Volkswagen Golf MK7 - modification of the rear lights installation
piotrekpiwi 13425 14
How can I wire and code post-facelift Volkswagen Golf 7 full-LED rear lights so the brake light does not get a higher voltage than the parking light?
You need to adapt and code the light channels in the BCM for the installed lamps, rather than trying to feed the brake LED with a higher voltage like a dual-filament bulb. The thread’s practical advice is to use the correct wiring diagram for the lamps you bought and then change the settings in adaptations so the lamp behavior matches the original function [#16808523] A Ross-Tech light-configuration reference was pointed to for the relevant adaptation channels [#16808523] Another reply also recommended coding the BCM for LEDs [#16807770]
  • #1 16807511
    piotrekpiwi
    So in short, in Golf 7 I wanted to have the back of the lamp from the version after the lifts, not matrix 3D but the usual full LED from the basic version. So I already have lamps, but there is another installation. Namely:
    The issue of plugs (completely different) to skip because the lamps will be connected by connecting the cables permanently. The problem is more serious. The new lamps have a brake light separately (separate led responsible for the stop). As the old lamps have a stop and stand in one cable (two-filament light bulb), there is a problem how to connect it. I could plug the stop light from the new lamp into the middle (additional) stop signal, but this does not solve the problem because after pressing the stop the lights illuminate with stronger light, and this should not be because it is not so in the original and I suppose that the leds that get a higher voltage they won't last long. To sum up, I would like to have one voltage in parking spaces, i.e. after pressing the stop pedal they would not get a higher voltage, as was the case with non-LED lamps, in which the stop was solved by a double-filament lamp.
    I will be grateful if someone will tell you how to solve it
    Thank you very much in advance :)
    Greetings, Piotrek
  • #3 16807562
    piotrekpiwi
    Yes, I read, but it has nothing to do with my problem, because I assume original homologated LED lamps.
  • #5 16807878
    piotrekpiwi
    Unfortunately, the cited link only raises the issue of burnt bulb error. For me, there is no problem, because the computer does not display the error of a burnt bulb after connecting the LED lamps.
    Added after 9 [minutes]:
    I thought about such a solution as a system plugged into the position lights signal, which at a certain voltage would cause that voltage would reach the stop lights. Can this be done? If so, how to make it as simple as possible? There is also the issue that with this particular parking voltage they could not, of course, light up ... I admit that I'm green in this, so I don't even know how to search the Internet for information on such a solution. Thanks in advance :)
  • #6 16808346
  • #7 16808363
    piotrekpiwi
    The problem is that I do not have any diagrams because I have not found anywhere this type of processing on the Internet. All I've found are the installation of led lights before lifting (from gti) or led lights after lifcie but matrix 3d. In my case it is a completely different matter, I think, because only the problem of stopping is a problem. All the rest, i.e. parking fog indicators work as it should.
  • #8 16808405
  • #9 16808453
    piotrekpiwi
    What will the scheme from golf vii to lifcie give me where the electrical installation is completely different? There is probably only one voltage there.
  • #10 16808463
    andrzej20001
    Help: 1578
    Rate: 6669
    Diagram of a car from the lamps you bought. They're not just golfing since coughing, are they? Make the connection cold and ready
  • #11 16808465
    piotrekpiwi
    Can you lighten it with a cold?
  • #12 16808481
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    piotrekpiwi wrote:
    The problem is that I don't have any diagrams
    Now it's your turn to paste it on the internet. And you are an electrician because I don't think so, because simple things are going very slowly.
  • #13 16808490
    piotrekpiwi
    I am not an electrician, I am far from being an electrician. It probably doesn't bother using this forum?
  • #14 16808505
    Help: 1405
    Rate: 6430
    Of course not.
    But groundless burying in the installation and its modification without a clue is beeee.
    And nobody questions here.
  • #15 16808523
The discussion revolves around modifying the rear lights of a Volkswagen Golf MK7 to install full LED lamps from a later version. The user faces challenges with the wiring, specifically the different plug configurations and the need to connect the brake light separately, as the original setup uses a dual-filament bulb. Suggestions include adapting the coding for the new LED lights and obtaining wiring diagrams for proper installation. The user expresses difficulty in finding relevant diagrams and seeks advice on how to achieve a safe and effective connection without risking damage to the LED lights due to incorrect voltage. Several participants recommend consulting with professionals or using existing resources for BCM adaptation and wiring schematics.
TL;DR: MK7 pre-facelift uses a 2‑filament bulb for tail/stop, while MK7.5 full‑LED rears split them; “the new lamps have a brake light separately.” Solve it with wiring per diagram and BCM adaptations, not voltage tricks. [Elektroda, piotrekpiwi, post #16807511]
Why it matters:** This FAQ helps Golf MK7 owners retrofit MK7.5 basic full‑LED rear lights cleanly, avoiding errors or BCM damage.
Can I fit MK7.5 basic full‑LED rear lights on a pre‑facelift MK7 without errors?
Yes, the swap is feasible. Users report no burnt‑bulb error after connecting LED rears. You must still wire functions correctly and verify coding. Do not rely on voltage‑boost tricks to mimic dual‑intensity; map brake and tail to separate outputs. Test each function—tail, brake, fog, indicators—before closing trim. If your cluster flags an error later, address diagnostics in BCM adaptations. [Elektroda, piotrekpiwi, post #16807878]
What’s the key wiring difference I must handle?
Pre‑facelift halogen clusters combine stop and tail on one two‑filament bulb. MK7.5 basic full‑LED clusters separate stop and tail onto different inputs. Plan for separate BCM outputs to each function. This split is the root of the brightness/overvoltage confusion when retrofitting. Wire and code for distinct channels instead of feeding one line at two voltages. [Elektroda, piotrekpiwi, post #16807511]
Do I need BCM coding, and which settings control the rear lights?
Yes. Use BCM adaptations to assign each rear function to its proper output. Volkswagen labels these as “Leuchte” channels. Map tail to a constant‑brightness channel and brake to a dedicated high‑intensity channel. As one expert put it, “you change it in adaptations.” If coding alone won’t achieve it, consider BCM variant differences. [Elektroda, 1769758, post #16808523]
Is there a plug‑and‑play harness, or do I have to hardwire?
Connector shells differ between MK7 halogen and MK7.5 LED lamps. You can repin or build a short adapter loom following the target lamp’s diagram. Avoid permanent splices until you confirm each pin’s function with the schematic and a multimeter. Correct pin‑to‑pin mapping matters more than connector style. [Elektroda, piotrekpiwi, post #16807511]
How do I stop the tail lights from brightening when I press the brake?
Do not feed more voltage to the tail circuit. Instead, separate the functions in BCM adaptations. Assign the tail to a steady channel and route the brake to its own channel. This replicates factory MK7.5 logic and preserves LED life. The fix lives entirely in the adaptation tables. [Elektroda, 1769758, post #16808523]
Can I use a voltage‑sensing module to trigger the brake LEDs from the tail signal?
Skip voltage‑sensing add‑ons. They often cause unintended brightness changes and do not match factory behavior. Properly wired MK7.5 LEDs expect distinct control lines. Use BCM “Leuchte” adaptations to define the stop lamp separately. This keeps tail light brightness constant and engages brake LEDs only on braking. [Elektroda, 1769758, post #16808523]
Do I need to replace the BCM for this retrofit?
Usually, coding is enough. Enter adaptations and remap the rear functions to available outputs. If your specific BCM lacks necessary channels, a BCM variant swap may be required, but try coding first. The recommended order is wiring per diagram, then adaptations, then hardware only if blocked. [Elektroda, 1769758, post #16808523]
Where can I get the correct wiring diagram for the MK7.5 LED rears?
Get the official wiring diagram for the specific lamp part numbers. Your local VW dealer (ASO) can print the relevant pages. Bring VINs or lamp part numbers to ensure accuracy. Work from the diagram, not guesses, before any adaptation work. [Elektroda, 1769758, post #16808405]
What is the BCM and what are “Leuchte” channels?
The Body Control Module (BCM) manages exterior lighting outputs. Volkswagen exposes function mapping via “Leuchte” adaptation channels in diagnostic tools like VCDS or ODIS. You assign each light function—tail, stop, indicator—to a channel with defined behavior. This mapping implements the MK7.5 separation cleanly. [Elektroda, 1769758, post #16808523]
What’s the risk if I miswire or bypass coding?
Miswiring or forcing shared circuits can overdrive LEDs and strain the BCM. A seasoned member warned that the BCM can suffer and “you will cry.” Protect the module by following the diagram and adapting channels, not by piggybacking voltage. This is the critical edge case to avoid. [Elektroda, 1769758, post #16808346]
Will overvolting shorten LED life in these lamps?
Yes. The MK7.5 LED stop and tail are designed as separate functions. Feeding higher voltage to make the tail brighter on braking deviates from factory logic and can reduce LED lifespan. Use distinct control lines and coding instead of dual‑intensity hacks. [Elektroda, piotrekpiwi, post #16807511]
How do I handle bulb‑out errors after the swap?
Some cars show no bulb‑out errors after connecting LED clusters. If no error is present, no change is needed. If an error appears later, adjust lamp diagnostics in the BCM adaptations for the affected channel. Address coding only when you see a fault. [Elektroda, piotrekpiwi, post #16807878]
Can I feed the brake LED from the center high‑mount stop (CHMSL) line?
Avoid that approach. It can make position lights brighten under braking and diverges from factory behavior. Keep the CHMSL on its dedicated circuit and code the rear brake LEDs via their own outputs. This preserves consistent tail brightness. [Elektroda, piotrekpiwi, post #16807878]
What quick steps should I follow to wire and code MK7.5 LED rears?
  1. Obtain the MK7.5 lamp diagram and map each pin to tail, stop, fog, and turn.
  2. Repin or build an adapter to match the MK7.5 pinout, then verify with a multimeter.
  3. In BCM adaptations, assign each function to its proper Leuchte channel and test. [Elektroda, 1769758, post #16808346]
Do I need special tools or software for coding?
Use a diagnostic interface compatible with VW MQB adaptations, such as VCDS, ODIS, or similar. Access the BCM adaptation list and edit the relevant Leuchte channels. Save original settings before changes so you can revert if needed. [Elektroda, 1769758, post #16808523]
What if I can’t find a DIY guide for my exact lamp version?
Work from the exact wiring diagram for your purchased lamps, not from a different trim. The principle remains: separate stop and tail, then adapt channels. If unsure, have a dealer or specialist handle wiring and coding to factory spec. [Elektroda, andrzej20001, post #16808463]
