X2, Y2, X1 Capacitors: Understanding Anti-Interference Capacitor Markings & Usage
al555 25574 4
  • #1 1440724
    al555
    Help: 32
    Rate: 8
    I wanted to ask what exactly these markings (x2 y2 x1) mean - is there a standard that regulates this.
    I know that it probably applies to anti-interference capacitors, but is it only such capacitors?
    Such capacitors can only be used in filter systems or in any applications where capacitors are used ??
    I'm hoping for help...
    Al555
  • #2 1451405
    Abili
    Help: 31
    Rate: 14
    The symbols Z, Y, X define the lower limit of the temperature range
    From +10°C
    Y -30°C
    X -55°C
    A digits are the upper limit of the temperature range
    2 +45°C
    4 +65°C
    5 +85°C
    6 +105°C
    7 +125°C
    8 +150°C
    9 +200°C
    AB
  • #3 1819400
    bolsfan
    Markings of this type are used to determine the electrical strength of the insulation, e.g.:
    class X1 = 1625 V- / 2 sec.
    class Y2 = 2000 V~ / 2 sec.
    ...the rest you will find in catalogs
  • #4 14500882
    krzbor
    Help: 42
    Rate: 1072
    I was looking for an answer to a question about markings. I found this document: link
    As for me, it describes the markings of anti-interference capacitors quite exhaustively.
  • #5 20555704
    TAAG
    Help: 37
    Rate: 54
    I took the liberty in this old topic to add the file from the link here before it disappears into the depths of the web.
    • Filtrowanie zakłóceń RFI .pdf (179.92 KB) You must be logged in to download this attachment.
