What pressure on the compressor when painting with a gun in HVLP technology
lukasz9891 58260 10
Can I use 6–8 bar compressor pressure for HVLP spray painting?
No—6–8 bar is too high for HVLP spray painting; the working pressure at the gun is usually around 1–3 bar, and one reply recommends setting the pressure reducer to about 2 bar [#14493272][#14496006] HVLP also needs high air flow, about 400 l/min minimum [#14497385] One reply notes that 2.5–3 bar is more typical of HP guns, not HVLP [#14497385] If you spray with a circular stream, reduce the amount of material and use a pressure reducer at the compressor or in the spray area [#14500677]
  • #1 14480943
    lukasz9891
    Rate: 22
    Hi. Is the pressure of 6 to 8 bar suitable for HVLP painting?
  • #2 14481191
    zdenek_zdenek
    Help: 62
    Rate: 326
    6 to 8 bar is too much even for HP technology. First, write down what kind of gun it is.
  • #3 14483851
    lukasz9891
    Rate: 22
    - EXPERT 2002 1.4 mm HVLP orange
    - some Auarita 2.0 mm green, this one is probably also in HVLP, but I am not sure
    The compressor turns on when there is 6.5 bar (or 6 with something), and turns off at 9.0.
  • #4 14493272
    mrtomjar
    Rate: 22
    Set the appropriate value on the pressure reducer (~ 2 bar, read carefully on forums), besides: High Volume Low Pressure - High efficiency, Low pressure.
    Do you use air tools on this compressor? If not, you can reduce the pressure range.
  • #5 14496006
    amarantus24
    Rate: 33
    Most often, the working pressure in HVLP pistols varies between 1-3 bar.
  • #6 14496157
    zdenek_zdenek
    Help: 62
    Rate: 326
    If you don't know something, you better not write.
  • #7 14496373
    amarantus24
    Rate: 33
    Justify the allegation.
    All the guns I have:
    Spray gun R-1007 HVLP max. 3 bars 1.4mm nozzle
    K - 887M HVLP max. 3 bar, nozzle 1,4
    LW 913 / HVLP max. 3.5 bar
  • #8 14497385
    zdenek_zdenek
    Help: 62
    Rate: 326
    These are not HVLP pistols, they are just cheap HP Chinese. 2.5-3 bar are HP pistols. Of course, we are talking about the input pressure. HVLP is max 2 bar and min 400 l / min.
    If you want to talk about the types of guns, write on the basis of recognized brands, because HVLP or another symbol can be placed on each product.
  • #9 14500385
    lukasz9891
    Rate: 22
    Expert 2002 K-506G / S 1.4 is in HP though, and Auarita H827W 2.0 in HVLP. Plasma is also attached to the compressor, which is sometimes used. I will ask, what will reducing the pressure give me? Painting with a primer is a bit difficult for me, because the paint drips off the surface too much, when I reduce the pressure, will it be better? I paint with a circular stream practically all the time. Is the difference in shade also the fault of too much pressure? For example, when I paint a large frame on one side (bottom), wait for it to dry, then turn it and drive on the other side (top).
  • #10 14500677
    zdenek_zdenek
    Help: 62
    Rate: 326
    With a circular stream, you need to reduce the amount of material. You must have a pressure reducer at the compressor, possibly on the wall of the room in which you "paint".
The discussion centers around the appropriate pressure settings for HVLP (High Volume Low Pressure) painting guns. A user inquires if a pressure of 6 to 8 bar is suitable for HVLP painting. Responses indicate that this pressure is excessively high, with optimal working pressures typically ranging from 1 to 3 bar for HVLP guns. Specific models mentioned include the EXPERT 2002 and Auarita guns, with recommendations to adjust the pressure reducer to around 2 bar for better efficiency. The conversation also touches on issues related to paint application, such as drips and shade differences, suggesting that reducing pressure may improve results.
