Max Distance for Built-in Dishwasher Installation from Sink/Drain?
WSRH 73395 13
Can I install a built-in dishwasher about 1.5 m from the sink/drain, and is there a maximum hose or connection distance?
Yes — for the Bosch SPI53M25EU mentioned in the thread, the stated hose lengths are 165 cm for the supply pipe and 205 cm for the discharge pipe, so 1.5 m is within range without extensions [#14476129] There is no universal maximum drain-hose length given in the replies, but extending the factory hose is discouraged because small-diameter hoses can clog, joints can leak, and bends make buildup more likely [#14476078] One reply recommends running a 50 mm sewer pipe to the dishwasher with a 3% slope instead of extending the hose [#14475959] Another notes that Bosch manuals have shown hose extension up to a maximum of 2 m [#14476051]
  • #1 14475911
    WSRH
    Rate: 62
    Hello, gentlemen, I have a question regarding the installation of a built-in dishwasher with a visible front ... at what MAXIMUM distance from the sink / drain can the dishwasher be installed? In my kitchen, the only place I can put a dishwasher is 1.5m from the sink / drain ... that's why I ask for the distance of pipes / connections, is there any upper limit ...
    Darkdarkman
    Level 30  
    Help: 120
    Rate: 253
    In general, I would not extend the factory hose.
    With small diameters, such a long hose may get clogged after some time.
    Lead the 50 diameter sewer pipe to the dishwasher, keeping a 3% decline.
  • #3 14475969
    WSRH
    Rate: 62
    In fact, I will not do it ... I ask for orientation if there is any chance to install it at my place and if it is, how should I do it so that some pseudo-expert does not get me confused and did not do it so that after a month something will break ... .
  • #5 14475996
    WSRH
    Rate: 62
    I do not have a dishwasher yet, I am asking for orientation, i.e. I have chosen the model but I did not buy it, I wanted to know what and how, I would buy a dishwasher and it turns out that I will not connect it ...
    Bosch SPI53M25EU is the one I would like ...
    Now I look at the instructions for this dishwasher on the internet and nothing is max length ...
    wojtex1111
    Help: 39
    Rate: 69
    In any case, in the manual from Bosch they write like this, the quote: "In the manual it was written-drawn that you can extend the hoses up to a maximum of 2 meters", but when buying, you can look at the manual to be sure about this distance.
    So, at least in the past there was something about it.
  • #7 14476071
    WSRH
    Rate: 62
    So you say that you can connect? I just have to find a good specialist, what will it somehow get over?
  • #8 14476078
    Darkdarkman
    Level 30  
    Help: 120
    Rate: 253
    Because there is no such thing as the maximum permissible length of the drain hose.
    The drain hose, however, should not be extended.
    Once that, with each extension, there is a risk of flooding in the apartment (leakage at the joint, greater risk of damage).
    Two, the flexible hose does not make sense to keep the slope, and each bend point is a potential place for muck to collect.
    Three, if your pipe is clogged, you will push it through with a spring, if your hose is clogged, what will you do?
    Ergo - you can spare yourself potential problems simply in the world without combining.
  • #9 14476112
    WSRH
    Rate: 62
    I do not understand? you mean to give up the dishwasher?
    wojtex1111
    Help: 39
    Rate: 69
    You write about the Bosch SPI53M25EU dishwasher i
    In the manual (technical specifications), they state that:
    Supply pipe length (cm) 165 cm
    Length of the discharge pipe (cm) 205 cm
    Your 1.5m distance is within this range without the extensions.
    http://www.bosch-home.pl/produkty/zmywarki/zmywarki-do-zabudowy/45-cm/SPI53M25EU.html
  • #11 14476186
    WSRH
    Rate: 62
    Oh hell, I didn't see it, I admit ...
    is now the next problem, whether to take someone from the newspaper or from the rtv euro, where I will buy a dishwasher ...
  • #12 14476343
    wojtex1111
    Help: 39
    Rate: 69
    I thought so, that's why I corrected my post and added where to look exactly, i.e. technical specifications, I would take from the place of purchase and take care of the warranty matters, manufacturer's warranty 24 months, you can buy a year, while asking for knowledge, for example, what to look for in time using.
  • #13 14485921
    WSRH
    Rate: 62
    Gentlemen, yesterday I had a "spec" and said that it can be done, but you have to:
    - redo the drain
    - undercut the cabinets at the back
    -something there with the water supply
    -to carve with a cupboard because without it it will not come in
    asked for PLN 500 for this plus materials, is this a normal price?
The discussion revolves around the maximum distance for installing a built-in dishwasher from the sink or drain, specifically addressing a scenario where the dishwasher would be 1.5 meters away. Participants emphasize that while extending the factory hose is generally discouraged due to potential clogging and flooding risks, the Bosch SPI53M25EU model allows for a discharge pipe length of up to 2 meters according to its manual. The conversation also touches on the importance of proper installation, including maintaining a 3% decline in the drain pipe and ensuring that the installation does not compromise the kitchen's cabinetry. A professional installation is recommended, with one participant sharing a quote of PLN 500 for necessary modifications.
