Zumtobel LED driver - What power and current for a module with 56 LEDs?
YR1 1395 0
  • #1 14135673
    YR1
    Help: 49
    Rate: 52
    The protagonist of the topic is a Zumtobel LED lighting controller. What should I "wire" the power and current to the LED board? I own the electonics for this, but I want to use it differently. It is a module with 45 white LEDs, 8 red LEDs and 3 super bright white LEDs. The whole thing gives 26W of light (with proper cooling). My client has requested that the light should "drop down". Module "2" i.e. the D525A has a dimmer function, this is implemented by a taster. And now yes. Can someone write a program under MCS or something similar to perform the PWM function with the consideration that this is a staircase. Input: strain gauges after operacem amplification, (0.2 - 2V) output? precisely, I don't know how to make the output to work like a taster. There are 23 tasters, it's supposed to work like this: someone walks from above, the light comes on and the light goes down. From the bottom it's the same. If someone goes up and down then the light should work here and there, and drop down.
    There may be controllers, but I doubt it, my client has it 'messed up' in his head and must have better a than his neighbour.
