TERMET gas heater E2 error code keeps appearing every 20 minutes—what does it mean?
kaktus232 41356 6
  • #1 9235757
    kaktus232
    Rate: 11
    I have a problem: I have a gas heater at home. It is used for heating home and water by TERMET. And the problem is that I get an E2 error and I don't know what it is. I have three knobs on it to adjust the temperature, two knobs to change the mode and check the water pressure. And the stove runs for a while, an error pops up, I check the pressure with the knob and it starts working normally again and it works like that for 20 minutes and the error comes up again. Does anyone have any idea what this error is about, what is causing it???
  • #2 9236260
    zybie
    Level 30  
    Help: 133
    Rate: 754
    You do not provide the exact type of boiler, so it is difficult to give a clear answer. From the description, it looks like the overheating sensor is activated. provide more details.
  • #3 9236577
    kaktus232
    Rate: 11
    I don't know what boiler model it is, tell me where I can read it and I will tell you. the only information I know is that it is over 10 years old. and the fact that the stove doesn't even have time to heat up because it turns off immediately, so I don't know what's going on when I turn on the water, it barely reaches the temperature and turns off when it's reheated, and the stove starts to run the same way, the water in the radiators is slightly warm, it's already warm, that's all, only E2 is displayed.
  • #4 9237713
    friggo1
    Rate: 19
    check the temperature limiter on the heater, if it is OK, I suspect that the furnace needs maintenance or the pump is damaged
    Moreover, it says on the casing what type of stove it is and I think it is a Minimax
    Please correct spelling errors
    mod - mirrza
  • #5 9244907
    friggo1
    Rate: 19
    I'm very sorry that I offended you, Moderator Mirrza, with my poor spelling, but I wonder if you are so precise, why do you write your nickname in red with a lowercase letter?
    what a non-Polish-sounding name
    mod - mirrza
  • #6 9245053
    mirrzo
    Help: 441
    Rate: 2609
    My nickname, like yours, is written the same - with a lowercase letter. That's how I imagined it. You too. It is very Polish. Not "polka"
    EURO-DOM
    Krótka, Elbląg, 82-300
  • #7 9245116
    friggo1
    Rate: 19
    listen, I have an old keyboard and that's why I don't do it out of love for your red comments
    If this is such a problem, delete my account now
    Moderated By mirrzo:
    One capital letter appeared, so there is no question of an old keyboard. Also about the lack of commas etc. I'm rewarding my friend with a break from writing. Please think about it and report it in at least 7 days for unblocking. You can delete your account personally, but why?
The discussion revolves around a recurring E2 error in a TERMET gas heater, which is used for home heating and water heating. The user describes the issue of the heater shutting off shortly after starting, with the E2 error appearing intermittently. Responses suggest checking the temperature limiter and considering maintenance for the furnace or a damaged pump. The user is uncertain about the specific model of the boiler, which is over 10 years old, and is advised to look for model information on the unit itself, with a possibility that it is a Minimax model.
