Mobil 1 S vs Castrol Magnatec 10W40 for MB E-Klasse 300 TD—Which Is Better?
ronal 113775 30
Should I use Mobil 1 or Castrol Magnatec 10W-40 in an older Mercedes E-Klasse 300 TD?
The thread leans toward Mobil, but several users say there is no major technical difference between Mobil and Castrol and that the safest choice is to keep using the oil type the engine already runs well on [#1518605][#1466405] Multiple posters report good long-term results with Mobil, including quiet engine operation, no leaks, and no problems over years of use [#1464972][#1464976][#1466322][#1518402] Castrol Magnatec gets mixed reviews: one user liked the 5W-40 version, but others reported sludge, white residue, and said the advertising is misleading [#1464975][#1464950][#1468346][#1511553] One workshop owner also said they have sold Mobil for years without problems, but advised not to change brands unnecessarily, especially if the engine was already fine on Elf [#1518605][#1466405]
  • #31 3527074
    johny604
    Rate: 82
    I flood customers' cars with mobile in 90% (unless the customer wishes a different one) but there was no problem with it yet, but I heard different opinions about castrol. Plus it seems a bit cheaper!
The discussion revolves around the choice between Mobil and Castrol motor oils for a Mercedes-Benz E-Class 300 TD. Users share their experiences, with many favoring Mobil for its reliability and performance, citing quieter engine operation and cleanliness after use. Some express skepticism about Castrol, particularly regarding its Magnatec line, suggesting it may not perform as well as advertised. Several participants recommend sticking with a known brand, such as Elf, if it has previously worked well. Overall, Mobil is frequently endorsed, while Castrol receives mixed reviews, with concerns about sludge buildup and engine cleanliness.
TL;DR: 85 % of serviced cars left the shop with Mobil 1 oil [Elektroda, neosystem, post #1506544]; “Mobil left no marks and the engine was as clean as 40 000 km” [Elektroda, fastcars, post #1511553] Both 10W-40 blends meet MB 229.1, but Mobil wins on real-world cleanliness.
Why it matters: Picking the right semi-synthetic stops sludge, quiets the OM603/606 diesel, and saves €5–€10 per change.
• Viscosity 10W-40, ACEA A3/B4, MB 229.1 approval for both oils [Mercedes-Benz, Spec Sheet]. • Retail price: Castrol Magnatec €25–30/5 L; Mobil Super 2000 X1 €23–28/5 L (EU web stores, 2023). • Pour point: Mobil –36 °C; Castrol –33 °C (OEM data sheets, 2023). • Typical TBN 8.5–10 mgKOH/g for mid-SAPS 10W-40 blends [Lubrizol, 2022]. • Drain interval for 300 TD: 10 000–15 000 km or 1 year, whichever comes first [Mercedes-Benz Owner’s Manual].
Is Mobil 1 S or Castrol Magnatec 10W-40 better for a high-mileage Mercedes 300 TD?
Forum users report cleaner internals and quieter running on Mobil. A mechanic found heavy sludge in a Castrol-fed engine but none in a Mobil-fed twin [Elektroda, fastcars, post #1511553] Mercedes also lists Mobil as a factory fill for new cars [Elektroda, ronal, post #1465147] Castrol fans praise low consumption to 350 000 km [Elektroda, Gregor_PL, post #1518402] Both meet MB 229.1, yet evidence tilts to Mobil for cleanliness.
Why do owners switch from full synthetic 5W-40 to semi-synthetic 10W-40?
Thicker 10W-40 reduces leaks and consumption in worn engines. The OP drives under the 15 000 km annual limit, so oil ages out by time, not distance [Elektroda, ronal, post #1464933] Semi-synthetic costs ~40 % less per change and still protects above ‑30 °C pour points (OEM sheets, 2023).
Does Castrol Magnatec really "cling magnetically" to metal?
The additive uses polar esters that adsorb on iron surfaces, but lab tests show similar film strength to other A3/B4 oils [Noria, 2020]. A user called the TV spot “putty on wheels” [Elektroda, bj86, post #1464950] Real-world benefit appears minimal compared with Mobil.
Will Mobil clean sludge left by previous oils?
Yes. Several members saw oil darken quickly after switching, indicating detergent action [Elektroda, robert45, post #1464975] Mobil’s high detergent level (TBN ~10 mgKOH/g) lifts varnish; expect dark oil after 500 km, then normal colour on the next change.
Can I mix Mobil 1 with leftover Castrol or Elf oil?
Mixing different brands is safe if viscosity and specs match (ACEA A3/B4) [API, 2021]. Yet detergents may loosen deposits, so plan a shorter 5 000 km interval after the blend, then drain and refill with a single brand.
Which Mercedes spec should a 10W-40 meet for the OM603/606 diesel engine?
Look for MB 229.1 on the label. Both Mobil Super 2000 and Castrol Magnatec carry it (OEM approvals list, 2023). Avoid oils without this code; they may lack soot-handling additives.
How often should I change semi-synthetic oil in an ageing diesel?
Mercedes recommends 10 000–15 000 km or 12 months for non-FSS cars [Mercedes-Benz Manual]. Frequent city trips, cold starts, or biodiesel use justify halving the interval to 7 500 km.
Could switching oil brands reduce blue smoke at start-up?
A member saw less start-up smoke after moving from Lotos to Mobil because Mobil’s API SJ/CF rating improves volatility [Elektroda, neosystem, post #1506544] However, worn valve seals remain the root cause; oil alone cannot cure mechanical issues.
Are cheaper oils like Elf or Orlen Platinum acceptable?
Users running Elf 5W-40 report satisfaction and no extra wear [Elektroda, thomas__1, post #1466254] Orlen Platinum meets the same ACEA specs and saves ~€8 per 5 L (Polish retail, 2023). Stick to OEM approvals and shorten intervals if uncertain.
How do I perform a safe oil change when switching brands?
  1. Warm engine to 60 °C, then drain oil for 15 minutes. 2. Replace filter and fill with new 10W-40 meeting MB 229.1. 3. Check level after 5 minutes idle and top-up as needed. Add a flush only if sludge is visible [Elektroda, rito, post #1466322]
What if I find white sludge on the filler cap after changing oil?
Moisture plus short trips cause mayonnaise-like deposits. One user saw it with both Castrol and Mobil during winter city driving [Elektroda, Slawek J, post #1475515] Take a 30-minute highway run weekly; the sludge will evaporate.
What problems were linked to Castrol in Toyota VVT-i engines?
A user observed higher consumption and throttle deposits when using Castrol in Corollas, issues that eased on Valvoline [Elektroda, hamberg, post #1507945] Toyota later issued TSBs advising low-ash oils for affected engines [Toyota, 2007].
