volkswagen passat b6 1.9 tdi 105 km 2006 - what good oil for the engine to buy?
Mateo89 32112 8
  • #1 16493033
    Mateo89
    Level 4  
    Rate: 27
    Hello, I just bought a Passat B6 from 2006 which has 242 thousand kilometers driven, the course I do not know if it's real, but the papers show that :) and I would like to change his oil for some good one. I was thinking about Motul because he has a lot of good reviews but I do not know the parameters because I heard that he must have some standards. How do I check them? Currently, Castrol 5w40 was cast but I also do not know exactly what I found it on the card attached to the engine. Please, specify exactly what Motul oil I need to buy?
  • #2 16493091
    @@Kamil@@
    Rate: 42
    I have this engine in Golf V and pours 8100 X-clean 5W-40 exchange every 15,000 km.
    Once I was flooding him with some Elf and it was good too. Oil consumption of 1l in those 15 thousand I had castrol, it took a little more than 1l.
  • #3 16493252
    FAB 2002
    Help: 35
    Rate: 195
    Engine oil with unit injectors must comply with VW 505.1 (replacement every 15,000 km), VW 506.1 (Long Live mode), VW 507 507 (for engines with DPF and Long Live).
  • #4 16493469
    Mateo89
    Level 4  
    Rate: 27
    I have a car without dpf so what exactly should I buy? What are these oil guidelines written on?
  • #5 16495786
    Mateo89
    Level 4  
    Rate: 27
    So what Motul should I buy? there are a few of them Will Motul Specty be ok? Does he meet this standard?
  • #6 16495812
    moto-kord
    Help: 137
    Rate: 505
    Hello, how many km do you do?
  • Recommended oil standards for VW 1.9 TDI PD engine
    #7 16496266
    FAB 2002
    Help: 35
    Rate: 195
    The manufacturer sets standards for the product on each original motor oil package.
    SAE standard (so-called temperature) - for our climate area - 5W40.
    API standard (so-called qualitative American) - recommended - SJ / CF.
    ACEA standard (so-called qualitative European) - recommended - A3 / B4.
    OEM standard (so-called qualitative engine manufacturer - for VW injector pumps) 505.01 .
    These w. Wym. the standard should meet oil for the VW 1.9 TDI / PD engine.
    The oil producer is to be recognized by the driver. I use Castrol EDGE Turbodiesel 5W40 for my Bora - this was flooded with new products.
  • #8 16496601
    moto-kord
    Help: 137
    Rate: 505
    Engine: Time / distance dependent inspection, no diesel particulate filter
    Engine oil SAE 5W-30 VW 505 01 All temperatures
    Motor oil SAE 5W-40 VW 505 01 All temperatures
    Zalej Castrol EDGE Turbodiesel 5W / 40.
  • #9 16496614
    Mateo89
    Level 4  
    Rate: 27
    moto-cord Kilometers I do about 30,000 a year.
    Thank you for your answers, I'm ready to know what to look for. greetings
The discussion revolves around selecting the appropriate engine oil for a 2006 Volkswagen Passat B6 1.9 TDI with 242,000 kilometers. The user is considering Motul oil due to its positive reviews but seeks clarification on the necessary specifications. Responses indicate that the oil must meet VW standards, specifically VW 505.01 for engines without a diesel particulate filter (DPF). Recommended oils include Motul 8100 X-clean 5W-40 and Castrol EDGE Turbodiesel 5W-40, both of which comply with the required standards. Additional specifications include SAE 5W-40 for temperature and API SJ/CF for quality.
