Bosch SMV58M00EU – how to replace the dishwasher drain hose?
kubixkubix 55725 1
  • #1 12480624
    kubixkubix
    Rate: 48
    Cats chewed on the drain hose in the dishwasher, so I took up the challenge of replacing it myself. I have read in another thread that the replacement is simple.
    I unscrewed the side sheet metal and my eyes saw the view as in the attached photo. In addition, from the back, where both hoses (drain and inflow) enter, I managed to remove a small flap through which you can push your hand a bit inside. However, I do not really have the option to remove the end of the hose because I am limited by plastic (in the photo it is the first hose from the left).
    Any tips for the beginner? Thank you in advance and best regards to the forum members :)
  • #2 12484924
    kubixkubix
    Rate: 48
    It turned out that nothing else needs to be disassembled. It was enough to use more force, with a screwdriver, press a little against the ribs on the old hose and we managed to pull it out (it sucked a little, because water is stored in the tank when the dishwasher is turned off.
    Mounting was easier, though the screwdriver and snake ribs were also useful :)
