Elektrolux EHS60300P Ceramic Hob: Error E8, No Field Works, Seeking Service Codes & Explanation
valkyrie 47430 3
  • #1 14248896
    valkyrie
    Rate: 50
    The Elektrolux EHS60300P ceramic hob has stopped working while cooking. Display error E8.
    No field works.
    Momentarily disconnecting the power in 2 phases does not help.
    Does anyone have access to Elektrolux service codes and is able to explain the topic?
  • #2 14250890
    peter falk
    Home appliances specialist
    Help: 1158
    Rate: 3364
    No communication between modules. Look for cold solders - first on the interface.
  • #3 14251154
    valkyrie
    Rate: 50
    Further work is done after Christmas.
    After a few hours, the left side of the plate is working, the right side is not working.
    On the right side, the recognition of the pots works, you can set the power, but it does not heat. It does not display errors
    Now you have to survive with what is.
  • #4 14329093
    valkyrie
    Rate: 50
    As the topic was not very popular and I wrote to the mirror for some time, I decided to delete the posts and make one of them.
    E8 - this is the lack of communication between modules as "peter falk" wrote earlier.
    When the hob cooled down, the error disappeared, but the right cooking zones did not work.
    It was possible to control the right fields, the vessel presence sensor was working, even after the program was turned off, the fields that were not working showed a warning about the hot field "H", even though the field was cold. I checked the cooking zones, resistance OK (30-60 ohm)
    I found the damage on the so-called HOC2000 power module.
    Two relays (blown contacts) responsible for the basic heating windings on the right panels were damaged.
    Original RT314012WG 12V 16A / 250VAC relays have been replaced with HF115F-012.
    After replacing the relays, the board works.
    The error numbers that I found in the documentation
    E-0 Config_Data_ALM_HC Wrong Configuration on HC / EEPROM checksum failure
    E-1 TEMP_CoolBlock_ALM_L
    E-2 TEMP_CoolBlock_ALM_R
    E-3 Phase1missing_L Phase not detected on powerboard
    induction Left
    E-4 Phase2missing_R
    E-5 CommErrorPowerBoard_L Internal Ind.Bus error / missing
    connection / 12VDC or 5VDC missing
    E-6 CommErrorPowerBoard_R
    E-7 Temperature probe coil Error of min. 1 cooking zone (see alarm codes message def.)
    E-8 Communication error to power board
    E-9 Config_Data_ALM_HUI HUI received invalid configuration
    Link to the document I was using.
    http://www.4mcculloch.co.uk/images/mediator/559/599516232.pdf
