Refilling Empty Aerosol Paint Cans With Car Paint and Compressed Air—Is It Possible?
HONDACX 45657 16
Can an empty aerosol paint can be refilled with car paint and compressed air, and will it work with a hardener?
No—an ordinary aerosol paint can should not be refilled at home with car paint and compressed air; aerosols are normally filled with propane-butane or, in some cases, DME/dimethyl ether, and the can’s quantity and pressure are set by the manufacturer [#17116785][#13688871] Air is not used as a propellant because the oxygen it contains creates a safety risk, so aerosol containers are intended for inert gas rather than home injection [#13688871] If you want a refillable spray, use a can made for compressor filling and the matching paint system; some car-paint mixing plants can charge a previously gassed aerosol can with a special tool through the valve [#17116785][#17103913] Those systems are for paints formulated as 1K aerosol products with the proper solvent/hardener mix already inside, not for squeezing arbitrary car paint into an empty can [#17116785] The cited regulation allows aerosol cans to reach about 8–9 bar at +50°C and to withstand a 12 bar test pressure [#13688871]
  • #1 13677842
    HONDACX
    Rate: 114
    Recently, in the garage I found an old aerosol with WD-40 and unfortunately the preparation was in a can, but you couldn't spray it with it - no pressure.
    I had to dispose of this can, but I had an idea to use the contents in some way - for an insignificant undertaking. The idea was to squeeze compressed air and for this I put the tip of the pistol on the compressor and squeezed compressed air through the valve.
    It worked !!!!!!!!!!!
    I pissed out all the way to the end of WD-40 :idea:
    However, my question is of the same nature, however, regarding aerosol paints.
    Is it possible to squeeze new paint (car paint) into the can (after the old paint) and top it up with compressed air? Here I also have a question about a possible hardener - it is about drying the paint after it is removed from the can.
    Does it make sense and will it work - maybe someone has done such experiments.
  • #2 13677973
    c4r0
    Level 36  
    Help: 155
    Rate: 565
    Why not, I guess? You just have to be careful that it does not explode. The problem may be some difference in the old and new paint, or the dried up remnants of old paint in a can, valve, etc. And above all, the question is, is it profitable at all? Do the spray paint and the same in a regular can differ in price so much that it will pay off? Besides, I understand that it is a one-off or occasional adventure. Anyone who paints seriously does not use spray paints, but a gun anyway.
    With WD-40 there was no need to force air in, you could just cut the can open and use the liquid without the possibility of spraying. Sometimes it's a much more sensible method - you can buy WD-40 in this form.
  • #3 13678054
    HONDACX
    Rate: 114
    Yes - a one-off adventure, although it may or may not be left for later painting. :D
    The gun you say - yes, yes. Only this washing brings me despair. Using the can is faster and there is not always access to a compressor at home. My wife would go crazy if I was still keeping the compressor at home. :|
    Regarding WD-40, it was possible to cut the can, but I would deprive myself of the possibility of using the preparation after some time and, of course, spraying (spraying).
    I wonder what this paint is in the aerosol and what to use (car paint with a hardener or ordinary enamel like all cars used to be painted - probably enamel or acrylic - I don't remember what it was called).
    I usually use car paint with a hardener, but it goes to the gun.
    When it comes to profitability, there is nothing to talk about, an example.
    Primer paint in a can 0.75l - cost about PLN 18
    0.75l acrylic paint (the same as used in old cars - varnish) - cost about PLN 20.
    An aerosol can of any color, 450 ml - costs about PLN 12
    Filling a 300 ml can - cost PLN 6 (half the price of an aerosol)
    The spray can does not have 450 ml anyway - I checked only about 100-250 ml or even less (only varnish, paint with a solvent, of which a solvent is a significant amount). I checked it by evaporating the solvent. It follows that the paint substance itself is only a small amount.
    So - I think this fun pays off.
    However, one more question - is there compressed air in the aerosol or some gas (it is about maintaining the pressure and paint flowing out of the can).
    Let me mention that I stuff all the solvents into the aerosol and fill it with air, and then it's great for cleaning difficult places. I am not interested in the pressure either, because when it is going poorly, I refill the air and I can continue to work. I press 6 bar (I have this designation on the compressor) - that is, the maximum that will be enough and the solvent is poured into me. :D
  • #4 13678263
    c4r0
    Level 36  
    Help: 155
    Rate: 565
    I don't know much about paints and painting, so I can't discuss comfort or such matters :P
    HONDACX wrote:
    Regarding WD-40, it was possible to cut the can, but I would not be able to use the preparation after some time
    You can make a hole with a nail and pour the contents into another, closed container.
    Well, I guess every paint has a solvent, right? It doesn't matter if it's a regular can or a spray. Anyway, it would be tough. Maybe the spray has a little more solvent because the paint has to be thinner to spray it this way (the compressor gun works differently than the can spray).
    Probably some gas. When you use gas, you can be sure that it is cleaner than air, more reproducible, and the lack of oxygen in the mixture will at least not bother you.
  • #5 13678531
    HONDACX
    Rate: 114
    Preferably in the mouth and then sprinkle on the element. Also way. hahahahaha
    The paint has several ingredients including all kinds, solvents, extenders, pigments, oily compositions, fasteners etc. So ????
    This is the most substantive answer on this forum. Way to go ! Farting in 3-City is the best. hahahahahahahahah
    Maybe I'll wait for more constructive suggestions.
  • #6 13678817
    c4r0
    Level 36  
    Help: 155
    Rate: 565
    Okay, then I don't speak anymore ;) And will I get a diploma for the most substantive answer?
  • #7 13678892
    HONDACX
    Rate: 114
    Yes - the president's hug. :)
    I came up with an idea - I am implementing it now - as I will describe it. Of course, in the subject as befits.
  • #8 13679192
    saskia
    Help: 174
    Rate: 1086
    With that air in the can, a nice bomb could come out, especially at the end when the paint is running out.
    Let something catch fire while painting, you would have to look for the fingers holding the can on the walls.
  • #9 13680513
  • #10 13680550
    saskia
    Help: 174
    Rate: 1086
    Jerzykowski wrote:
    As far as I know the sprays are filled with butane so I don't know why the can filled with air should explode.
    Because it has a flammable mixture inside, air (oxygen) and volatile hydrocarbons, so it will propagate to the inside of such a can with a known effect.
    Do you know why you cannot, for example, weld fuel tanks without rinsing them thoroughly and filling them with, for example, nitrogen or CO2?
    The paint (solvents) or butane will only burn on the outside of the can, but if there is air (oxygen) in the can, the flame propagation will not stop on the sprayer, but will go inside.
  • #11 13680996
    HONDACX
    Rate: 114
    But nobody here will weld the paint can.
    Welding the fuel tanks - I have already done this - I covered them with sand and welded them - the handles are still in place. :)
    I am just wondering about the can explosiveness - as far as I know, there are 3 factors to meet for a fire or explosion to appear.
    In this case, rupturing the can under (air) pressure will not give an explosion effect, but only rupturing the can from excess pressure.
    From my experience - 6 bar - the can withstand calmly. I checked on an industrial compressor - up to 40 bar. The paint can began to change its shape - at 16 bar.
    So there is no danger - tearing the can.
    Muse to do one more experiment - how many "bars" has a factory filled can of paint. I just don't know how to do it yet - I have no connections. :(
  • #12 13688303
    saskia
    Help: 174
    Rate: 1086
    Have you heard anything about static charges?
    If not, read on.
  • #13 13688871
    Madrik
    Help: 627
    Rate: 1191
    HONDACX wrote:
    Muse to do one more experiment - how many "bars" has a factory filled can of paint. I just don't know how to do it yet - I don't have connections. :(
    It is very easy.
    1 - go to the website http://isap.sejm.gov.pl/
    2 - We turn on the search engine and look for:
    "Regulation of the Minister of Economy on detailed requirements for aerosol products.
    And there we are looking to what pressure the can should be filled.
    Depending on the capacity, this pressure cannot be higher than 8-9 bar at a temperature of + 50 ° C, and the can is to withstand a test pressure of 12 bar without changing the parameters.
    Knowing the pressure at 50 ° C and the capacity, you can easily calculate the pressure at room temperature.
    And air is not used for punching, because the oxygen contained in the mixture under pressure poses certain risks. Therefore it must be an inert gas. And propane-butane is used because it is the cheapest of the inert gases. It is post-production waste and the excess would have to be burned. And that's just how you use it for cans. The effect is the same, but some cash still falls into your pocket. :)
  • #14 17095562
  • #15 17097837
    Tommy82
    Help: 455
    Rate: 1074
    Concrete gas as a propellant is used in aerosols so that at the pressure in the can it is in a liquid state with all its consequences.
  • #16 17103913
    DecoDominik
    Rate: 96
    The cans suitable for filling from the compressor are ready.
    It's nice how much you paint with different paints and washing the gun every time is not worth it ... Or you need to have 10 guns and worry that sometimes one of them does not dry out.
  • #17 17116785
    pbkat
    Help: 5
    Rate: 80
    Most often, non-odorizing propane-butane is used as a propellant in aerosols. in exceptional cases there are other gases, e.g. DME or dimethyl ether which is very well miscible with most paints and varnishes. When answering the question whether it is possible to charge at home and how much pressure, I answer - that you cannot inject gas into an aerosol in a home-grown way. An exception to this rule are paints which, in most car paint mixing plants, can be stuck to a previously gassed aerosol can using a special razor through the valve to the center of the paint. The important thing here is that you cannot "squeeze" into this package, for example, grease or shaving foam. Why? and because, apart from the gas itself, there is a special solvent mixture inside with a hardener that will allow you to paint with 1K paint in such a way that a durable coating is created. The quantity and pressure that the aerosol container is able to take is specified by the packaging manufacturer.
The discussion revolves around the feasibility of refilling aerosol cans, specifically for WD-40 and aerosol paints, using compressed air. One user successfully used compressed air to expel the remaining WD-40 from a can that had lost pressure. The main inquiry is whether it is possible to refill an aerosol can with new car paint and use compressed air to spray it. Responses highlight concerns about potential risks, such as explosions due to flammable mixtures and the compatibility of old and new paint residues. Some participants suggest alternative methods, like transferring paint to a different container, while others emphasize the importance of using inert gases instead of air for safety. The conversation also touches on the types of propellants used in aerosol cans, such as propane-butane and dimethyl ether, and the technical specifications regarding pressure limits for aerosol containers.
