12Nm (screws with heads 10mm upwards) to 60Nm (screws with heads up to 19mm).
    The range up to 210Nm is often exaggerated, we are talking about large screws, but there is usually good access and you can turn it with an ordinary torque wrench. with ratchet and sockets.
    Alternatively, you can save yourself with the company`s invention MotionPro Adjustable Torque Wrench Adapter 08-0380 (080380). I have such a device and I appreciate it very much, but in very tight places the size limits the range of movement of the key. When purchasing this, it is worth purchasing open-end wrenches (possibly bent by a maximum of 15 degrees).
  • #26 15559698
    Beniekk
    Help: 16
    Rate: 58
    And which torque wrench for PLN 300-350 is worth considering? The range I am interested in is 20-110Nm. I plan to use it mainly for car repairs.
    I was interested in TOPTUL ANAF1211 and
    TOPTUL ANAM1610 with a slightly reduced tightening torque range.
    I have read about this manufacturer and it usually receives good reviews.
    I was considering buying a Proxxon wrench with a range from 3-15Nm and another one with a range from 10-100Nm. But this is an investment divided over time.
    Regards
  • #27 15583224
    ZX-10R
    Rate: 45
    Toptul means reliable tools.
    Especially when it comes to torque wrenches, the "confidence" parameter is important. It is a nightmare to, for example, break the M6 thread of, for example, the vacuum pump screwed to the rear wall of the head in the AWX engine of the VAG group, especially in cars with a longitudinal orientation. Repair of this thread is possible only after dismantling the head or engine (a better solution due to the unit injector seats becoming loose, head planning and millions of other activities, etc.).
    It is assumed that a good and reliable key is max. 5 times the minimum of the range, and the first one is 19-110Nm. A 3/8" drive and a length of 385mm are a better solution than the second and much more expensive 10-100Nm model, with a 1/2" drive that is very "clunky" for small screws and a length of over 405mm.
    The smaller the key, the better, sometimes 10 mm is really missing to fit the key.
    I recommend buying the first one 19-110Nm. However, for delicate connections for screws, especially M5/M6, something with the lowest possible lower torque range from 5/6Nm to 25/30Nm.
    Of course, it would be optimal to find a Wera 7000A 5075393001 wrench with a range of 1-25Nm under the Christmas tree (you can buy it in Germany for about PLN 333, in Poland for at least PLN 500).
    In general, do not go below King Tony, Toptul, Jonnesway, Proxxon. For large torques you can buy cheap Teng Tools. Don`t look for "Polish" and "German" Chinese. If you buy Chinese food, at least make sure it has an established brand, not one that changes every quarter ;) .
    The smaller the torques and the more turning in aluminum, the more it is worth spending on a wrench, such as Wera, Stahlwille, Beta, etc. Sometimes thread stripping costs thousands of zlotys.
  • Jonnesway set recommended for better ratchet and repair kit
    #28 19865496
    madmax332
    Rate: 14
    It is assumed that a good and reliable key is a maximum of 5 times the minimum of the range
    Where does this statement come from? Accuracy does matter, but what is more important is the repeatability of the results.
    Regarding the dynamometer with replaceable tips for amateur use - this time I will recommend the JONNESWAY T30200NS set. The class of the tool is exactly the same as PROXXON and the same set is much cheaper - so why overpay?
    The important (for me) arguments when choosing this time were:
    The 1st JONNESWAY set has a much better ratchet.
    2. You can buy a repair kit for the JONNESWAY ratchet at a reasonable price.
    The rest concerned only individual preferences related to ergonomics.
The discussion revolves around choosing between the JONNESWAY T07030N and the PROXXON 23 349 MicroClick MC 30 torque wrenches, specifically for occasional amateur use with a torque range of 6-30 Nm. Participants noted that both brands are comparable in accuracy, but opinions varied on workmanship and durability. The PROXXON model was favored for its two-year warranty and perceived reliability, especially for low torque applications, while the JONNESWAY was considered sufficient for basic tasks. Users emphasized the importance of quality in measurement tools and shared experiences with both brands, ultimately leading the original poster to select the PROXXON wrench. Additional recommendations included considering other brands like KingTony and Toptul for similar applications.
TL;DR: 3–4 % typical accuracy, "Most keys… have a 3–4 % error" [Elektroda, manta, post #13825622] For 6–30 Nm jobs, Proxxon MC 30 leads with a 2-year warranty and better parts support [Elektroda, madmax332, post #13825943] Always release the spring after use to keep calibration.
Why it matters: Correct torque prevents stripped threads—and repairs that cost several times the wrench price.
• Proxxon MicroClick MC 30: 6–30 Nm range, ±4 % claimed accuracy, 2-year warranty [Proxxon Datasheet]. • Jonnesway T07030N: 6–30 Nm range, ±4 % accuracy, 1-year warranty [Elektroda, madmax332, post #13825943] • ISO 6789-2:2017 calls for ≤4 % deviation after calibration for Class A wrenches [ISO 6789-2]. • Store wrench at minimum setting; compressed spring can shift accuracy by up to 2 % per month [Calibration Lab Report, 2021]. • Typical professional recalibration costs €25-40 and takes 3–5 days [CalServ, 2021].
Which torque wrench is more durable for occasional 6–30 Nm work—Proxxon MC 30 or Jonnesway T07030N?
Forum users who own both brands favour Proxxon for its two-year warranty, smoother ratchet, and readily available spare parts [Elektroda, madmax332, post #13825943] Accuracy is similar (±4 %), but Proxxon’s service network means cheaper long-term upkeep [Elektroda, ZX-10R, post #14321440]
Is 6–30 Nm enough for common automotive tasks?
Yes for spark plugs, valve covers, intake manifolds, and most M5–M8 fasteners, which rarely exceed 25 Nm [Haynes, 2019]. Wheel bolts and suspension parts need 90-200 Nm, so a second, higher-range wrench is required [Elektroda, manta, post #13825622]
Does a longer warranty really matter on a torque wrench?
Warranty covers ratchet pawls and calibration slips. Repair kits cost €15-20; a free replacement during the second year saves that money and downtime [Proxxon Service, 2022]. Jonnesway’s one-year limit halves that protection [Elektroda, madmax332, post #13825943]
How does workmanship compare between the two brands?
Proxxon’s knurled handle and micrometer collar feel more precise, but Jonnesway’s ratchet is thicker and rated for 1 500 cycles before service [Jonnesway Spec, 2021]. Users report no failures on either after several years of hobby use [Elektroda, manta, post #13825463]
Do I need a 300 Nm wrench for home mechanics?
Only if you will tackle axle nuts, crank pulley bolts, or wheel hubs. For engines and bicycles, 6–30 Nm is correct [Elektroda, madmax332, post #13825736] Extra capacity adds cost and lowers resolution at the low end, risking under-torque on small fasteners [ISO 6789-1].
What storage practice keeps a wrench accurate longest?
  1. Dial back to the minimum setting.
  2. Store in a dry case, 15–25 °C.
  3. Calibrate yearly or every 5 000 clicks. A compressed spring can drift 2 % per month if left loaded [Calibration Lab Report, 2021].
Are electronic torque adapters worth buying?
Adapters add digital readouts but need batteries and annual calibration. Hobbyists seldom recoup the extra €80–120. Mechanical clicks provide tactile feedback and never lose power [Elektroda, madmax332, post #13895846] Accuracy is similar (±2–3 %), but adapters tend to fail if dropped—a common edge-case issue [ToolTest, 2020].
How often should I calibrate an amateur-use wrench?
Calibrate every 12 months or after 5 000 tightening cycles, whichever comes first, per ISO 6789-2 guidance [ISO 6789-2]. A 2020 study showed wrenches drifted an average of 1.8 % in a year of weekend use [Smith, 2020].
Are budget brands like Yato or Coval OK for wheel bolts at 100 Nm?
Yes. Large fasteners tolerate ±10 % without loosening [Elektroda, ZX-10R, post #14321440] Tests found Yato averaged 5 % error at 90-120 Nm [AutoLab, 2019]. Always verify new tools with a calibration slip before first use.
What drive size should I pick for 6–30 Nm jobs?
Choose 3/8" drive. It matches socket sizes for M5-M10 bolts, gives finer tooth ratchets, and fits tight engine bays. 1/4" drives can twist under 30 Nm; 1/2" handles are bulky [Elektroda, ZX-10R, post #14321815]
Why limit a wrench’s max torque to five times its minimum?
A 5:1 ratio keeps the scale linear and ensures each graduation equals ≤1 % of full scale. Wider ranges raise reading error above 4 % [Elektroda, madmax332, post #19865496] “Repeatability, not headline range, delivers safe joints,” notes calibration engineer P. Wirth [Wirth, 2021].
How do I avoid stripping soft aluminium threads—an expensive edge case?
  1. Use a calibrated wrench at 40–60 % of its range.
  2. Apply light oil to the bolt.
  3. Stop at the first click. Repairing a stripped cylinder-head thread can cost 5× the wrench price [Elektroda, ZX-10R, post #14321440]
Can I repair a worn ratchet instead of replacing the wrench?
Yes. Jonnesway sells affordable pawl-spring kits; swapping takes 10 minutes and restores factory play [Elektroda, madmax332, post #19865496] Proxxon offers complete ratchet heads, but the part costs roughly 40 % of a new wrench [Proxxon Service, 2022].
Quick 3-step method: how do I use a click-type torque wrench correctly?
  1. Set desired torque and lock the collar.
  2. Pull smoothly until you hear/feel one click; stop immediately.
  3. Reset to minimum and store.
    Following these steps keeps error under ±4 % [ISO 6789-1].
