Honda Alpine BB714PH – no power after reconnecting plugs, what to check?
luki2604 4422 2
  • #1 14507522
    luki2604
    Rate: 41
    I have a car radio with Honda Alpine BB714PH navigation. The radio was factory installed in Honda CRV. Everything was ok, it worked as it should. Wanting to transfer the radio to another car (to the same CRV Honda, but the version without navi), I took out the radio and connected according to the scheme:
    - the audio plug with the power supply is the same, so I just connected it to the radio
    - there was no plug with NAVI power supply, so I connected a separate power supply and ground in a 12-pin cube on the radio, according to the diagram from the Internet (1/2/5 + 12V, 4 / mass)
    Unfortunately, the radio did not move. After reconnecting in an old car, the radio did not move.
    I do not know what could have happened. It seems to me that I have connected everything well. Or maybe I misread PINs in the NAVI cube.
    I'm looking for help on what to do next, how to check if something burned? Is it profitable to repair them?
    Greetings,
    Luke.
  • #2 14508765
    Antoni Dworny
    Rate: 10
    Start by measuring the voltage on the pins in both cars, as somewhere will be different, it will be easier to work out what has happened.
  • #3 15007124
    nowak_grzegorz
    Hello. I would like to know if you have been able to connect this radio and if you have diagrams to connect
