[Solved] Best Torque Wrench/Adapter for Spark Plugs: YATO Key, Honiton Adapter, or Vorel Key? (90 chars)
LightOfWinter 25815 16
Should I buy a torque wrench or adapter for changing spark plugs, and what torque range is appropriate for this job?
For spark plugs, choose a proper torque wrench in a range centered on the required torque rather than a broad adapter; a 5-50 Nm or 10-60 Nm wrench is more sensible than 19-110 Nm or 20-200 Nm because accuracy is best in the middle of the scale and falls toward the ends [#16981973][#16982364] The thread notes that spark plugs are often tightened around 23-30 Nm, so a wrench whose working range puts that value near the middle is the better choice [#16982198][#16982370] A factory calibration certificate helps, and one Vorel manual states 4% factory calibration accuracy, but the more important issue is selecting the right range for the intended torque [#16987695] For spark plugs, several replies also recommend tightening by the manufacturer’s angle/spec or by hand with care, because actual torque changes with thread condition, dirt, and grease [#16982364][#16982525] In practice, the best answer from the thread is: buy a reasonably accurate torque wrench in the correct lower range, not a wide-range adapter [#16982364][#16987695]
  • Comparing torque wrench and adapter for spark plugs
    #1 16970898
    LightOfWinter
    Help: 369
    Rate: 935
    I'm trying to exchange spark plugs in my car.
    Therefore, as well as for other future repairs, I want to buy a torque wrench or adapter.
    Question what?
    I found such offers:
    yato-key-dynamometer 19-110Nm
    or
    honiton-dynamometer adapter 20-200Nm
    Here I found the specification of the tightening torques of spark plugs:
    spark plugs - tightening torques
    The question is is it better to choose a key or adapter?
    The key seems more handy, while the adapter is more universal and accurate. For home applications, the calibration problem is also lost in the case of the adapter.
    Alternatively, I could consider the clue key
    Vorel-torque-wrench
    The only question is whether the accuracy of this invention is sufficient.
  • #2 16970920
    DriverMSG
    Help: 3984
    Rate: 4883
    A good torque wrench costs several thousand zlotys. so the above mentioned ones are rather toys for an amateur.
    Their accuracy (lack of it) is actually only suitable for such things as wheels or candles, though those who do not use them too much.
  • #3 16981753
    LightOfWinter
    Help: 369
    Rate: 935
    It is obvious that there are better and more expensive keys.
    Amateur use precludes spending more money on this tool.
    It's about getting a decent quality at an affordable price - here about PLN 200.
    I think that in this price range should go to choose a tool suitable for such works.
  • #4 16981800
    grzeskk
    Help: 320
    Rate: 731
    I also had a similar problem, especially at small tightening times. I did the exact key basically. I bought an electronic fishing scales and made an appropriate length of arm and indication of the weight in kg I had in Nm. Cheap and accurate.
  • #5 16981973
    dizba
    Help: 239
    Rate: 808
    For spark plugs this is not the range. Look for a key in the range of 5-50 Nm.
  • #6 16982198
    LightOfWinter
    Help: 369
    Rate: 935
    Why not this range?
    In the link that I have been giving I write that the tightening torque of the candle I have 14mm for the aluminum head is 25 to 30Nm.
    So the key, for example, the 19-110Nm key covers it.
    I also read that Yato has a factory calibration certificate.
    YT-0750
    I am interested in this patent with fishing weight. Especially since I have such and often comes in handy.
  • #7 16982245
    grzeskk
    Help: 320
    Rate: 731
    For simplicity, 10N / kg can be taken. So, by applying a force of 1kg on 1m, we have 10Nm. Shortening the arm to 10cm we have at 1kg - 1Nm.
    ^ToM^
    Help: 495
    Rate: 2939
    Pay attention only to the fact that the highest accuracy of such a key is in the middle measurement range, i.e. for this key will be about 45 Nm. The closer to the end, on the one or the other side, the accuracy decreases. Therefore, it should be selected so that the scope of work is more or less in the middle of the range. Thus, in fact, a 50 Nm key may be more sensible. Nevertheless, tightening the bolts in the car is not a pharmacy and the accuracy of 20-30% does not change anything, because this is also the measurement error resulting from the state of the threaded joints themselves. Please note that the moment is given for clean new and uncoated threads. As you tighten the screw with a torque of, for example, 30 Nm and the screw will be clean you will get a different voltage than if the screw is dirty or it will have a thread covered with grease.
    Spark plugs I personally tighten it with my hand based on the rotation angle with the key given by the manufacturer. In my opinion it is more accurate to obtain the necessary screw tension than by measuring the torque. Well, but this is my opinion and everyone can have different.
    Greetings!
  • #9 16982370
    tadkli9743
    Help: 70
    Rate: 280
    Welcome.
    Check the documentation of the tightness of the car manufacturer.
    I have a Mitsubishi Colt and the candles are tightened with a force of 25 +/- 5 Nm.
    • AK604537AB00ENG.pdf (263.14 KB) You must be logged in to download this attachment.
    ^ToM^
    Help: 495
    Rate: 2939
    Well, in fact, the torque wrench works, with only the difference that it has an additional latch that will jump as you want to pull too much. With the method with the weight, you have to do the pawl yourself and see if you've already quite strained the key arm. But actually, it is the simplest and most effective method to use at small moments.
    Once I had my hand and an ordinary wrench with about 40 cm arm in the car. A buddy and a reptile came, what old man you dismiss for maniana. After all, it tightens with a torque wrench! He flew the key to the locker, but I already had all the wheels tightened properly. He came and asks me with what moment I pulled it up. I tell him he'll be around 100 Nm. He says give, I'll check. Well, it turned out that everything was 100-110 Nm tight. Thus, it can be done without a key exactly. :D :D
    What it comes from? This is due to the fact that the keys have their factory length depending on the size. So if an ordinary peasant grabs a key, let's give it to 19, and he will draw a hand solidly, the arm of this key will give him the strength of tightening that is needed for M12 screws. Therefore, using normal keys without extensions, adapters and other inventions, most bolts can be tightened manually with the correct torque. Of course, you need to practice a bit.
    The key is worth having, if only to check whether the manual torque meter is working properly or when tightening critical screws, eg in the engine head.
  • #11 16982460
    LightOfWinter
    Help: 369
    Rate: 935
    Greetings!
    Thank you for your response.
    I suspected that the accuracy would be the worst on the edge of the range.
    But I could not confirm it anywhere in the literature.
    In the Haynes book for my engine, it is recommended to tighten the spunbonds 23Nm, but there is no tolerance.
    The tightening method based on the key rotation angle seems to me worth attention.
    I will look for materials where it is described.
    ^ToM^
    Help: 495
    Rate: 2939
    You'll find in the candle manufacturers' materials or here:
    link
  • #13 16982576
    sandamiano
    Help: 161
    Rate: 354
    And, in my opinion, it is only worth paying attention when assembling new candles where they have undeformed washers and only then rotates by the appropriate angle of the pads are flattened and it is possible to achieve the moment as it should be. When re-unscrewing and screwing the candle is no longer possible. I have a torque wrench 0-70Nm for candles, but not from the auction only more accurate from the ocean where the torque you've tightened is marked with a pointer - a small arrow that moves along with the wrench
  • #14 16984240
    ^ToM^
    Help: 495
    Rate: 2939
    Well, in case I had to remove the lamp once and mount it, I did it so that first I turned my hand to the resistance (through the extension cap) and then I put the knob in place and tightened with two fingers and then tightened about 1/4 turn and ready. The tightness is then maintained. When the spark plug is first turned on by the angle specified by the manufacturer, the washer is not crushed to the max, which means that the re-assembly and assembly with tightness is possible. :)
  • #15 16984608
    LightOfWinter
    Help: 369
    Rate: 935
    link
    Thank you for the materials.
    I still had a question. There are two keys.
    Yato 19-110Nm
    and
    Vorel 13.6-108.5 Nm
    In the latter, the range begins with smaller values. But there is no factory calibration certificate. And now the question is whether this key - Vorel is checked in terms of measurement tolerance. Or is the production process set once per tolerance and the manufacturer does not check the accuracy of its measurements afterwards?
    Do I think that I can count on better accuracy for Yato who has a calibration certificate? Is it not that important?
  • #16 16987695
    LightOfWinter
    Help: 369
    Rate: 935
    As for the Vorel 13,6-108.5 Nm key, I found in the manual "The key is calibrated at the factory with an accuracy of 4%."
    Vorel 13.6-108.5 Nm
    What dispels my doubts.
  • #17 17016954
    LightOfWinter
    Help: 369
    Rate: 935
    Finally, I bought the JONNESWAY 3/8 374MM 10-60NM T27060N key
    I hope I will be happy with it.
The discussion revolves around selecting the best torque wrench or adapter for spark plug installation, focusing on options like the YATO key (19-110Nm), Honiton adapter (20-200Nm), and Vorel key (13.6-108.5Nm). Users express concerns about accuracy, calibration, and the suitability of these tools for amateur use. It is noted that while higher-end torque wrenches offer better accuracy, affordable options can suffice for home applications. The importance of using the correct torque range for spark plugs (typically 25-30Nm) is emphasized, along with alternative methods for achieving torque, such as using a fishing scale. The Vorel key is confirmed to have a factory calibration accuracy of 4%, alleviating concerns about its reliability. Ultimately, one user decided to purchase the JONNESWAY 3/8 374MM 10-60NM T27060N key.
TL;DR: For spark plugs, target mid‑range torque on the tool; “the highest accuracy… is in the middle of the measurement range,” and ±20–30% variation often doesn’t matter. Choose a 5–50 or 10–60 Nm wrench; avoid working at the ends. [Elektroda, ^ToM^, post #16982364] Why it matters:** This FAQ helps DIYers pick an affordable, accurate torque solution for spark plugs without overpaying or stripping threads.
What torque range should I buy for spark plugs?
Pick a wrench whose mid‑scale covers your spec. Many gasoline engines specify about 23–30 Nm. A 10–60 Nm tool keeps 25–30 Nm near the middle, improving accuracy and feel. “The highest accuracy… is in the middle of the measurement range.” [Elektroda, ^ToM^, post #16982364]
Is a torque wrench better than a torque adapter for home use?
Both can work, but budget tools vary in accuracy. For simplicity and consistency, a click‑type torque wrench wins for most DIYers. Cheap devices are fine for non‑critical jobs but lack pro‑level precision, which aligns with the advice given to hobby users. [Elektroda, DriverMSG, post #16970920]
Do low‑cost torque wrenches have usable accuracy?
Yes, many budget wrenches quote around ±4% accuracy, which is adequate for spark plugs. One example in this discussion lists “calibrated at the factory with an accuracy of 4%.” Always operate near mid‑scale and store the tool correctly. [Elektroda, LightOfWinter, post #16987695]
Is a calibration certificate worth paying for?
A factory certificate confirms initial accuracy and can inspire confidence, especially for infrequent DIY use. One buyer highlighted a model supplied with a calibration certificate. It doesn’t replace periodic checks, but it helps when choosing between similar tools. [Elektroda, LightOfWinter, post #16982198]
Can I tighten spark plugs by angle instead of torque?
Yes, angle-tightening works well for new plugs with crush washers. It is less reliable after washers deform in service. Use angle only when installing new plugs or when the washer condition is known. “Only then… the pads are flattened” as intended. [Elektroda, sandamiano, post #16982576]
What if my manual says 23 Nm—how should I set the wrench?
Set the wrench to 23 Nm and tighten on clean, lightly oiled threads if the manual specifies it. One Haynes example cited 23 Nm for a specific engine. Avoid working at a tool’s extreme; a 10–60 Nm wrench suits this target nicely. [Elektroda, LightOfWinter, post #16982460]
Why avoid the ends of a torque wrench’s range?
Accuracy drops near the scale limits. Keep your needed torque near the middle for better repeatability. This guidance came directly from an experienced poster: “the highest accuracy… is in the middle.” [Elektroda, ^ToM^, post #16982364]
Do thread conditions change the effective clamping force?
Yes. Clean, dry threads vs. dirty or greased threads produce different clamp loads at the same torque. The cited post stresses that torque specs assume clean, new, uncoated threads. Adjust practices accordingly to avoid under‑ or over‑clamping. [Elektroda, ^ToM^, post #16982364]
Is 3/8" drive OK for spark plug work?
Yes. The models compared in the thread are 3/8" drive and cover the needed torque. This drive size pairs well with common spark plug sockets and provides good control in tight engine bays. [Elektroda, LightOfWinter, post #16984608]
How accurate can “feel” tightening be?
With practice, surprisingly close. One user hand‑tightened wheel bolts and a torque check showed 100–110 Nm, matching the target. For spark plugs, prefer a wrench, but this shows trained feel can be near spec. [Elektroda, ^ToM^, post #16982390]
What did the thread starter finally buy?
They purchased a JONNESWAY 3/8", 10–60 Nm (T27060N). That range keeps common plug torques centered, aligning with the mid‑range accuracy advice. [Elektroda, LightOfWinter, post #17016954]
How do I DIY‑check a wrench using a fishing scale?
  1. Fix the wrench horizontally and measure a 0.10 m or 1.00 m lever arm.
  2. Pull with the scale at that mark; 1 kg at 1 m ≈ 10 Nm (1 kg at 0.1 m ≈ 1 Nm).
  3. Adjust until the wrench clicks at the expected reading to verify calibration. [Elektroda, grzeskk, post #16982245]
Should I choose 19–110 Nm or 10–60 Nm for plugs?
Pick the 10–60 Nm model for spark plugs. It centers typical 23–30 Nm targets, improving accuracy. Avoid using 25–30 Nm at the very bottom of a 19–110 Nm tool. “Select a wrench so work sits in the middle.” [Elektroda, ^ToM^, post #16982364]
Any edge cases I should watch for?
Do not reuse deformed crush washers with angle‑tightening. The angle spec no longer correlates to proper load. If threads are dirty or lubricated, torque-to-yield shifts, risking misclamp or strip. Clean and inspect before tightening. [Elektroda, sandamiano, post #16982576]
Are torque adapters more accurate than wrenches?
Not inherently. Low‑cost torque tools, whether adapters or wrenches, are adequate for DIY but not professional precision. For critical fasteners, use a known‑accurate wrench and verify. That advice was given for amateur tools in general. [Elektroda, DriverMSG, post #16970920]
What’s a simple rule of thumb for torque math?
Use 10 N per kilogram-force at 1 meter. So 1 kg at 1 m equals about 10 Nm; 1 kg at 0.1 m equals 1 Nm. This helps set checks with a luggage or fishing scale. [Elektroda, grzeskk, post #16982245]
