Home Test for Audi A3 1.9TDI Vacuum Pump: Assess Brake Response & Pedal Behavior with Gas
makaronmc 92361 15
How can I check whether the brake vacuum pump on an Audi A3 1.9 TDI is really faulty, and is the brake pedal dropping when I press the brake and add throttle a valid test?
The pedal-dropping-when-you-blip-the-throttle test is not a reliable diagnosis; the proper check is to measure the vacuum in the system with a vacuum gauge and inspect the vacuum lines for leaks or blockage [#13946523][#13946746] After 4–5 brake presses the stored vacuum can be used up, and if the pump cannot rebuild it at idle the brake assist will weaken, so the problem may be in the pump, the servo, or the vacuum line rather than only the pump itself [#13946861][#13946879] One reply noted that on this engine the vacuum pump can fail at the metal fitting, causing vacuum loss [#13946861] A cited value was that the pump should create at least about 0.7 bar of vacuum [#13947433]
  • Testing Audi vacuum pump via pedal response under throttle
    #1 13946480
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    Today I showed up at the local brake repairman...
    Replaced the rear discs and pads.
    He did not order the fluid to be replaced because he took the old one and said it was quite clear.
    (I bought the car 3 years ago and didn't check the fluid)
    The specialist swore that I have a damaged Vacum Pump.
    (When braking several times in a row ... for 4-5 times, the car almost does not react to the brake)
    He showed me a simple example ... He told me to press the brake pedal and add gas ... the brake pedal itself began to fall slightly ...
    Is this a valid test?
    Patient :
    Audi A3 1.9TDI
  • #2 13946523
    budiet
    Help: 25
    Rate: 92
    I suggest plugging a vacuum gauge into the system and reading the vacuum value, unless you also want to measure the pump's efficiency, how many liters per minute it pumps.
    Check the patency of the wires.
  • #3 13946537
  • #4 13946746
    tzok
    Help: 3176
    Rate: 6549
    There may as well be a leak in the servo itself or the vacuum line.
  • #5 13946775
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    I asked the guy if it was...
    I know him because he comes from my town...
    He said that he would not bet because there was nothing to do ... but we agreed that if it was the same, he would screw in the old pump and I would not pay anything for the work ;-)
  • Moisture-contaminated brake fluid causes repeated-braking fade
    #6 13946860
    vodiczka
    Help: 1185
    Rate: 4311
    Change the professional to another as soon as possible.
    makaronmc wrote:
    (When braking several times in a row ... for 4-5 times, the car hardly reacts to the brake)
    When the brake fluid is watered, the hydraulic brake becomes pneumatic when braking frequently
    Did you buy new or used? In the stimulant, the liquid can be twice as old, the effects as above
  • Vacuum gauge testing reveals leaks and pump fitting failure
    #7 13946861
    toku74
    Help: 123
    Rate: 729
    If you press the brake four or five times, you'll use up all the vacuum. The idling pump will not be able to replenish it /here the course to the right and the information why you do not drive "at ease" - this is one of the reasons/. You will check the vacuum with a meter - as they inform you earlier. The meter will indicate whether the vacum has the right value and you will be able to check for any leaks. As far as I know your engine, the vacum pump breaks down very often - the metal fitting in the pump loosens and there is a loss of vacum.
  • #8 13946879
    Dziaduszyn
    Help: 19
    Rate: 70
    Have you checked the servo itself?
  • #9 13947423
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    The spec will check on Thursday, but he said that he has already eaten his teeth on the brakes and it will be the pump for 99%.
    And a damaged vacuum pump has something to do with the turbocharger?
  • #10 13947433
  • #11 13947439
    Dziaduszyn
    Help: 19
    Rate: 70
    It does, if it is, for example, controlled by vacuum. Such a solution is used, for example, in discharge valves that are opened with the help of a vacuum pump.
  • #12 18941333
    jacek1008
    Rate: 17
    budiet wrote:
    I suggest plugging a vacuum gauge into the system and reading the vacuum value, unless you also want to measure the efficiency of the pump, how many liters per minute it pumps.
    I might revive an old thread.
    How to measure the pump vacuum efficiency? It is the number of liters per minute.
    Added after 4 [minutes]:
  • #13 18941425
    marszałekkom
    Help: 212
    Rate: 510
    Maybe a water meter? But in practice it will be difficult to mount it, and even so the test will not give much, because it is not known what the factory performance should be. I know that in efficient cars the pump pumps out the air from the servo in about 2 seconds.
  • #14 18941553
    piotrekwoj1
    Help: 947
    Rate: 3433
    It's not about how much it pumps, it's about how quickly it will do it, i.e. how quickly it can recover the vacuum in the system.
    The only way to assess this is to observe the vacuum gauge plugged into the system.
  • #15 18941733
    jacek1008
    Rate: 17
    Yes, I agree, but where to get reference values?
  • #16 18941758
    piotrekwoj1
    Help: 947
    Rate: 3433
    I don't think there is such a thing, just a comparison with a working car.
The discussion revolves around diagnosing a potential vacuum pump issue in an Audi A3 1.9TDI, particularly in relation to brake response and pedal behavior. The user reports that after replacing rear brake discs and pads, the brake pedal exhibits poor response after multiple presses, leading a brake specialist to suggest a damaged vacuum pump. Various responses recommend testing the vacuum system using a vacuum gauge to measure efficiency and check for leaks in the servo or vacuum lines. The importance of brake fluid condition is also highlighted, with suggestions to replace it if necessary. Additionally, the relationship between the vacuum pump and turbocharger functionality is discussed, noting that a malfunctioning pump can affect boost control.
