Replacement BC-500 cable for BMS controllers with RS-485 ports?
Mateo-22a 2412 2
  • #1 14449950
    Mateo-22a
    Hello, the manufacturer recommends using a BC-500 cable to connect the controllers (communication via RS-485 ports). In your opinion, can this be replaced with some other cable, e.g. twisted pair cat.6 FTP or some other?
  • #2 14459088
    Andrzej75
    You can use twisted pair (100 Ohm twisted pair), it is worth knowing
    UTP cat.5 node-to-node 250m, max. length of network segment 450m
    JY(St)Y node-node 320m, max. length of network segment 500m
    Belden 8471 node-to-node 400m, max. length of network segment 500m
    Belden 85102 node-to-node 500m, max. length of network segment 500m
    Regards
    Andrew
