Audi A4 B8 2.0 tdi - does not start after the spacer from the multitronic
kkriss26 10647 12
How do I make an Audi A4 B8 2.0 TDI start correctly after converting from Multitronic to a manual gearbox, including ECU coding and the starter/brake-switch wiring?
You need to redo the starter relay wiring for the manual setup, because it is connected differently than on the automatic [#16567719] The engine ECU should communicate even without the gearbox controller, so if VCDS cannot see it, check the ECU power supply and CAN wiring first; in this case one CAN wire was found damaged [#16567667][#16574677] If the car still reports that the selector must be in P or N, the manual/automatic logic is still not sorted out in the ECU or related wiring [#16574677] The thread also notes that VCDS coding changes were rejected with seed/key and out-of-range errors, so a simple recode was not enough [#16574677] For EDC17, the suggested solution was a full backup and then an ODIS-E overflash with software from a manual gearbox ECU, followed by coding [#17973787][#18060402]
  • Brake switch logic reversed after multitronic spacer install
    #1 16565257
    kkriss26
    Hello, I am after the multitronic spacer for the manual in A4 B8, the clutch sensor and the reverse sensor was connected according to the diagrams Audi A4 B8 2.0 tdi - does not start after the spacer from the multitronic Audi A4 B8 2.0 tdi - does not start after the spacer from the multitronic
    Now I have a problem with starting the meter, a message is displayed to start the engine, switch the levers to P or N. So it would be necessary to transcode the engine ecu and here the problem arises because I cannot connect VCDS with the engine with the rest of the devices connects without a problem, I also noticed that The stop light now shines when the brake pedal is not pressed and when it is pressed, the stop light goes out. Maybe one of you is able to help me with a hint, I would be very grateful
  • #2 16566823
    KMAuto-Klinika
    Rate: 18
    gearbox controller connected or disconnected? Communication is probably going through the gearbox control unit.
  • #3 16567042
    kkriss26
    The box controller is in the box is also disconnected
  • #4 16567667
  • #5 16567719
    buncza
    Help: 10
    Rate: 94
    In the manual, the relay from the starter is connected differently - you have to redo it.
  • Requesting manual ECU coding for 2.0 TDI CAGA
    #6 16574677
    kkriss26
    Communication with ECU has been repaired, one of the can cables has been damaged. Now the car fires but still on the counter there are messages to switch the gear levers to P or N. To remove the keys from the ignition I had to make a bridge on the 4-pin plug that was connected to the jack from the multitronic. I tried VCDS to change the engine encoding, but in security Access, when I enter the code from the prompt, the controller refused to send a seed! Error 7f service not support in active session and when I enter coding and change into byte 04 to transmission manual click Do it! it crashes coding rejected Error 31 request out of range. A colleague says now to arrange the batch from 2.0 tdi CAGA manual and upload it.
    Hence the request for the ecu charge of the 2.0 tdi Caga manual engine
  • #7 16744033
  • #8 16771362
    kkriss26
    From the mechanical side, as for the spacer, everything is practically done, communication with the ECU and the rest is ok. As of today, the car fires and drives, but I still cannot cope with the recoding to the manual. Another thing that I did not write at the very beginning, this is the multitronic spacer on the manual quattro ABS pump is changed from quattro, the fuel pump and the tank also from quattro, so there is also the ABS pump and meter coding. But first I would like to tidy up the ecu.
  • #9 17972868
    LoLek85
    Help: 86
    Rate: 303
    kkriss26 Did you cover the topic to the end?
  • #10 17973787
    damdam
    Help: 274
    Rate: 950
    in EDC17 it's not that simple. first full backup and then over-flash ODIS-E with soft from manual, coding, and there is a chance.
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #11 18058097
    inhoss
    Rate: 36
    Anyone know something and help? I am in the process of changing from multitronic to manual on a4 b8 CAGA. What equipment can the ECU be reprogrammed into a manual gearbox and is it possible? What other drivers are still to be recoded?
  • #12 18060402
    damdam
    Help: 274
    Rate: 950
    the easiest way is the post above, throwing a full backup from the manual driver with tuning equipment will not necessarily be easy, due to OTP and various PowerClass.
  • #13 19323864
    alvaro155
    Kkris 26 did you have to bridge the relay? How so which one and what pins
The discussion revolves around an Audi A4 B8 2.0 TDI that fails to start after modifications involving a multitronic spacer. The user reports issues with the engine not starting and receiving a message to switch the gear lever to P or N. Various responses suggest checking the gearbox controller connections, ensuring proper ECU communication, and verifying the starter relay connections. The user later resolves some communication issues but still faces challenges with recoding the ECU to manual settings after changing components like the ABS pump and fuel system from a quattro model. Suggestions include performing a full backup and using ODIS-E for reprogramming the ECU to manual specifications.
