How to connect Lantick PE-2-2 LAN relay to hallway light and 2nd switch?
zduni 1764 0
  • #1 14346271
    zduni
    I am in the process of designing the installation and therefore have a few questions.
    question one:
    The ceiling light in the hallway is controlled by a switch on the wall as standard.
    I would like to be able to control this light also
    - when I am not at home, e.g. using a relay module controlled via LAN lantick PE-2-2, and also from another (second) wall switch.
    The question is how to connect this so that it works properly. Do I need a bistable relay or can it be done more simply (staircase, cross?).
    The second question concerns the same LAN lantick PE-2-2.
    I would like to be able to remotely switch off the electricity in the whole house or e.g. on the first floor. What should the installation look like to make this possible. Will I need another more powerful relay (three-phase?).
    I am a builder without much knowledge of the subject so don't hang dogs....
