TOSHIBA Satellite L755-13J - "the firmware has detected that a cmos battery
Raphy77 4353 3
  • #1 14251281
    Raphy77
    Rate: 16
    My problem is the lack of settings for the BIOS.
    After pulling the battery out for a few minutes, the BIOS logo and menu with F2 will appear when you turn on the laptop. After pressing F2 I get the message "the firmware has detected that a cmos battery failure occurred" after which a flashing cursor appears.
    I checked the batteries on another laptop and it's working.
    Please for suggestions, advice on how to remove this problem
    Greetings and Wesolych Swiat I wish You all
  • #2 14251310
    helmud7543
    Help: 1216
    Rate: 1563
    The latter, if it appears after removing the battery, is normal (finally the battery removed is no battery / low voltage, etc.). Unless you write about a laptop battery and not a cmos. Exactly - what voltage does the CMOS battery have?
  • #3 14251312
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1538
    Reprogram the bone.
  • #4 14251429
    Raphy77
    Rate: 16
    ... he writes about removing the battery for a few minutes and restarting the laptop after putting it back in. The battery has a voltage of 3.08V
    Added after 22 [minutes]:
    yes, it will reprogram the BIOS as soon as the ordered programmer is received.
