How to connect multiple sensors to the Aurel 650201280G and HOPE HM-TRS868?
lateraluspl 1398 0
  • #1 14034218
    lateraluspl
    Hello, I have a question regarding RF modules from AUREL, HOPE etc....
    HOPE MICROELECTRONICS HM-TRS868
    AUREL 650201280G
    How can sensors be connected to them
    have outputs, example from aurel:
    1. ANTENNA
    2. GND
    5. GPIN0 / ADC0 / LIMITSWITCH_OPEN
    6. GPOUT0 / MOTOR_UP / PWM
    7. LEARN (Input for learning procedure, pull-up is already provided. A button towards
    GND should be used)
    8. UART RX (Input for module)
    9. LED (Output for learning confirm. A led towards GND with resistance should be
    used)
    10. UART TX (Output for module)
    11. VCC (+3V or +5V)
    12. GND
    13. ENABLE (High: ON – Low: OFF, with built-in pull-down resistor). This pin can be
    driven by an external microcontroller, with no need for dedicated regulators or
    transistors to break module power-supply
    14. GPIN1 / ADC1 / LIMITSWITCH_CLOSE
    15. GPOUT1 / MOTOR_DOWN
    And can more than one sensor be connected to them, as they have an Atmega? Can they be connected directly or is something else necessary?
    I want them to transmit the readings of the various sensors over a distance.
