Unitra 5102 audio computer – how to dim overly bright programmer LEDs?
Fosucki_Czek 10083 2
  • #1 14514580
    Fosucki_Czek
    My 5102 imported from Gdynia factory suffers from lights too much in the programmer stage. My eyes feel sick after using these devices in the last weeks.
    How to easily set the light of LEDs lower? I have no good skills in polish schemes. There are eight little diodes and the interfront is hard to achieve. Can I put some resistors there or maybe one resistor or stabiliser in the supply stage of this programmer boards?
    Help, my eyes won't manage no more. I love this tuner though this is a factory failure in my opinion.
    Don't be angry, I am new here :))
  • #2 14514619
    cichy50
    Help: 37
    Rate: 21
    You can try to fit resistors to limit the current for weaker LED lighting. Resistors you can solder between diodes and PCB.
  • #3 14591047
    SlawekKedra
    Help: 1569
    Rate: 1935
    Change resistor R617 for higher value (original is 680 Ohm) on the board with SAS IC.
