Discover Audi Climatronics Hidden Functions: User Experiences & Allegro Auction Info
Patol 186609 6
  • #1 1472850
    Patol
    Help: 50
    Rate: 31
    does anyone know these hidden functions ?? I found such an auction on the Allegro. I am curious if it works, if anyone would know, please answer.
    http://moto.allegro.pl/show_item.php?item=49568642
  • #2 1472976
    tomekb
    Help: 54
    Rate: 210
    look in this forum
    if I remember correctly, the description of the service was also discussed
    Greetings
    T.
  • #3 1473050
    Patol
    Help: 50
    Rate: 31
    I am looking, I am looking and I cannot find. : /
  • #4 1473102
    Stoperf
    You won't learn anything interesting from these additional functions. how do you have any problem c air conditioning connect vaga and read the errors.
  • #5 1473205
    elbob
    Level 32  
    Help: 211
    Rate: 118
    I don't know where I got something like this from, but I am sending it to PW - it may be useful.
    Greetings.
  • #6 1473426
    Sady
    Help: 115
    Rate: 373
    And if by VAG nothing detects an air conditioning error, the air-conditioning system does not work (nothing can be set, there is a constant airflow), what may be the cause. Just do not write that the fault lies with the lack of refrigerant, and then what?
  • #7 1474985
    grzesiek_nysa
    Help: 61
    Rate: 57
    KLIMATRONIK
    Change the temperature display units.
    Press and hold the recirculation button. Then press '+'
    temperature to change the units between Celsius and Fahrenheit to
    air conditioning display and outdoor temperature indicator.
    Diagnostic codes available.
    Press and hold the recirculation button. Then press the button
    manual top airflow. 1c will be displayed. Press '+' or '-'
    temperature to select the code number. Press the button again
    recirculation. The value will be displayed. Press '+' or '-' temperature
    again to display a different code.
    Note: The airflow motor (V 71) and potentiometer (G 113) are not
    installed in versions for the USA / Canada. Ignore the values displayed for these
    elements.
    Code value displayed.
    1 System fault - displays as Diagnostic Trouble Code (DTC),
    see paragraph below
    2 Digital value of Interior Temperature Sensor, in Headliner (G 86)
    3 Digital value of internal temperature sensor, in dashboard
    (G 56)
    4 Digital value of inlet air temperature sensor (G 89)
    5 Digital value of outdoor (ambient) temperature sensor (G 17),
    front
    6 Digital value of the outdoor (ambient) temperature sensor
    7 Digital value of the ambient temperature sensor of the fresh blower
    air (G 109)
    8 Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
    9 Delta value of
    Temperature Regulator Flap)
    10 Error value of the Temperature Regulator Flap
    11 Digital Value of Central Flap Motor Potentiometer (G 112)
    12 Special value of the central flap
    13 Digital value of Footwell / Defroster Flap Motor Potentiometer (G 114)
    14 Special value of Leg Flap / Defroster
    15 Digital value of Air Flow Flap Motor Potentiometer (G 113)
    16 A specific value for the air flow flap
    17 Vehicle speed (km / h)
    18 Current air blower voltage (V)
    19 Special voltage air blower (V)
    20 A / C compressor (A / C clutch) voltage (V)
    21 Number of low voltage occurrence, non-transient
    22 Air conditioning cycle of the A / C high pressure switch (F
    118)
    23 Cycles of A / C High Pressure Switch (F 118)
    24 switching cycles, absolutely never-hesitating
    25 Analog / digital value, Kick-Down switch
    26 Analog / digital value, cooling temperature warning lights
    engine (ECT)
    27 Coding value
    28 Engine Speed (RPM)
    29 Air conditioning compressor speed - equal to engine speed x 1.2
    (RPM)
    30 Program version
    31 Checking the display (all segments of the controller light up)
    32 Potentiometer error counter of the Temperature Regulator Flap
    33 Counter of errors of the central flap potentiometer
    34 Potentiometer fault counter, Footwell / Defroster Flap
    35 Air flow damper potentiometer malfunction counter
    36 Signal "cold" end-stop - Flap Motor Potentiometer
    temperature regulation (G 92)
    37 Feedback value, hot end-stop, Flap Motor Potentiometer
    temperature regulation (G 92), max.
    38 Signal "cold" end-stop - Flap Motor Potentiometer
    central (G 112)
    39 Feedback value, hot end-stop, Flap Motor Potentiometer
    central (G 112)
    40 Signal "cold" end-stop - Flap Motor Potentiometer
    legs / defroster (G114)
    41 Signal hot end-stop - Flap Motor Potentiometer
    42 Signal "cold" end-stop - Flap Motor Potentiometer
    air flow (G 113)
    43 Feedback value, hot end-stop, Flap Motor Potentiometer
    air flow (G 113)
    44 Vehicle (carrier?) Operation cycle counter
    45 Calculated inside temperature (internal program, digital)
    46 Outdoor (ambient) temperature, filtered, for regulation (program
    internal)
    47 Outdoor (ambient) temperature, unfiltered, (internal program,
    in oC)
    48 Outside (ambient) temperature, unfiltered, (digital)
    49 Speedometer Signal Error Counter (Vehicle Speed)
    50 Dwell time (min)
    51 Engine Cooling Temperature (ECT) in oC
    52 Graphic channel 1 - provided that the air conditioning compressor is present
    off - will be displayed 88.8.
    Look below.
    Graphical Channel 2 - The state of the electrical output system is identified
    display 88.8. look
    below.
    54 Control character
    55 Outdoor (ambient) temperature in oC or oF confirmed on panel
    air conditioning controller
    56 Temperature in oC, from Interior Temperature Sensor, in Headliner (G.
    86)
    57 Temperature in oC, from internal temperature sensor, board
    dashboard (G 56)
    58 Temperature in oC, from fresh air duct temperature sensor, (G.
    89)
    59 Temperature in oC, from an external temperature sensor (G 17), front
    60 Temperature in oC, from ambient temperature sensor, fresh air blower
    air (G 109)
    61 Program version (latest)
    Meaning of Diagnostic Trouble Codes (DTCs)
    00.0 no errors
    02.1 (G86) interior temperature sensor, in headliner, static break,
    * 02.1 (see below)
    02.2 Interior Temperature Sensor, in Headliner, static short, see
    02.1
    02.3 Interior Temperature Sensor, in Headliner, sporadic open
    02.4 Interior Temperature Sensor, in Headliner, sporadic short
    03.1 (G56) Interior Temperature Sensor, in instrument panel, static
    break, see 02.1
    03.2 Interior Temperature Sensor, in Instrument Panel, static short,
    see 02.1
    03.3 Interior temperature sensor, in dashboard, sporadic open
    03.4 Interior temperature sensor, in dashboard, sporadic short
    04.1 (G89) Fresh Air Duct Temperature Sensor, static break,
    * 04.1 (see below)
    04.2Fresh Air Duct Temperature Sensor, static short,
    see 04.1
    04.3 Fresh Air Duct Temperature Sensor, sporadic open
    04.4 Fresh Air Duct Temperature Sensor, sporadic short
    05.1 (G17) Outside (ambient) Temperature Sensor, front, static
    break, * 05.1 (see below)
    05.2Outside (Ambient) Temperature Sensor, front, static short,
    see 05.1, * 05.2 (see
    below)
    05.3 Outside (ambient) temperature sensor, front, sporadic break
    05.4 Outside (ambient) Temperature Sensor, front, sporadic short
    06.1 (G110) Engine Cooling Temperature (ECT) Sensor, A / C
    continuous break, * 06.1 (see
    below)
    06.2 Engine Cooling Temperature (ECT) sensor, A / C continuously
    short circuit, see 06.1
    06.3 Engine Cooling Temperature (ECT) Sensor, A / C sporadic
    break
    06.4 Engine Cooling Temperature (ECT) sensor, A / C sporadic
    short circuit
    07.1 (G109) Ambient Temperature Sensor at Fresh Air Blower,
    continuous break, * 07.1 (see
    below)
    07.2 Ambient Temperature Sensor at Fresh Air Blower, static
    short circuit, see 07.1
    07.3 Ambient Temperature Sensor at Fresh Air Blower, timer
    break
    07.4 Ambient Temperature Sensor at Fresh Air Blower, timer
    short circuit
    08.1 (G92) Temperature Regulator Flap Motor Potentiometer, static
    break, * 08.1 (see below)
    08.2 Temperature Regulator Flap Motor Potentiometer, static short,
    see 08.1
    08.3 Temperature Regulator Flap Motor Potentiometer, sporadic open
    08.4 Temperature Regulator Flap Motor Potentiometer, sporadic short
    08.5 Temperature Regulator Flap, static block, * 08.5 (see below)
    08.6 Temperature Regulator Flap Motor Potentiometer, defective
    08.7 Temperature Regulator Flap, sometimes blocked
    11.1 (G112) Central Flap Motor Potentiometer, static open, * 11.1
    (look below)
    11.2 Central Flap Motor Potentiometer, static short, see 11.1
    11.3 Central Flap Motor Potentiometer, sporadic open
    11.4 Central Flap Motor Potentiometer, sporadic short
    11.5 Central Flap, static block, * 11.5 (see below)
    11.6 Central Flap Motor Potentiometer, defective
    11.7 Central Flap, sometimes blocked
    13.1 (G114) Footwell / Defroster Flap Motor Potentiometer, static pause,
    * 13.1 (see below)
    13.2 Footwell / Defroster Flap Motor Potentiometer, static short, see
    13.1
    13.3 Footwell Motor Potentiometer / Defroster, sporadic open
    13.4 Footwell / Defroster Flap Motor Potentiometer, sporadic short
    13.5 Footwell / Defroster Flap, static block, * 13.5 (see below)
    13.6 Footwell Motor Potentiometer / Defroster, defective
    13.7 Footwell / Defroster Flap, sometimes blocked
    15.1 (G113) Air Flap Motor Potentiometer, static open, * 15.1
    (look below)
    15.2 Air Flap Motor Potentiometer, static short, see 15.1
    15.3 Air Flap Motor Potentiometer, sporadic open
    15.4 Air Flap Motor Potentiometer, sporadic short
    15.5 Air Flap, static block, see * 15.5 (see below)
    15.6 Air Flap Motor Potentiometer, defective
    15.7 Air Flap, sometimes blocked
    17.0 Faulty car speed signal
    18.1 Fresh air blower voltage, still
    18.3 Fresh air blower voltage, sporadic
    20.1 Bad voltage in A / C compressor - still, * 20.1 (see below)
    20.3 Bad voltage in air conditioning compressor - sporadic
    22.1 (F118) A / C air conditioning high gas pressure switch, static
    break, * 22.1 (see below)
    22.3 A / C air conditioning high pressure switch, occasional break
    22.5 Air conditioning high pressure switch for gas, 120 x open, * 22.5
    (look below)
    29.1 Belt slip detection "soft", continuous
    29.2 Belt slip detection "hard", continuous
    29.3 "Soft" belt slip detection, sporadic
    29.4 Belt slip detection "hard", sporadic
    Diagnostic Trouble Code (DTC) Notes:
    * 02.1 Default digital value 128 is set if the sensor is
    damaged
    * 04.1 Value delivered by a damaged temperature sensor
    * 05.1 Value delivered by faulty temperature sensor
    * 05.2 Digital default 128 is set if sensors G89 and G17
    are damaged at the same time
    * 06.1 The engine cooling temperature is calculated if the sensor is present
    damaged or not installed,
    Only perform diagnostics above 0 degrees Celsius
    * 07.1 Correct value programmed = 0
    * 08.1 The temperature regulating flap motor cannot be controlled any longer
    automatically, only manually
    * 08.5 The engine is jammed, try to remove the blockage programmatically
    * 11.1 The central flap motor can no longer be automatically controlled,
    only by hand
    * 11.5 The engine is jammed, try to remove the blockage programmatically
    * 13.1 The foot flap motor / defroster can no longer be controlled
    * 13.5 The engine is jammed, try to remove the blockage programmatically
    * 15.1 The digital value is programmed internally for limp-home mode
    (soft?)
    * 15.5 The engine is jammed, try to remove the blockage programmatically
    * 20.1 The compressor remains off until the voltage is higher than 10.8V
    for the last 25 seconds
    * 22.1 The compressor remains off until the breaker closes
    * 22.5 Compressor restarts, VAG 1551 error scanner
    Channel codes 52 - OBD - air conditioning compressor off
    If the air conditioning compressor is off, "88.8" is displayed, comes on
    the following alphanumeric codes will be displayed.
    Conditional part
    a1 Interrupt or blockage, high gas pressure switch
    air conditioning, 120 x off
    b1 Engine Speed (RPM) less than 200 - 500
    c1 Engine Speed (RPM) greater than 6000
    d1 Engine Speed (RPM) greater than 6000
    e1 System functions OK
    f1 System functions OK
    a2 Air conditioning switched off manually (air conditioning not active)
    b2 Low voltage
    c2 Kick-down switch, compressor off for 12 s max.
    d2 Engine Cooling Temperature (ECT) indicator light ON
    e2 A / C Low Gas Pressure Switch (F73)
    f2 A / C Refrigerant High Pressure Switch (F118)
    a3 ECON mode selected
    b3 OFF selected
    c3 Outdoor (ambient) temperature too low
    d3 Engine management system (compressor will remain off for 3 -12 seconds)
    e3 High pressure has occurred more than 30 times
    f3 Ambient temperature sensor at Fresh Air Blower (G109) below
    27 oF (-3 oC)
    g1, g2, g3 System functions OK (g1 + g2 + g3 must be displayed in sequence - then
    system OK)
    The decimal point
    On - air conditioning compressor ON
    The decimal point
    Off - air conditioning compressor OFF
    Channel 53 codes - OBD - Status of electrical codes for system outputs
    When the electrical NO outputs are active, "88.8" will be displayed, will appear
    the alphanumeric codes below will be displayed. The decimal point at "88.8"
    is not displayed in this channel.
    Conditional part
    a1 Fan for internal temperature sensor
    b1 Fresh air / recirculation flap closed (recirculation mode)
    c1 Closed heating valve
    d1 Bi-directional cables
    e1 Air conditioning compressor ON
    f1 Radiator fan first speed ON
    a2 Air flow flap open
    b2 Air flow flap open
    c2 Airflow flap closed
    d2 Leg flap / defroster in leg position
    e2 Leg flap / defroster in leg position
    f2 Footwell flap / defroster in "defroster" position
    a3 Central flap in "central air supply" position
    b3 Central flap in "central airflow" position
    c3 Central flap in "legs / defroster" position
    d3 Temperature flap in "cold air" position
    e3 Temperature flap in "cold air" position
    f3 Temperature flap in "warm air" position
    system OK)
The discussion revolves around hidden functions of Audi's Climatronic system and user experiences related to an auction listing on Allegro. Users express difficulty in finding detailed information about these functions. One participant suggests using VAG (Volkswagen Audi Group) diagnostic tools to identify air conditioning issues, while another shares specific diagnostic codes and methods to change temperature display units between Celsius and Fahrenheit. The conversation also touches on troubleshooting air conditioning problems, emphasizing that issues may not always be due to refrigerant levels.
