Autonomous door controller with remote control and scheduler? looking for...
adam_ruski 1464 2
  • #1 14117601
    adam_ruski
    Looking for a standalone door controller for a detached house with functions:
    - 2 remote controls with 2 buttons to close the door
    - timetable, e.g. from 7 a.m. to 6 p.m. door open, from 6 p.m. to 7 p.m. door automatically closed (if opened between 7 a.m. and 6 p.m. remote control should close the door and it should stay that way until you open the door with the remote control)
    if the door is open, it should automatically close at 6 p.m. and then the remote control can open the door for a controllable period of time - a few minutes
    i was thinking of something like the EDGEPlus Solo ES400 from HID
    Link
    plus a control unit as for a car with 2 remote controls. however, this does not give me full management freedom.
    Anyone knows a similar controller with the functions I need?
    Of course the price is important.
  • #2 14117890
    pafciowaw
    Automation specialist
    Help: 480
    Rate: 365
    You can use a programmable timer, e.g. PCZ-521 http://fif.com.pl/produkt/38/631 to set intervals of 7-18 (permanently open) and 18-7 (permanently closed), to which a 1-channel radio line + remote controls can be added. And for temporary closing (when the zone is closed and "opening for a moment" by remote control), either appropriate programming of the radio line, e.g. http://sklep-ecsystem.pl/radiolinia-1-kanal-dwa-piloty-w-zestawie-umb100h.html (monostable activation after a signal from the remote control) or another solution: delay timer (opening time after a signal), e.g. PCU-510 http://fif.com.pl/produkt/36/546
  • #3 14139034
    elektryk1e
    Help: 38
    Rate: 34
    Take an interest in Roger's products. The autonomous access controller will meet all your requirements. Do you already have a mechanical solution for closing the door? A deadbolt, jumper or deadbolt? Take a look at the Assa Abloy product range
