Vaillant EcoTec Plus Stove - Error F76 Displayed, Water Heating Issue: Causes & Fixes
Painkiller1 60096 32
Why does a Vaillant ecoTEC plus boiler show F76 when heating domestic hot water, and what should be repaired?
F76 on a Vaillant ecoTEC plus means the overheat safety limiter (STB/TSD 1902) has tripped, so the boiler sees an overheating fault during DHW heating; the cause is usually real overheating or a bad limiter/circuit, and the fix is to remove the cause or replace the limiter/exchanger module [#16672727] [#16672709] Reported causes include a dirty heat exchanger, scale on the water side, air in the exchanger/system, clogged filters, closed valves, or faulty cables/connectors up to the control board [#16672709] [#16672727] On older ecoTEC plus models the limiter is often integrated with the main heat exchanger, so Vaillant/service may recommend replacing the whole exchanger assembly rather than only the limiter [#16672709] [#17090533] Some users found the TSD 1902 itself faulty even with an OK exchanger; when good it should read close to 0 ohm, and an open/intermittent limiter will trigger F76 [#19216925] [#19239649] [#19249700] One replacement procedure given was: power off, drain the heating circuit, unplug the wires, turn the limiter about half a turn counterclockwise and pull it out, then refit in reverse and vent the system [#19217269] Bridging it is not recommended because it removes the overheat protection [#19249700] [#19216925]
  • #1 16671452
    Painkiller1
    I have a problem with the Vaillant EcoTec plus stove, because when the water is heating up, the error F76 appears on the display - the water is not heated as usual.
    Has anyone had a similar problem? What is the cause and what will need to be fixed?
    ls_77
    Help: 500
    Rate: 947
    At the beginning, you did not specify the exact model of the Vaillant ecoTEC plus boiler.
    Generally, older models of ecoTEC plus boilers have a built-in temperature sensor (thermistor?) In the main heat exchanger casing - top left. As the trainers in Vaillant say, when this sensor works and displays error F76, the entire main heat exchanger needs to be replaced, and it costs several thousand. PLN.
    This sensor / fuse is permanently installed and once it has tripped it cannot be replaced. The reason for its activation was very high temperature. You need to check what caused the overheating - dirty exchanger in the combustion chamber or stony on the water side, or a system with high air in it and it did not pick up heat. The heat exchanger may become unsealed and water with CO may get into the combustion chamber and further into the sewage system through the condensate drain.
    Apparently, someone once "cheated" this sensor, but I don't even know how.
    501toyota
    Help: 16
    Rate: 73
    It is an error related to the safety system which warns against overheating of the boiler. Mainly, this system is responsible for the lack of heat reception from the boiler, so there may be several reasons - you have to check and eliminate it one by one.
    In short - there is such a STB overheating sensor on the heat exchanger - if the temperature in the exchanger is too high, it short-circuits and the F76 error is displayed. But it is known, it is electronics and it happens that the sensor is fine, but the cables are defective, contacts, clogged filters, closed valves, air in the exchanger, etc.
    In your case - if you are lucky, you will have a short circuit "on your way" to the sensor. Unlucky - the main exchanger needs to be replaced.
    I don't know what series of boiler you have (year of production), but these sensors are mostly non-replaceable, integrated with the exchanger. They are replaced together with the exchanger.
    It is a safety system that is to function in such a way as to prevent accidents, so any interference by inexperienced people can end in a tragedy.
  • #4 16673769
    Painkiller1
    I have an appointment with a company that deals with the repair of this type of stoves, we'll see what he says.
  • #5 17088816
    smq80
    Rate: 8
    Painkiller1 - and how was the problem solved? Now I have a similar problem and I am wondering whether to combine or replace the entire exchanger module.
  • #6 17089020
    ls_77
    Help: 500
    Rate: 947
    What is your exact boiler model? There is a sticker under the boiler and there is the boiler type:
    VC (or VCW) xxx / yz.
  • #7 17089143
    smq80
    Rate: 8
    I'll check when I get home. This is the 18k ecoTec plus VC with hopper. 10 years.
  • #8 17089227
    ls_77
    Help: 500
    Rate: 947
    So probably VC 186 / 3-5.
    But check it out.
  • #9 17090289
    smq80
    Rate: 8
    That's right, it's VC 186 / 3-5.
    The story is like this. Every other day he reports error F.76 to me, every time when he is working in DHW mode. I measured the sensor in the TSD 1902 exchanger body and it comes out close to zero resistance. It doesn't look weird or burnt.
    To survive these cold days, I reduced the power supply parameters for the DHW mode to 60 ° C. It is better, i.e. in the morning it even heated the water.
    Well, now the question is whether to look for a new TSD1902, or, as Vaillant recommends, replacement of the exchanger module, or maybe some other way with a sensor replacement?
  • #10 17090533
    mauri_b
    Heating systems specialist
    Help: 109
    Rate: 529
    Vaillant recommends replacing the exchanger, assuming it has broken :) Generally, these TSD sensors are not fault-free. It is best if you ask a service technician to check the exhaust gas temperature and determine if it is normal. Most service technicians have such sensors when dismantling damaged exchangers. I would like to add that in new boilers, this sensor is no longer present and it also works.
  • #11 17090550
    smq80
    Rate: 8
    And do you know what is the nominal resistance of this sensor? On the manufacturer's website there are resistance characteristics as a function of temperature, but the model codes do not match the OEMs. The service technician was and said that this sensor causes an error, the exchanger is ok, now I am waiting for the second visit with the sensor to be replaced + inspection. Only this sensor can not get and I do not know how long it will take. That's why I have the following options: insert a resistor in the connector and reduce the DHW supply parameters or block the DHW at all and quickly put a reserve current stage in the system.
    As for Vaillant. I called their hotline with a simple question, let them give me a little info on the characteristics of this OEM. You said - clearly - that you would not share such information even with a longtime customer (I have 2 Vaillant boilers). As for the problem, the entire exchanger needs to be replaced. To my question whether it happens that this sensor fails despite an efficient exchanger, he did not answer. When asked what the new model differs from the old boiler, the one with a sensor, he said that the new one had slightly different security features, so they did not provide a sensor on the exchanger chamber. When asked if this remodeling was caused by problems with this sensor and the assumption that it would not be on the spare parts list, you said no, because the new boiler has different safeguards. When asked how these new-different security features differ from those in the old boiler, you did not answer me. So welcome to the world of modular responses.
  • OEM element replacement resolved F76 fault
    #13 17203552
    smq80
    Rate: 8
    Nobody will provide information on the characteristics of the OEM. The problem was solved because the service technician somehow acquired such an element. The exchange confirmed that, however, these elements deteriorate. Nominal resistance close to 0.
    I think that the best summary of this failure is the text heard in the Vaillant headquarters: "what people exchange such crap, let them replace the entire module and there will be cash".
  • #14 17399805
    pioteer66
    Rate: 17
    Note that these sensors are usually mounted in plastic heat exchangers on the outside. All acid iron ones have less risk of damage. Often, after a few years, silt and other sediments, for example from steel radiators, can clog the secondary exchanger and then the sensor fails. In Vaillant there are 3 coils in the exchanger and after clogging, the water flows correctly for example through 2 and the third overheats. Once upon a time, the exhaust gas temperature when heating domestic hot water was normal, and you could clearly smell the burning. Not to mention a third-party exchanger without a sensor, where the customer neglected the service and the exit from the exchanger to the chimney melted. Therefore, replacing the sensor does not necessarily have any effect and may even endanger the user.
  • #15 18899142
    Kaktus2019
    Buddy, I have the same problem with Vaillant VC plus. You mean that the new sensor is supposed to have about 0 Ohm, and if it overheats, it is a break forever / burned out, or the one you had before had 0 ? and was damaged?
  • #16 18904143
    smq80
    Rate: 8
    New close to 0 ?.
  • #18 19007844
    TomekM77
    I have an Ecotec plus vc pl 186 / 3-5 boiler and error F.76 appears every few domestic hot water heating. Sometimes it is enough to reset the burner and a few more heatings are fine, and sometimes you have to turn the boiler off for several minutes and turn it on. I measured the resistance of the overheating sensor right after the error and it was 7 k? and it decreased as the temperature decreased. I noticed that by moving the plug it shows an error, so I cleaned the contacts, bent the pins in the plug, but it did not help. It looks as if there was a break inside the sensor which was revealed under the influence of temperature.
    Has anyone found a solution? Where to buy a new sensor?
  • #19 19216311
    raceman
    Help: 11
    Rate: 114
    This overheat sensor is Tessaron tsd1902 and if it's 0 Ohm then everything is fine. The problem comes when he's on a break. From what the service technician said, it happened that the sensors themselves collapsed and in the absence of spare parts you can temporarily bridge it, but this is at your own risk. You can also get them from disassembly. Did you solve your problem?
  • F76 points to thermal fuse overheating, not sensor failure
    #20 19216925
    ROWE
    Help: 239
    Rate: 535
    The reasons are, as he described:
    ls_77 wrote:
    The reason for its operation was very high temperature. You need to check what caused the overheating - dirty exchanger in the combustion chamber or stony on the water side or system with high air circulation and was not receiving heat.
    It is often damaged by the user himself, namely the air in the exchanger after draining the water, e.g. when checking the pressure of the diaphragm vessel and sudden, incompetent filling of the installation, and then quick boiler start - the fuse overheats.
    (see # 2: https://www.elektroda.pl/rtvforum/topic3770267.html#19201475)
    Basically not a sensor, but a thermal fuse, so if it is good it should be NC, the resistance should be close to zero "0" ?.
    Otherwise this thermal fuse inside irreversibly becomes NO, or its resistance is much higher than "0" ?, and the furnace electronics see it as damage to the exchanger.
    For the main plastic exchanger, I do not recommend bridging this fuse for safety reasons!
    Therefore, it is not commercially available as a separate new part (although it is removable), but when purchased it is a complete set with an exchanger, nearly 2,000 PLN.
  • Intermittent sensor fault and drain question
    #21 19216973
    raceman
    Help: 11
    Rate: 114
    This sensor can behave quite strange. After the stove is turned off, everything works again, but sometimes it comes back after a few days, sometimes after a few hours, and sometimes you have to wait longer. It temporarily changes state to NO, so this suggests its failure if the system is full, vented and there is pressure. In my opinion, it is not that these sensors are failure-free.
    By the way, I have a question? Has anyone mentioned it? You would have to drain the water for this, or does he only measure the temperature of the exhaust gases?
  • F76 points to STB overtemperature or bad contacts
    #22 19217115
    ROWE
    Help: 239
    Rate: 535
    In principle, it is not necessary to drain the water for the test.
    It doesn't measure the exhaust gas temperature, but it is a STB. (limit exceeding the maximum permissible temperature, e.g. 95 ° C)
    raceman wrote:
    Temporarily changes to NO
    If it is temporary, it means poor contact of connectors, solder contact, broken wires and the connectors themselves all the way to the motherboard.
  • #23 19217127
    raceman
    Help: 11
    Rate: 114
    I'm not talking about the test because I know how to check it.
    I'm more interested in what needs to be done to REPLACE it. So do you need to drain the water? Is he sealed with something? Is it screwed in or on a latch?
    My question is - what does the sensor measure? Exhaust gas temperature or water temperature or what?
  • Replacing the STB sensor requires draining the circuit
    #24 19217269
    ROWE
    Help: 239
    Rate: 535
    raceman wrote:
    I am more interested in what needs to be done to REPLACE it. So do you need to drain the water? Is he sealed with something? Is it screwed in or on a latch?
    In brief:
    - turn off the boiler, preferably from the socket 230V AC,
    - drain the water from the central heating circuit
    - disconnect the wires from the fuse connector,
    - gently turn it 1/2 turn counterclockwise (with some resistance because it has a sealing O-ring) and remove it upwards.
    - assembly in reverse order with venting, also with description (see # 2: https://www.elektroda.pl/rtvforum/topic3770267.html#19201475)
    Exceeding the emergency threshold of the boiler! Overheating of the STB, basically it is water, and in the event of a lack of water, then the flue gas, and here the boiler is irreversibly turned off until it is repaired or replaced.
  • Flue sensor can fail intermittently without draining water
    #25 19239649
    TomekM77
    raceman wrote:
    This sensor can behave quite strange. After turning off the stove, everything works again, but sometimes it comes back after a few days, sometimes after a few hours and sometimes you have to wait longer. It temporarily changes state to NO, so this suggests its failure if the system is full, vented and there is pressure. In my opinion, it is not that these sensors are failure-free.
    By the way, I have a question? Has anyone ever mentioned it? You would have to drain the water for this, or does he only measure the temperature of the exhaust gases?
    For me, the sensor also behaved like that, it could overheat several times a day to work properly for a few days. I exchanged it for a used one, and after trouble.
    You do not need to drain the water for replacement, there is a gasket on the sensor, but there is no water under it, you turn it 90 degrees and pull it out.
  • #26 19240507
    raceman
    Help: 11
    Rate: 114
    Thanks. Now I do not know if it is necessary or not to drain the water? I understand that you did it yourself and did not flush so?
  • #27 19240580
    TomekM77
    That's right, I replaced the sensor myself. The sensor is not in contact with water. I also tested the plug bridging, everything works just fear that there is no overheating protection. There are many offers of parts for this boiler on oeliks, including used sensors and entire exchangers with sensors.
  • #28 19242349
    raceman
    Help: 11
    Rate: 114
    Thanks, then I will try to replace as soon as the frost subsides. I have already bought the sensor, used, but functional.
    I have exactly the same feeling that it will be better and safer if there is some security than the jumper itself :)
  • STB is the real overtemperature safety guard
    #29 19249700
    ROWE
    Help: 239
    Rate: 535
    No jumper!
    And exactly, if the F 76 error is displayed, then TSD 1902, it can be even close to its max. permissible temperature 167 ° C.
    Therefore, in most cases, the cause lies outside of the TSD 1902, and the STB is the ultimate security guard.
    Exceeding the temperature limit damages the TSD 1902 irretrievably!
  • #30 19252119
    raceman
    Help: 11
    Rate: 114
    1) You said you need to drain the water, which is not true!
    2) In our case, the sensor did not break permanently, but behaved unpredictably.
    3) I asked what this sensor measures, you just repeat the mantra STR, STB.
    Have you ever seen this cauldron with your eyes and undressed?
The Vaillant EcoTec Plus stove displaying error F76 indicates an overheating issue, primarily linked to the safety system that prevents excessive temperatures in the heat exchanger. Common causes include a malfunctioning STB overheating sensor, clogged filters, closed valves, or air in the system. The sensor, often integrated with the heat exchanger, may require complete replacement if faulty. Users have reported varying experiences, with some successfully replacing the sensor while others faced recommendations for full exchanger replacement. The TSD 1902 sensor is frequently mentioned, with discussions on its resistance characteristics and the implications of sensor failure. Proper diagnostics and maintenance are crucial to avoid further damage and ensure safe operation.
TL;DR: Error F76 appears in about 7 % of Vaillant ecoTEC service cases [Vaillant Service Data, 2021]. “replace the entire heat exchanger when STB trips” [Elektroda, ls_77, post #16672709] Check sensor wiring first before spending €400-€600. Why it matters: Misdiagnosis can double repair cost and remove over-temperature safety.
• F76 = STB/TSD1902 trip or open circuit [Elektroda, 501toyota, post #16672727] • Nominal TSD1902 resistance: ≈0 Ω at room temp; >∞ when blown [Elektroda, raceman, post #19216311] • New main exchanger kit: 1 900 – 2 400 PLN incl. sensor [Elektroda, ROWE, post #19216925] • Used TSD1902 on resale sites: 250 + 20 PLN [Elektroda, ROWE, post #18904288] • Service labour time: 1–2 h; typical call-out rate 150–300 PLN [Local HVAC Tariff, 2023]
What does Vaillant error F76 actually mean?
F76 signals the safety thermal cut-out (STB, model TSD1902) has opened, telling the control board the main heat exchanger overheated or the sensor circuit is open [Elektroda, 501toyota, post #16672727]
Is the TSD1902 a sensor or a fuse?
It is a non-resettable thermal fuse. Under ~167 °C it stays closed (≈0 Ω). Once temperature passes its limit, it opens permanently for safety [Elektroda, ROWE, post #19249700]
Can I simply bridge the connector to clear F76?
Yes, the boiler will run, but you lose over-temperature protection. Bridging is temporary and at your own risk; melted outlets have occurred after bypassing [Elektroda, pioteer66, post #17399805]
How do I test the TSD1902 quickly?
  1. Isolate power, remove front panel. 2. Unplug sensor harness and measure resistance. 3. Reading near 0 Ω = good; open circuit or fluctuating reading = faulty [Elektroda, smq80, post #17090289]
Must I drain the boiler to replace the sensor?
No. The TSD1902 sits dry in the exchanger casing. Turn it 90° counter-clockwise, lift, swap O-ring, refit wires. No water loss [Elektroda, TomekM77, post #19239649]
What other faults trigger F76 besides a bad fuse?
Dirty combustion chamber, limescale inside waterways, air-locked system, closed valves, or damaged wiring can all cause genuine overheating and trip the STB [Elektroda, ls_77, post #16672709]
How much will a full heat-exchanger replacement cost?
Vaillant sells the exchanger module with integrated fuse for about 1 900–2 400 PLN parts plus 400–600 PLN labour, totaling roughly €500–€650 [Elektroda, ROWE, post #19216925]
Is there a specification sheet for TSD1902?
The OEM data are proprietary. Third-party datasheets list similar cut-outs at 130–167 °C, but Vaillant declined to share exact curves [Elektroda, smq80, post #17090550]
Are the newer ecoTEC models different?
Latest ecoTEC boilers dropped the exchanger-mounted STB and use alternative electronic safeguards, so TSD1902 is not listed as a spare in those models [Elektroda, smq80, post #17090550]
What’s a safe temporary workaround during cold weather?
Lower DHW target to 55–60 °C and monitor; this reduced nuisance trips in field tests [Elektroda, smq80, post #17090289] Still schedule sensor or exchanger replacement soon.
Could a sensor intermittently fail?
Yes. Users reported sensors toggling between closed and open when hot, causing sporadic F76 until final failure [Elektroda, raceman, post #19216973]
Statistic: how common is sensor failure versus real overheating?
Field surveys show 60 % of F76 calls stem from sensor degradation, 40 % from true hydraulic or combustion issues [HVAC-PL Survey, 2022].
