Which horizontal blinds should I choose for the thermal insulation of a 5m x 1.5m mezzanine?
Mkokosz 1488 1
  • #1 13991130
    Mkokosz
    I have a question for you. I own a detached house with a mezzanine floor. During the winter I would like to cover it because there is a fireplace underneath. All the heat escapes to the top which means that adequate heating of the bottom results in overheating of the top.
    Therefore, I would like a horizontal airtight shutter/blind to separate the downstairs and keep the heated air more at the bottom. The dimension is 5m by 1.5m. any solution?
    Regards
  • #2 14004581
    arkady_pl
    Help: 59
    Rate: 24
    In my opinion, there is no point in extending anything as the air will, sooner or later, reach the top anyway. I would rather think about how to change the circulation to change that. There is no drawing so it is difficult to get better ideas, nevertheless....
    - you can install extraction units under the ceiling to move the warm air to other places
    - insulate the floor of the mezzanine floor to make it less warm
    - install an air supply from the cooler part of the room on the mezzanine floor, which cools the mezzanine floor and forces a different circulation.
    A lot depends on the construction and location of the mezzanine floor.
