Audi A4 B7 – how to distinguish Multitronic from Tiptronic by eye?
ravelation 69774 10
How can I tell from photos or an ad whether an Audi A4 B7 has Multitronic or Tiptronic transmission?
You usually cannot tell with certainty from photos alone; the most reliable check in an ad is the VIN, and Multitronic was used only with front-wheel drive, never with Quattro [#14439891][#14440847] From interior photos, the gear lever can help because the Tiptronic selector looks different from the Multitronic one [#14441290] Even so, not every FWD Audi has Multitronic, so drivetrain alone does not prove the gearbox type [#14440847]
  • #1 14429807
    ravelation
    Help: 27
    Rate: 164
    Hello, there has been a lot of talk lately about the failure rate of multitronic transmissions in Audi, but whether there were tiptronic in the b7 and how to distinguish it by the external appearance (wajchy, etc.)
  • #2 14439817
    ravelation
    Help: 27
    Rate: 164
    So it turns out that it is impossible to distinguish a tip from a multi?
  • #3 14439841
    arewin
    Help: 33
    Rate: 198
    The easiest way when driving, in Tiptonic, you can feel the gear change, in the second case there is a feeling of "slipping clutch"
  • #4 14439880
    ravelation
    Help: 27
    Rate: 164
    but I mean the pre-selection of online advertisements.
  • #5 14439891
    arewin
    Help: 33
    Rate: 198
    you can ask the seller for a Vin number.
  • #6 14440847
    yarecki16
    Help: 20
    Rate: 62
    In addition, it is worth remembering that the multitronic transmission was not used in cars with a 4x4 drive, i.e. Quattro. Multitronic was used only with the front wheel drive, but at the same time not every FWD is Multitronic.
  • #7 14440917
    ravelation
    Help: 27
    Rate: 164
    I have VIN NP. WAUZZZ8E76A159597 And what next?
  • #8 14441290
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    And that this silver Audi is a multitronic. Audi A4 B7 – how to distinguish Multitronic from Tiptronic by eye?
    Added after 8 [minutes]:
    And this is the tiptronik gear lever: Audi A4 B7 – how to distinguish Multitronic from Tiptronic by eye?
  • #9 14441560
    ravelation
    Help: 27
    Rate: 164
    Did you know this from the wine or from the photos?
    To sum up: multitronik- there is no number-emergency-avoid?
  • #10 14441593
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    I recognized it from photos. With this mileage (if real), I would rather not buy. Multitronik is cool to 180,000 - 200,000,000.
  • #11 14441643
    ravelation
    Help: 27
    Rate: 164
    But which car has 200,000?
    I think in the otomoto advertisement,
    Then what happens?
    And how much does it cost?
The discussion revolves around distinguishing between multitronic and tiptronic transmissions in the Audi A4 B7 model. Users express concerns about the failure rates of multitronic transmissions and seek visual identification methods. It is noted that multitronic is not used in Quattro (4x4) models and is typically found in front-wheel-drive vehicles. Suggestions for identification include checking the VIN number and observing the gear lever design. Users also share insights on the driving experience differences between the two systems, with tiptronic providing a more tactile gear change compared to the multitronic's "slipping clutch" feel. Concerns about the reliability of multitronic transmissions, especially over high mileage, are also discussed.
