faac XT4 868 SHL LR remote control - One remote control for controlling 3 devices
Malwina 1980 3222 4
  • #1 14376077
    Malwina 1980
    Hello!
    I would like to ask which lighting control unit I should buy to control the lighting of outdoor lamps on a Faac XT4 868 SLH LR remote control. I have a Faac GBat 300 door set with a 455 D control unit and RP2 868 SLH radio receiver, and a Faac D600 operator also with the 868 SLH system and XT4 868 SLH LR remote control for the garage, and I would like to control all the devices with one remote control.
    I was thinking of the Zamel RZB - 04 set but it works.
    Please give me a hint how to solve this.
  • #3 14395702
    Malwina 1980
    XR2 868C powered 12/24 where do I connect it as I have 230 volts at the lamps. What is the 230 volt external relay. Can you send me a diagram or something. I'm just learning so it may seem trivial, but I can't seem to understand it.
    Jarmie
    Help: 10
    Rate: 70
    Radio and relay supplied from e.g. garage door drive, the radio uses NO contact (bistable operation) to switch a relay, e.g. PULSAR AWZ517 PU1/HV/24V, which controls 230 V lamps. Pressing the button on the remote control switches the lighting on, another press switches it off.
  • #5 14399376
    Malwina 1980
    Thanks a lot! It seems simple now.
