A4 B8 Multitronic Transmission Oil Change Guide: Replacing Oil, Filter, and MMi Panel Info
dominooo 29439 7
  • #1 17350837
    dominooo
    Hello all.
    I have a question regarding my furki. I recently purchased an A4 B8 with a multitronic automatic transmission. I have to replace the oil in the box. And now the question is how? any instructions, notes, etc.? Mechanics, burying cars is not strange to me, but the first time I do it in the machine and I would like to do it properly. From what I found out the external filter is not there (box with the designation LLA) so I only exchange oil. And what to use? The original ATF or as I heard Revanola CVT flooded because it is supposedly good and meets the standards of the original ATF. When replacing, do you need to do some box calibrations, etc.?
    I am asking for all information and tips, I will be very grateful.
    By the way, without assuming a new topic, does anyone have a pin header deployment from the MMI panel? mainly I mean the pins responsible for the backlight, or maybe someone to look at their packs which cables on which pins are responsible for panel illumination?
  • #2 17354333
    Michal2002
    Help: 18
    Rate: 180
    I made such a chest and if you do not want to look for another oil, it's only the original.
  • #3 17358747
    dominooo
    Michal2002 is your chest damaged by the original oil? Did you do the oil change yourself or did you return to the service / workshop somewhere?
  • #4 17369250
    Michal2002
    Help: 18
    Rate: 180
    The treadmill is running in, do not take any chances because the parts are horribly expensive. Although I did it 10 years ago, but little has changed in the subject. I did it myself, so if you have to exchange anything, it's better not to mention it at all.
  • #5 17440993
    Zuykacz
    RAVENOL just what? congratulate knowledge on the subject
  • #6 17443728
    Michal2002
    Help: 18
    Rate: 180
    Dextron is just what - specifically this oil I had in mind - this chest is not suitable.
  • #7 17452558
    dominooo
    that I heard about Dextron that it is not recommended, that is Ravenol can be flooded into this chest?
  • #8 17460167
    Michal2002
    Help: 18
    Rate: 180
    I had such experiences as I wrote, I flooded the original because I was afraid that there will be problems, especially that one set - chain and treadmills I had to throw in the trash ...
    https://motofocus.pl/informacje/nowosci/13823/kolejne-procedury-dolaczane-do-olejow-ravenol
    It seems that they are applying - the question with what effect - immediately there will be no problems asking what will happen after 50,000 km ...
The discussion revolves around changing the oil in the multitronic automatic transmission of an Audi A4 B8. The user seeks guidance on the oil replacement process, including the type of oil to use, whether to opt for original ATF or alternatives like RAVENOL CVT. Participants emphasize the importance of using original oil to avoid potential damage to expensive components. Concerns are raised about using Dextron oil, which is deemed unsuitable. Additionally, the user inquires about MMI panel pin header deployment, specifically for backlight connections, indicating a need for technical assistance in that area.
