LAN Controller - problem with saving settings in the EVENTS table
luktob 1158 0
  • #1 14166662
    luktob
    Rate: 22
    I have a LAN Controller. I control temperatures, humidity, flowing current and power consumption with it. However, when I want to control the relay outputs OUT0 - OUT4 from the EVENTS table, problems arise. After setting the temperature range and trying to write 'save', the message 'wait 3 second' appears. This wait never ends and I am not sure if the values have been saved. If the output changes its state - signalling green, trying to save another temperature range does not change the state of the output.... i have this impression that what is typed into the table has a poor translation to the response of the outputs....
    has anyone encountered this problem?
    Greetings
    Gap
