Audi a4 b6 2004 air conditioning warm on one side and cold on the other!
Funcar 5964 2
  • #1 16352009
    Funcar
    Hello ! I have a big problem with the audi a4 b6 2004 1.8 turbo. So I set it to "LO" and there is cool cold air from the driver and the air is very hot from the passenger. Fluids topped up with new oil and still cold from the driver, and the passenger says too hot. I remind you that it is set to 'LO'. Also on temperatures 18, 19, 20 etc. it is the same. Please help!
  • #2 16352324
    123nowy
    Help: 55
    Rate: 101
    Make an error reading on the climate, most likely one of the motors failed at the initial settings
  • #3 16356714
    Funcar
    I will check
