Termet Ecocondens 25 Stove: Resolving Error E03 and E16 - Causes and Steps to Reset
qxw 57324 7
  • #1 14514754
    qxw
    Rate: 23
    Termet Ecocondens 25 stove displays error E03, it can be canceled by turning the knob to reset, the stove will restart, but after a while it displays the same error again. After 30 minutes of doing nothing, the error changes to E16, this can be reset and after a while again E03. I am asking for help where the cause lies.
  • #2 14515305
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    E03 means overheating. To be checked: pump, filters, temperature sensors.
  • #3 14517810
    qxw
    Rate: 23
    E03 exhaust gas temperature fuse I know, I'm interested in the reason and what to do next.
  • #4 14518306
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    Provide the exact model of the boiler.
  • #5 14518641
    serwo66
    Help: 61
    Rate: 292
    The question is whether the boiler was started and adjusted by the service and on which gas the boiler works. Have you drained the water from the radiators since starting the boiler?
  • #6 14518727
    qxw
    Rate: 23
    Termet EcoCondens 25 Plus, started and adjusted by an authorized service, natural gas, water from the heating system was not drained.
  • #7 14518794
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    How long was it regulated? Combustion chamber clean?
    If it is freshly adjusted and the combustion chamber is clean, I bet on the exhaust temperature sensor.
  • #8 14521710
    serwo66
    Help: 61
    Rate: 292
    The most common cause of damage to the flue gas sensor is the lack or very bad regulation of the boiler (flue gas analysis) or draining water from the central, e.g. repairs, but the most important thing is the proper venting of the exchanger. I have never had a damaged sensor in the boiler from the first Ecocondensa series, in the Crystal yes. The sensor is damaged due to overheating of the exchanger
    The repair can be very simple, it is enough to replace the sensor, but the problem is that the manufacturer of the exchanger does not sell the sensors only with the entire exchanger. The same applies to a Vaillant with the same exchanger.
    Unfortunately, repair it will hurt. Good luck.
The Termet Ecocondens 25 stove is experiencing recurring errors E03 and E16. Error E03 indicates overheating, potentially caused by issues with the pump, filters, or temperature sensors. The user confirmed that the boiler was properly started and adjusted by an authorized service and operates on natural gas without draining water from the heating system. Suggestions for troubleshooting include checking the combustion chamber cleanliness and the exhaust temperature sensor, as improper regulation or venting could lead to sensor damage. Replacement of the sensor may be necessary, but it is noted that the manufacturer only sells it with the entire exchanger, complicating repairs.
