Z32SE Opel Signum 3.2 v6: Oil Change Question - Transition from 10w40 to 5w30, Castrol Edge
Jarooooo 6765 4
  • #1 16214760
    Jarooooo
    Oil change time is coming in Signum 3.2 v6 (Z32SE)
    The car has driven 209,000. The last entry in the book is with an oil change for 10w40, after the purchase I exchanged for the same Mobil 10w40.
    Now I do not like this oil (mayonnaise under the cork, clogged emphysema - the result was oil seals from the keyboard), recommended oil according to the book 0w40 or 5w30, the car has no oil leaks. The car may be under-heated, which causes carbon deposits to accumulate under the plug, but I do not like the oil, the gasket under the heads is ok, the fluid does not decrease.
    What do you think of the transition from 10w40 to 5w30 ?? threatens to unseal the engine? Can a good 10w40 oil fill, e.g. Motul or LM. ??
    At the moment I bought Castrol Edge 5w30LL and I had doubts that I would flood it on Tuesday I have an oil change ... I am asking for any advice what you think about it. ?
  • #2 16214987
    melon1968
    Driving in the winter on short distances causes water vapor that can block the pneumothorax and poor oil intensifies it. Pour this castrol nothing should happen unless someone has poured a motodoctor or similar shit.
  • #3 16215027
    Jarooooo
    like 5w30, castrol certainly will not pour in, too much bad is read about it and the difference in price from motula or lq 10-20 PLN.
    Stages to work I do 10km cold engine and oil dumped. Now I fly with cardboard :) and it's better now. It is about whether or not the engine leak or roulette. : / Because I am not 100% sure how many people were cast
  • #4 16215076
    melon1968
    And the motul is better? That the 5w-30 was like you have in the service case and from a reliable source. Unseal the engine should not be because it is superstition from the time of the polonaises.
  • #5 16215117
    Jarooooo
    Better I don't know, but they don't mess with him like a castrol ;) A reliable source is a store, I have no access to the manufacturer.
