#1 16613714 28 Jul 2017 18:47 Krystian samsel Krystian samsel Level 2 Posts: 2 Rate: 48 » | Topic author Post #1 16613714 28 Jul 2017 18:47 Hello. On the Bosch PIE631FB1E induction hob the letter E appeared in each field. After pressing this letter shows the code 513, does anyone know what has broken down?
#2 16736960 04 Oct 2017 09:41 bartek_duszynski bartek_duszynski Level 11 Posts: 6 Rate: 42 » | Positive voted Helpful post? (+42) Post #2 16736960 04 Oct 2017 09:41 Hello, have you found out what this error means. I have a similar error on my disc, but on 2 of 4 fields.
#3 16784081 28 Oct 2017 08:51 Beakob Beakob Level 1 Posts: 1 Rate: 18 » | Positive voted Helpful post? (+18) Post #3 16784081 28 Oct 2017 08:51 Hello, I have the same problem, can you help me?
#4 16785032 28 Oct 2017 17:27 Barthezz1976 Barthezz1976 Level 19 Posts: 254 Help: 24 Rate: 164 » | Positive voted Helpful post? (+12) Post #4 16785032 28 Oct 2017 17:27 Beakob wrote: Hello, I have the same problem, can you help me? Replace the right power module or repair (although if you ask, I suspect you have no idea what the number of posts also indicates).
