Comparing Open-End Wrenches: MODECO 8pcs (6-22mm) vs NITEO TOOLS Ratchet Wrenches
pierotez 22479 28
Are NITEO TOOLS ratcheting open-end wrenches likely to be as good as the MODECO 8-piece 6–22 mm set for occasional home use?
NITEO TOOLS is unlikely to offer a clear quality advantage over MODECO; one assessment classifies both as inexpensive Chinese tools that mainly differ by branding [#18742784] Another user reports that MODECO is a decent, durable budget brand comparable with Jonnesway and Kingtony, based on personal experience [#20599692] If you specifically want ratcheting wrenches, the thread recommends the SATA 09066 12-piece 8–19 mm set, or its smaller eight-piece version, although the latter omits 9, 11, 16 and 18 mm [#18746181] Proxxon ratcheting sets were also recommended for their good quality and relatively thin construction, which helps in confined spaces [#18757673] For higher-end tools, the suggested progression was Jonnesway, Kingtony and Facom, with quality increasing in that order [#18742784]
  • #1 18742756
    pierotez
    Rate: 85
    I have and use at home from time to time Flat wrenches cpl. 8pcs.(6-22mm) MODECO
    I once bought a small set of socket wrenches with a ratchet handle at Ladybug and they worked fine.
    Now not long ago I saw a cool-looking Flat-end wrenches with ratchet from NITEO TOOLS . Unfortunately only 8-19 but always something. I thought it was possible to have something convenient (ratchet) in the box.
    What do you think this type of wrench will not be worse than the aforementioned Modeco?
    Grzegorz_madera
    Help: 268
    Rate: 1736
    The ones you have listed are the cheapest Chinese products differing by name. They are all the same. If you want something good then Jonnesway, Kingtons, Facom. Their quality increases in the order I listed them.
  • #3 18742829
    pierotez
    Rate: 85
    O K.. Link! Well yes, you pay for quality. I will look behind Jonnesway on Alle ;) .
    Danielos898
    Help: 12
    Rate: 34
    If you want a full set of 6-32 then I recommend the Sata brand. Such a set costs raptly about 270zł. And you have super wrenches for ever.
  • #5 18745790
    pierotez
    Rate: 85
    With the fact that I do not see with ratchet only without.
    Danielos898
    Help: 12
    Rate: 34
    pierotez wrote:
    With that I don't see with a ratchet but without.
    Ahh, you wanted with a ratchet. Sorry.
    In that case, too, Sata, for about PLN200 there is a set of 12 pieces, 8-19. There is also a smaller set of 8 pieces for about PLN150, they drop out wrenches like 9, 11, 16 and 18. Note that the ratchet is on both sides of the wrench. Something along the lines of the Wera Joker.
  • #7 18754204
    pierotez
    Rate: 85
    Danielos you suggest some store so that you do not get nicked for fakes?
    Danielos898 wrote:
    There is also Sata, for about 200zl there is a set of 12 pieces, 8-19. There is also a smaller set of 8 pieces for about 150zl, fall off in it such wrenches as 9, 11, 16 and 18. Note that the ratchet is on both sides of the wrench. Something like the Wera Joker.
    Your suggestions are OK. Still on Jonnesway website I found a set of 6mm - 2*/ or maybe 3*mm but I don't see it in stores.
    For this set of Sata 8 - 19 mm I could match 6 - 8mm JONNESWAY , I don't see 6 - 7 mm. Or Facom 6mm
    Ed.
    Recently I've been doing some of this action and got screwed over with the eyelet that hey :)
    In the slide at the 6mm bar (I was using 6 and 8mm now) the nut was 10mm and so it turns out that 6mm and her may not be necessary for me. ;)
    Comparing Open-End Wrenches: MODECO 8pcs (6-22mm) vs NITEO TOOLS Ratchet Wrenches .
  • #8 18757673
    paluszasty
    Help: 56
    Rate: 268
    I would still recommend Proxxon wrenches:
    https://swiatnarzedzi.pl/pl/p/Klucze-plasko-oczkowe-PROXXON-kpl.-15szt-6-21mm-prk-23821/328
    I have had them for a long time and am satisfied.
    Better than Facom, Beta, Bahco, Gedore etc and quite good quality.
    They also have the advantage of being a little thinner than others so sometimes it's easier to put them in tight places.
    Added after 1 [minute]:
    Version with ratchet:
    https://swiatnarzedzi.pl/pl/p/Klucze-plasko-o...MImMSy_uD_6QIVhqwYCh1alQZgEAQYASABEgJWdPD_BwE
    By the way, isn't it better to use spacers instead of the rod combination?
  • #9 19046034
    pierotez
    Rate: 85
    Listen great this set of Sata! At least so far there are no signs of wear.
    Recommend still a ratchet with sockets and a small puller for such as car wipers. At one time I would have simply bought a Yato but..., well that's just it.
  • #10 19046094
    Danielos898
    Help: 12
    Rate: 34
    I'm glad you took my recommendation and are satisfied.
    Do you want a 1/2 or 1/4 ratchet? Or both complete with sockets and bits? Any budget
    With the extractor I can not help, I have no knowledge in this subject.
  • #11 19050870
    pierotez
    Rate: 85
    Danielos898 wrote:
    The ratchet do you want 1/2 or 1/4? Or both complete with sockets and bits? Any budget
    Hmm, I mostly turn wrenches 10-20mm - so 1/4?
    With bits? Probably yes. Bits as such I do not have except for a small set from Biedra for a dozen zeta.
    From more affordable I saw Honiton, possibly Jonnesway , Sata.
    Danielos898
    Help: 12
    Rate: 34
    pierotez wrote:
    Hmm, I mostly shoot with 10-20mm wrenches - so 1/4?
    No no, 1/4 is so up to 13, 14mm are standard. 3/8 will be so universal in these sizes but I would go for a set with two ratchets, 1/4 and 1/2. All the brands you mentioned are ok. I have honitons, 94 el. set, priced around 230-250zl.
  • #13 19053305
    pierotez
    Rate: 85
    Ok that's what I will do. I already gave a price inquiry to a friendly store.
    Hmmm, may take by the way these flat ones with ratchet only Sata 12 / 8-19 I see ratchets only on one side and not on two. Could you provide a link?
  • #14 19053477
    Danielos898
    Help: 12
    Rate: 34
    I thought you already had them. Sata model 09066. if you don't know how it works see on youtube by typing this model.
  • #15 19053602
    pierotez
    Rate: 85
    Cool I already bought the 6-32 flat-eye sats without the ratchet.
    Now I'll take this Honiton set and maybe those flat-eye sats with ratchet what you recommend ;) .
  • #16 19054180
    Danielos898
    Help: 12
    Rate: 34
    Oh. Ok. Because I first recommended the classic and then with a ratchet. I did not know which you bought.
    Generally you will be happy with these tools.
  • #18 19060826
    misiek1111
    Level 37  
    Help: 325
    Rate: 1098
    Both brands are similar b. good quality.
    I like stainless steel keys better, but colored ones are easier to recognize in the clutter.
  • #19 19061729
    Danielos898
    Help: 12
    Rate: 34
    As for my opinion is as above. Quality similar and at a high level. Choose by looking at the appearance and price.
  • #20 19095748
    pierotez
    Rate: 85
    misiek1111 wrote:
    in stainless,
    Hmm, I took the blackened ones and not the chrome ones. 50 dich :) . I hope they won't rust quickly.
  • #21 19095774
    misiek1111
    Level 37  
    Help: 325
    Rate: 1098
    I was reminded, Wiha is already counterfeit, also be vigilant.
  • #22 19095788
    pierotez
    Rate: 85
    Store stationary and not some portal so I hope it will be OK 🙄
    Sat with a ratchet unfortunately do not have and so I will buy elsewhere - do you have a link to something proven?
  • #23 20585448
    xbajt
    Rate: 42
    Hi. What wrenches do you recommend for home use? Do you hit NEO or is it not worth it?
  • #24 20585517
    nspd
    I use Yato, neo and Proline. The fact that for "garage" work. The only thing that "managed" to destroy was a torx from neo precisely, but rather through my fault it happened. For home work it is definitely enough shelf https://buythis.pl/klucze-plasko-oczkowe-2/ Sometimes it is better not to buy the whole set but just individually.
  • #25 20585678
    misiek1111
    Level 37  
    Help: 325
    Rate: 1098
    This is also cool. 4-in-1 ratcheting ring wrench 10x13 + 17x19 mm
    In one wrench are popular four sizes and have a direction switch:
    4-in-1 ratchet ring spanner with price and function description. .
  • Modeco recommended as decent Chinese quality
    #26 20599692
    ^ToM^
    Help: 495
    Rate: 2939
    Grzegorz_madera wrote:
    The ones you listed are the cheapest Chinese products differing by name. They are all the same. If you want something good it's Jonnesway, Kingtons, Facom. Their quality increases in the order I listed them.
    I disagree. It is the same Chinese as Jonnesway, Kingtony.
    Modeco is Chinese more than decent quality but at a good price.
    When I buy Chinese goods, I usually start just by checking for one from Modeco. A proven brand and I can recommend from personal experience. It certainly does not differ in any way from Jonnesway, Kingtona. Although in my opinion Modeco is even more armored in performance.
  • Recommend torx socket bits for Honiton set
    #27 21232468
    pierotez
    Rate: 85
    Danielos898 wrote:
    pierotez wrote:
    Hmm, I mostly shoot with 10-20mm spanners - so 1/4?
    No no, 1/4 is so up to 13, 14mm are standard. 3/8 will be so universal in these sizes but I would choose a set with two ratchets, 1/4 and 1/2. All the brands you mentioned are ok. I have honitons, set of 94 el., price about 230-250zł.
    We were replacing the lid gasket on the Corsa today and found that the above Honiton 1/4, 1,2 set has everything, just not the female torx.
    Recommend torx socket bits for the above kit.
    Ed, supposedly the universal 1/4" HONIDRIVER ones are too weak.
  • #28 21233844
    Danielos898
    Help: 12
    Rate: 34
    pierotez wrote:
    We were replacing the roof lid gasket on the Corsa today and found that the above Honiton 1/4, 1,2 kit has everything, just not the female torx.
    Yes, the 94el kit does not have torx bits. The larger one already has.
    I bought the e-torxes from Honiton as well. Specifically the Honiton H2202 set.
  • 4-in-1 ratchet ring spanner recommendation
    #29 21234576
    romarcin
    Help: 34
    Rate: 82
    misiek1111 wrote:
    This is also cool. 4-in-1 ratchet ring spanner 10x13 + 17x19 mm
    There are the popular four sizes in one spanner and it has a directional switch:
    You can buy similar ones for "pennies" at Action https://www.action.com/pl-pl/p/3016586/zestaw-kluczy-grzechotkowych-werckmann/
    I bought because externally ("organoleptically") they are surprisingly neatly made, no sharp edges, no lint, nice satin finish.
    Of course, it's not clear how the durability is, but "on the other hand" for this money...?
The discussion centers around comparing MODECO's 8-piece flat wrenches (6-22mm) with NITEO TOOLS ratchet wrenches (8-19mm). Users express concerns about the quality of these tools, suggesting that many brands, including MODECO, are similar in quality and often manufactured in China. Recommendations for higher-quality alternatives include Jonnesway, Sata, Proxxon, and Facom, with specific mentions of Sata's ratchet sets and Proxxon's thin wrenches for tight spaces. Users also discuss the importance of having ratchet functionality and express satisfaction with various brands based on personal experience. The conversation highlights the need for reliable tools for home use and the potential pitfalls of counterfeit products.
