Ditec CROSS - wireless control from the Satel Integra control panel
franky_furbo 1704 2
  • #1 14477048
    franky_furbo
    Welcome,
    i am wondering how to solve the following problem:
    i want to implement the opening of a sliding gate driven by a Ditec motor using a remote control from the Satel alarm system. The problem is that the cable from the control panel is led into the garage and in order to extend it to the motor itself, it would be necessary to drill through the walls and dismantle the cube.
    Is anyone able to suggest a wireless solution?
    Regards
  • #2 14478334
    IGS
    Help: 44
    Rate: 61
    i do not understand the problem you describe
    why do you need to install a remote control receiver in the building you are writing about, in most drives there is enough space to install the remote control receiver you are writing about
    there is also generally 24 and sometimes 12 v for the power supply
    it is possible that you have not written everything and your alarm system has an integrated receiver working on the Integra bus
    if so, you buy a standalone Satel receiver compatible with your remote controls, install it in the drive, add the remote controls manually....
    specify type of remote control
    IGS teletechnika i automatyka obiektów
    Bażyńskiego 32 lok 12, Gdańsk, 80-312 | Tel.: 58 XXX XX XX (Show) | Company Website: www.igs-systemy.pl
  • #3 14510453
    luk9753
    Help: 63
    Rate: 147
    Or you buy a 2ch receiver e.g. elmesa and polot mtx and transmit the distance from the garage to the machine wirelessly.
