Electrolux EHD60020P Induction Hob: Error E9, Flooded, DIY Repair & Error Code List
t.sat 74637 4
  • #1 13593732
    t.sat
    Rate: 11
    Electrolux EHD 60020 P induction hob - error E9
    Hello, the disc, as in the title, was flooded, after maintenance it worked without faults for a period of 4 months. Currently error E9 after power off. I am asking for information on error E9 and whether it can be repaired without service. I am looking for a list of error codes for Electrolux induction hobs.
  • #2 13865655
    ryszardjames1
    Rate: 15
    Try to disconnect the device from the power supply for some time, if it does not help, the touch control panel is damaged.
  • #3 13947204
    misq
    Rate: 26
    did you fix it?
    yesterday in my board there was the same problem: / on the touch panel I found one resistor where there was slight corrosion, I soldered it and it worked for a few minutes, so I cleaned the whole panel well and it worked until the end of the day, the next E9 again. I will probably transfer everything, it may help
  • #4 14929662
    mariusz kania
    Rate: 28
    Today I had the same problem - probably the VIPER17L chip to be replaced ...
  • #5 14929741
    misq
    Rate: 26
    I finally cleaned the panel at home, soldered most of the elements and it still works without any problems :)
