Connecting a garden light to the EVER 212 gate opener - how to do it?
dawid8688 2943 2
  • #1 14577854
    dawid8688
    Hello, I am looking for advice regarding the above automation....
    Please find the manual attached.
    I need advice regarding the connection of the garden lamp. In order to switch on the lamp with the remote control, is it sufficient to connect it to the output described "230V AC output for garden lamp"? Then the lamp should be switched on from the remote control, yes?
    And the second question is about connecting the same lamp additionally to the switch installed in the house. There is a description in this manual " To an external switch for the garden gate", so I can connect a normal wall switch there. Where exactly do I connect this switch? Because there is only one socket in the manual, but you need two for the switch.... Then the lamp should be switched on with this switch, because it already has power from the same circuit as the remote control, yes?
    I am a bit green on the subject and that is why I am asking these questions.
    I would appreciate your help. Regards
    • Avidsen_350_Ever_212_SELTEX.pdf (5.32 MB) You must be logged in to download this attachment.
  • #2 14587922
    Jacek Rutkowski
    Help: 69
    Rate: 275
    AD.1 Yes, the lamp should be connected under "230V AC output to garden lamp".
    AD.2 If I have understood the instructions correctly you should connect the switch under the input "To external switch for garden lamp" and the other terminal to "12VDC power supply for small console"
    However, the easiest way is to call the manufacturer and ask....
  • #3 14588988
    dawid8688
    Thank you very much! All in all right, I'll take the box apart and call the manufacturer. Best regards
