Best cable for DS18B20 sensor for long distances (3x20m)?
abwg 4017 2
  • #1 14149425
    abwg
    Rate: 91
    i am planning to connect multiple sensors to the 1-wire bus of a raspberry minicomputer and I know that the longer the length of the total cable is, the lower the probability of reading.
    Here my question is what is the best cable to use to maximise the distances?
    I have found something like LIYCY. It is unfortunately expensive.
    I would like to connect at least 3 x 20m.
  • #2 14157133
    Popak
    Moderator on vacation ...
    Help: 97
    Rate: 270
    You can use twisted pair cable in the screen. In addition, you can use a ferrite choke at the end of the cable (computer side):
    Regards
  • #3 14212810
    KwoiteK
    Help: 14
    Rate: 10
    I have about 20 sensors on one bus in a star topology (unfortunately such a necessity). With an ordinary twisted-pair cable, the problem was not the length, but the number of ds connected. It worked with a 1k bus pull-up resistor.
    In the 1wire bus, the capacity of the wires is of great importance.
    Think about surge protection for the bus.
