GT Golf Side Turn Signals: Inspection Requirement, Placement & Passing Technical Inspection
tomekjak 31501 13
Does a Volkswagen Golf need factory-fitted side turn signals to pass inspection, and where can they be installed if a trailer hitch requires them?
A Golf does not need side turn signals for inspection if they were not fitted by the manufacturer. [#1480204] [#1480768] [#1482889] If a trailer hitch is recorded or installed, side indicators become mandatory. [#1480204] [#1764796] In that case, indicators mounted on the exterior mirrors are accepted in practice, provided the required mirror equipment is present. [#1480204] [#1480822] Without a hitch, the owner generally does not need to retrofit indicators, but contacting the inspection station beforehand can resolve any local interpretation.
  • #1 1479689
    tomekjak
    Rate: 14
    There are no side turn signals on my GT golf, only the GT badge. I heard that the car must have side blinkers or it will not pass the inspection. I have a review in a month and therefore I have a request if someone could explain to me how it really is with these blinkers. Do they have to be? When I bought this golf, it was already inspected, registered and the owner said that there was nothing like that during the inspection. And if there must already be a side indicator, can it be attached to the mirrors or to the side of the bumper? Thanks.
  • #2 1479809
    tadeuszgr
    Help: 7
    Rate: 54
    Mandatory
    car yellow
    along the length: on both sides; the distance from the front edge cannot exceed 1800mm
    at the height: 500-1500mm
    Legal basis :D Journal of Laws No. 32 item 262 of 2002.
    (this is what I have at my disposal, maybe I haven't checked something newer)
  • #4 1479921
    grzesiek_nysa
    Help: 61
    Rate: 57
    So why when I did a review in my golf in July last year, when I brought it, nobody added to me that I do not have side directions? were mandatory.
    Regards
  • #5 1479934
  • #6 1480077
    Jerzy100
    Help: 45
    Rate: 84
    I confirm with this hook. If you have a hook in your ID card, side directions are mandatory. If you have any doubts or queries, contact the diagnostic station and ask before the inspection.
  • #7 1480106
    tadeuszgr
    Help: 7
    Rate: 54
    Mr. ELEKTRIT
    Are you not confusing with mirrors?
  • #9 1480768
    JariP
    Help: 6
    Rate: 21
    There is no obligation to install side turn signals if they were not fitted as standard in the car. The regulations make it compulsory to fit a rear fog light, and there is no mention of directions.
    No diagnostician will cause problems since they were not there before (it would be different if they were out of order and were installed).
    Regards.
  • #10 1480822
    rito
    Help: 7
    Alternatively, if you have a hook, they can be on the mirrors, there is no problem with that in my omega, I put the hook on and went to the inspection and the diagnostician told me that I had to have side directions, I put them on the mirrors and everything was ok.
    Regards
  • #11 1481260
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    Heh!
    And there are front directions that extend so far over the fenders that they have two approvals: front and side! But if you go to the SKP and ask, then obviously on the lowest resistance line: there is a hook - they must be sideways! And nobody bothers themselves - bureaucracy and demonstrating your diagnostic power is essential!
    Kisses
    Slawek J
    Level 30  
    Help: 119
    Rate: 170
    Vilswagens, these poorer versions did not have indicators on the side, even passats until 1993 did not have all. If you did not have, you do not have to do it, it is exactly like the seat belts on the back seat, if they are not installed in the factory, the owner does not have to put them on either.
    maestro11
    Help: 12
    Rate: 18
    Side directions are obligatory (in Poland) if a hook is installed, if you don't have one, you have nothing to worry about. I don't have a hook and side directions and in 5 years no one even mentioned them.
  • #14 1984288
    tomekjak
    Rate: 14
    All answers have been confirmed. Subject to be closed.
The discussion centers around the requirement for side turn signals on the GT Golf, particularly in relation to vehicle inspections. It is clarified that side indicators are mandatory only if the vehicle is equipped with a towing hook. If the car was not originally fitted with side turn signals, they are not required for inspection. Several participants confirm that if the manufacturer did not install them, the owner is not obligated to add them unless a towing hook is present. In such cases, side indicators can be mounted on the mirrors. The conversation references legal regulations and personal experiences regarding inspections and modifications.
