Samsung F1045AV Washing Machine - Persistent dE Error: Door Sensor Access & Solutions
Neuron26 57404 3
  • #1 6785762
    Neuron26
    Rate: 23
    Hello and welcome.
    The washing machine, as in the topic, still displays the error dE. In the instructions, they write that it is from an open (not closed) door. Unfortunately, all attempts to get rid of this error by closing the door do not help :( Anyone have a way to get rid of this? How can this sensor be accessed?
    Thank you in advance for your answer.
  • #2 6785793
  • #4 6793253
    Neuron26
    Rate: 23
    Welcome back.
    Case resolved. The cause was in the blockage. After dismantling, it turned out that a 'foreign body' blocked the lock, which in consequence made it impossible to close the electromagnet and short-circuit the contact giving the 'open-closed' signal. Considering that it was my first contact with the washing machine (I mean from this side), thank you very much for your interest and help :)
    The subject - I suppose - is closed :)
